Welcome to the North American Subaru Impreza Owners Club Friday October 19, 2018
Old 06-21-2017, 05:46 PM   #1
ThoR294
Member#: 434158
Legacy 2nd gen legacy build thread
1998 L Wagon 2.2 Auto. Named Scuttle by GF, the White Whale by others.
It was/is my first Subaru, and it made me fall in love with the 2nd gen WAGONS for sure.
To start, I found my wagon (named Scuttle, thanks to the girlfriend)
on craigslist. Picked him up for $650. He was pretty beat up, but what is the fun in a build thread if it needs no work?
Here is when I first got it:
180K miles. Autotragic (thanks again, girlfriend). No real options besides P/S and A/C i guess?
Issues:
Hubcaps ruined, 3 bent wheels, 1 out of round tire, right rear caliper doesn't work, A/C doesn't work, seats ripping, rubber trim peeling off under windows, hooted dented and rusted, front brakes scraping, harmonic balancer wobbling, key barely worked in all doors, front bumper was resprayed with overspray on the headlights, blinkers, and 2 bolt holes on the right side of the bumper, headlights pointing straight at the ground, HORRIBLE torque binding when turning the wheel, grille missing. So bad I had to put the car in FWD mode to get home. That is all I can remember when I first got it.
bumper damage:
My first steps were to fix the torque binding, replace all 4 wheels/tires, and do brakes all around.
I flushed the trans twice, and torque binding is 90% gone. Replaced 4 wheels and tires with 15" wheels from another outback, and put outback 2pot brakes on the front, new RR caliper, pads/rotors all around. This was taken right after grill was replaced, and I also got an outback hood, why not?
Here it is with the 15" wheels and hood:
I had to redrill the headlight mounting holes, and get some headlights from the junkyard because they were all BROKEN. I think each side had 1 bolt holding them in! The A/C had dye in it, so I easily found the leak on the driver's side A/C line. The O ring was shot, replaced that, A/C now works after a re-charge.
My GF's bro was driving it, and he said "hey, I just lost power steering". I thought no big deal, probably pump. I get to my GF's parents house and see...
Oops. Looks like person before me who did Tbelt forgot to torque something to spec.
Crank was OK thank god. Replaced balancer and belts. Back to normal.
I had to flip a 95 wagon I found to sell to my GF's boss. It needed 4 tires. I figured screw these 15" wheels, I'll put them on the other wagon and get some nice wheels and tires for my own wagon
ThoR294 is offline   Reply With Quote
Old 06-21-2017, 05:46 PM   #2
ThoR294
Member#: 434158
I went around and replaced all the window trim. I decided that since the speakers suck, ill upgrade them.
Before
After
These are rear ones. In the front I put ones with separate tweeters. Sorry, forgot a picture. Thanks to a phenryiv1 on legacyGT for the brackets!
Also installed an Alpine Type-R 15" sub in the trunk. So much for wagon trunk space, but I made it easy to remove. (this done early 2016)
Upgraded to outback leather seats, fake wood trim in the interior from a limited, leather door inserts.
JDM tails with my 16" snow tires/wheels I got from a saabaru guy. (winter 2016)
Also pictured is a 2005 honda pilot rear wiper blade. mine was rusted and spring was shot. Found out these fit perfectly.
I managed to get a bumper for $30, had my friend repaint it. Got a JDM grille and had him paint it black as well. Retrofitted morimoto H1s into new depo headlights. (5/25/2017)
Few weeks ago (06/02/2017),
Car smelled like gas during start up. Didn't run 100% while cruising. I did plugs/wires/MSD coil when I got the car (Maybe early 2016), so I figured it's either a bad injector, or bad compression.
Easiest thing to test is compression.
Cylinders 2, 3, 4:
Great!
Cylinder 1:
I drop a little bit of oil in the cylinder
my reaction:
So I said **** it. What is the worse that can happen at this point?
I ran Motor Medic through the car twice, and put a drop in the cylinder.
I didn't take a picture, but now its squeezing ~174psi!!!!!! Car runs much better now. It has been going strong for 3 weeks. will check compression again soon just to see.
Still waiting to go in:
JDM trunk spoiler
Coilovers
On the to get list:
outback sway bars (20mm front 18mm rear)
possibly swap out the motor for a refreshed 2.2 with a delta cam regrind.
maybe another trans, or convince the gf to let me 5 speed swap it.
Old 07-07-2018, 07:24 PM   #3
99_legacy_gt
Member#: 487852
Before
After
Cylinders 2, 3, 4:
Great!
Cylinder 1:
my reaction:
JDM trunk spoiler
Coilovers
On the to get list:
Looks good man! Waiting to see more!
99_legacy_gt is offline   Reply With Quote
Old 07-11-2018, 01:48 PM   #4
ThoR294
Member#: 434158
Haven't been updating this thread too much haha, ill copy pasta from my legacyGT thread.
Tinted the windows over the winter - looks much better.
Replaced all brakes with hawk HPS pads and installed the other 3 stainless brake lines. Had to replace drivers rear caliper as it was frozen, wasn't actually doing anything lol. Same as the passenger rear one when I got the car.
Also took the snows off and put my BRZ wheels that I got for a steal on.
Still need to re-assemble my STI struts and RCE yellows to throw into the car. Also need to swap the engine/trans and install the full stainless exhaust. Lots of stuff to do. A "summer project"...
Last week the HVAC decided to make love to it with his truck, so it's at the body shop right now.
Old 07-14-2018, 05:24 PM   #5
99_legacy_gt
Member#: 487852
Dang! That sucks man! Those wheels look nice! And so does the tint. What engine and trans you swapping into it?
Old 07-14-2018, 07:54 PM   #6
ThoR294
Member#: 434158
Yeah lol not fun.
The brz wheels are a great fit. Just gotta lower it.
Just a 2.2 auto with deltacam reground cams. Has 80k miles on it. Anything turbo is $$$$$$$$
Old 08-24-2018, 03:06 PM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Yeah lol not fun.
I see your rear window sticker, you in NJ?
Old 08-24-2018, 03:14 PM   #8
ThoR294
Member#: 434158
Yessir, central.
Also, to update... spoiler on, liftgate/bumper painted. car has now 2 shades of white unfortunately lol
just found either my LF caliper seized or SS line failed. ugh
Old 08-26-2018, 09:17 AM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
I had my front bumper replaced years ago after a towing company screwed up the original. Had the bumper painted off the car, then swapped the bumper cover out myself. Sure enough, I've got 2 different shades of silver. *sigh* Better than the broken bumper that was on there before, though!
