09-25-2007, 03:16 PM | #51 |
Member#: 81102
South East
what do you mean ride? there are more parts on the car...more non oem parts=higher probability of a part failing. I have an ewg too btw
09-25-2007, 04:05 PM | #52 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
oem doesnt always = better
and an ext gate is a spring and a diaphragm, not really parts that fail a lot and there arent really more parts on the car, you switch from an internal gate to an external, you really didnt add more. |
09-25-2007, 08:47 PM | #53 | |
Member#: 26933
BAIC
Vehicle:2006 STI CGM |
Ringlands generally let go from excessive knock... not too many other possibilities. It probably had to do with heatsoak at the track. Were you icing down the tmic at all? Thanks -- Ed |
09-26-2007, 12:13 PM | #54 | |
Member#: 81102
South East
yah someone said it was overboost, some people say bad gas, some people think i changed the setup last minute, etc........i know it's not impossible to creep with a ewg, but i didn't do anything different than normal setup wise...nothing was changed, nothign altered, nothing ran funny. Car was running perfectly EVERYDAY until that day at the track. It was decently hot though at the track...but i have no idea why all those days when it was hotter and i was pushing the car more and giving it more chance to creep or overboost and it didn't(from what i saw/heard). Yah my folks don't understand that drag racing is probably the least damaging of the motor sports to the car's. I'm only 23 and this is my dd(other than the motorcycle). So I have to give up my quest for your's and sean's record. no i wasn't icing or anything, got there and let her cool down and then got in line....started smoking up first run 12.9@106.66 thank's ed |
09-26-2007, 12:18 PM | #55 | |
Member#: 81102
South East
i think it's quite a change going ewg, UR up-pipe for tial 38, mbc vs. Stock boost control......... there is also the manual boost controller, i forgot to mention that when i returned ride500's post. So yah imo there is a lot of factors that can lead the mbc to cause problems in the car and the ewg is run by that mbc. Weather, altitude and other factors can lead to the car hitting target boost earlier or later, etc. and you need to address these changes so the car isn't getting hurt |
09-26-2007, 12:41 PM | #56 | ||
Member#: 36033
SCIC
A manual boost controller is quite a simple device. Quote:
09-26-2007, 02:37 PM | #57 | |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
how do you figure? you had a wastegate valve before, and you have one now. you had an actuator before, and you have one now. you had an up pipe before, and you have one now. as far as oem being more reliable, generally i would agree, but there are a lot of oem parts that have come off my car to be replaced by something stronger. ken ps a good ball and spring mbc is MORE reliable than any EBC. |
09-26-2007, 02:50 PM | #58 | |
Member#: 26933
BAIC
Bad gas is certainly a possibility from the pump, but race gas tends to be pretty darn consistent, so I would highly doubt that as the cause. As far as pushing the car hard before this happened, were you doing so on your race gas map and boost levels or were you on pump gas at that point? I still have my bet on the heatsoak issues at the track. Even though you let the car cool down prior to your run, the TMIC can get extremely hot when the car isn't moving. A very hot TMIC immediately before the run with the resulting knock could certainly result in some serious problems. BTW, I'm 24 so I know where you're coming from with the parents -- Ed Last edited by Equilibrium Tuning; 09-26-2007 at 03:24 PM. |
09-26-2007, 04:49 PM | #59 | |
Member#: 81102
South East
09-26-2007, 04:51 PM | #60 | |
Member#: 81102
South East
right, i don't disagree with anything. I just was stating the fact that i don't trust non oem parts, as much as i trust oem. I think if my car had stock boost control i might have been able to avoid my car going kablleeewy, on the same token, it might have had no bearing. you're the man ken, what's up with your setup? |
09-26-2007, 04:55 PM | #61 |
Member#: 101607
South East
Vehicle:06 Subaru STi Aspen White |
so has this car gotten tracked yet!? im anxious to see the traps!
09-26-2007, 05:28 PM | #62 |
Member#: 63179
BAIC
Vehicle:2006 Stock Turbo STi [email protected] VF39 |
hahaha not yet
the driverr still in the practicing phase he jus receltly smoked a 400whp trans am from 40 - 130mph yes thats goin of a roll his goin against couple of cammed full bolt on c5 z05 and a 450whp 03 04 cobra. from 40 - 140mph i will get the vids on this oh btw i beat that conbra already 450whp 40 - 140 by about 4 - 5 cars streeet racing is bad but only way to really learn your car since we live like 150mile away form the track |
09-26-2007, 06:11 PM | #63 | |
Member#: 84206
I guess Phung is no longer taping the runs huh!J/K Good luck with the practice runs.
