Welcome to the North American Subaru Impreza Owners Club Saturday August 8, 2020
Old 07-16-2019, 12:45 PM   #1
buddyjon
Member#: 504244
Default Variable Valve Timing 2.5L NA SOHC Intake Rocker Assembly
While removing the intake rocker assembly on a 2008 subaru impreza I lost one of the springs that are part of the hydraulic variable valve timing mechanism in the rocker arm assembly. Does anyone know where I can get a replacement spring or a replacement kit that includes the spring and pins? I've looked everywhere and private messaged a few longer term forum members but have not had any luck. Any help is appreciated.
Explanation of what I'm referring to starts at 9:40 in the following YouTube link:
buddyjon is offline   Reply With Quote
Old 07-22-2019, 02:10 AM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
You're likely going to have to go to a junkyard and pull the parts you need.
CosmoTheCat is offline   Reply With Quote
