Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 04-14-2018, 02:38 PM   #1
DoubleDD
Member#: 376101
Default Baja Radiator
So My 2005 Turbo automatic with Sport Shifter needs a new radiator
I looked at the CSF 3356 but there's a comment that its not for models with a sportshif transmission - Is that really a thing
CSF 3356 {Click Info Button for Alternate/OEM Part Numbers} 1 Row Plastic Tank Aluminum Core High Performance; Use Mini 16 psi Cap Info
OE Style Design; w/o Sportshift Transmission
https://www.rockauto.com/en/catalog/...,radiator,2172
DoubleDD is offline   Reply With Quote
Old 04-25-2018, 03:05 AM   #2
steven765
Member#: 105920
2006 Baja 5 Speed
steven765 is offline   Reply With Quote
Old 04-25-2018, 10:36 AM   #3
DoubleDD
Member#: 376101
Originally Posted by steven765 View Post
Mine's a turbo the above is for non-turbo - I ordered one form RockAuto.com $84.xx (including shipping)
https://www.rockauto.com/en/moreinfo...061&cc=1430884
It should be in today, I'll install it this weekend
Old 05-04-2018, 03:05 PM   #4
Baja 462
Member#: 485507
2005 Baja Turbo
White/Silver
Default How is the new Rad?
How did that new radiator come out? Mines not leaking but it is a little ruff. Kinda like to see if you had luck with the R.A. radiator.
Baja 462 is offline   Reply With Quote
Old 05-07-2018, 10:27 AM   #5
DoubleDD
Member#: 376101
So far its been good. I was stubborn and I didn't want to remove the plastic skid plate (if ya can call it that) so it was taking a lot longer than it should have.
I finally caved and removed the plastic cover that's under the car engine and things really started to go fast after that.
I should have changed the main hoses but I didn't I hope - I don't regret that.
Old 05-10-2018, 10:30 PM   #6
Baja 462
Member#: 485507
2005 Baja Turbo
White/Silver
Default Got ya
Good to hear. Not real familiar with RockAuto parts quality, so wanted to ask someone that's used them. Thanks for the info 😎
Old 05-12-2018, 02:14 PM   #7
DoubleDD
Member#: 376101
Guy at work uses them, Sez they are good, fast and inexpensive
Old 05-20-2018, 12:19 AM   #8
JustyWRC
Member#: 153088
2005 Baja Turbo
06/04 For 18 Imp 4dr Sprt
How many miles when yours went? Mine popped at 130K. Put OEM back on it.
Old 05-21-2018, 12:05 PM   #9
DoubleDD
Member#: 376101
I think I have 140,000 ish
Its been going for a while - I always smelled antifreeze and even saw some green puddles in he snow this past winter.
I finally started to see a puddle everyday so I ordered a replacement and was adding water everyday
the new one is in - so far so good
