#1 |
Member#: 494268
![]() 2008 Subaru WRX STI Hatchback - Silver
NOVA - Northern Virginia $10k OBO 136,000 miles and going up, daily driven 6 speed stock transmission Local shop (Mach V Motorsports) checked it out recently, notes available. Passes emissions and safety. Have listed everything to the best of my knowledge, can provide additional receipts if requested. Good: - New coil packs and a rear wheel bearing just replaced ~FEB 2025 - Mach V - IAG stage 2 block with full rebuild, done 30k miles ago, at 106k - original spun a bearing, all parts recommended by shop were replaced + new clutch and flywheel - Dyno tuned with cobb downpipe at 298HP wheels (sheet attached) - Now detuned to cobb stage 1 off the shelf and stock down pipe, in order to re-pass emissions - VA model steering rack, with faster turning ratio replaced a few years ago - New rear subframe and all suspension components outside of struts/springs, new bushings all around - ~2021 - Front lower control arms upgraded to 2011+ style - Gas tank replaced with a used/rust free - Replaced alternator, power steering pump and belt within past few years - Refurbished calipers all around + stainless steel lines + flush in 2022 - Tomei Equal length headers, SPT cat back, up pipe COBB cat less - COBB intake and air box - Newer tires from 11/2024 (receipt attached with model) - I have receipts form it all, most work was done either by Mach V or Moore Auto Bad: - Worst part is the rust - radiator support (just the piece running under, radiator still mounted solid for now), strut mounts, spots around body and hood and bubbling on door trim, pictures of the more noticeable available - Front bumper cracked near bottom + driver side front fender scraped, and starting to rust - AC compressor grinds, belt removed (but all hoses and condenser recently replaced), so no AC - Strut top hats worn, original coils and struts work but likely need replace - Clutch pedal creak - Ambient temp sensor and rear diff temp sensor offline, bad grounding - Broken arm rest clip on driver side door - Driver rear wheel seems to slow leak (even though brand new, and asked the shop to take care of it) - TPMS not functioning Some pics and video: https://www.facebook.com/marketplace...22843431527871 https://m.facebook.com/marketplace/i...22843431527871
#2 |
Member#: 494268
![]() $11,500!
Pictures: ![]() ![]() ![]() ![]() Videos: https://thingstead.s3.us-east-1.amaz...le/driving.mp4 https://thingstead.s3.us-east-1.amaz...ale/tunnel.mp4 |