Ron Quote:
09-26-2007, 07:42 PM | #64 | |
Member#: 142748
09-26-2007, 07:45 PM | #65 | |
Member#: 142748
09-26-2007, 07:47 PM | #66 |
Member#: 142748
09-26-2007, 07:51 PM | #67 | |
Member#: 84206
29... Sat Grudge Fest Gates open 4pm. Racing 6-10pm Adm. $5. Racing $35 30... Sun CMI SPORT COMPACT DRAGS Gates open 8am Adm. $10,Racing $45 Info: 916-416-0546. Ron |
09-26-2007, 08:32 PM | #68 | |
Member#: 142748
Is this every sat and sun? Thanks |
09-26-2007, 08:39 PM | #69 | |
Member#: 26933
BAIC
Having the stock boost control wouldn't have saved you. The ECU only pulls out boost if the IAM drops significantly and it takes quite some time for this to happen. By the time boost was potentially dropped, the damage would have already been done. -- Ed |
09-26-2007, 08:40 PM | #70 |
Member#: 26933
BAIC
09-26-2007, 08:55 PM | #71 |
Member#: 48219
Vehicle:. Always drive the race line . |
Vaus -
Hmmm...I'm 24 and will be 25 in November as well...But what are the chances that your birthday is also on the 25th? Anyway, I like the road dyno plots that you use. It would be nice if all road tunes on NASIOC used the same method to analyze acceleration data. Do you want to share your road dyno with the community so we can start displaying/comparing tunes in a standard fashion? Standards are good in my opinion, as they give a universal reference point. If you are up for it, I'll be the first in line to adopt to your road dyno 'software'. If not, that's cool too. |
09-26-2007, 08:58 PM | #72 | |
Member#: 101607
South East
09-26-2007, 09:17 PM | #73 | |
Member#: 26933
BAIC
Many people have asked to purchase the road dyno software but for now I've decided to keep it proprietary. I've managed to earn some significant credit for the software and the numbers it produces and don't want to spoil that by having people potentially messing with the parameters to skew their graphs one way or another. Remember, its just as easy to change how this software reads as it is with any chassis dyno out there. I have been offering a little service to some people who tune their own cars. They send me logs along with weight and tire info and I send them plots for a small fee. Thanks -- Ed |
09-26-2007, 09:26 PM | #74 | |
Member#: 63179
BAIC
haha if you do break my record. im goin to call up ron and ed ask them to help me run 10s on stock turbo hahaha.. and ill hire earl to drive my car or MAYBE 100 shot NAWZZZ |
09-26-2007, 09:44 PM | #75 | |
Member#: 114631
Vehicle:2009 GTR, 735whp 13' Benz, 15' WRX |
speakin about the NAWZZZ, some kid put a 75 shot in his stg 2 sti about two weeks back. If he goes sub 11.5's, i think im gonna try it, lol. Just have to buy another intake manifold because ill have to tap the current one. When and if the motor blows, ill switch the manifolds and use suby's 5yr/60k wrnty In this case, I just think NOS would be soooo cheating, although it would be cool to have. I had it in my integra back in high school, lol. Oh yeah, my high school days of cars that couldnt even break 13's with nitrous, haha. |
Another FAST pump + meth 35r car 11.3@126, 128.7 best mph | Junior2JZ | Proven Power Bragging | 23 | 04-30-2009 05:16 PM |
another fast and furious meet | Mtnbrdr | North West Impreza Club Forum -- NWIC | 9 | 03-29-2009 02:59 AM |
Another N00b VF39 Problem | SHIFTcanadian | Texas Impreza Club Forum -- TXIC | 29 | 02-09-2008 01:36 PM |
upgrade form TD04 to VF39,do i have to get another inlet for vf39 or use stock one? | pengmao | Newbies & FAQs | 14 | 02-07-2008 08:53 PM |
Another fast WRX...BUT this time its from the West Coast | MARKGSTI | Proven Power Bragging | 45 | 08-23-2005 03:41 AM |
