Welcome to the North American Subaru Impreza Owners Club Friday December 4, 2020
Old 02-17-2019, 09:45 AM   #926
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Originally Posted by ryansport22 View Post
Big thanks to the great guys at Surgeline for the awesome tune up and dealing with my weird autocross specific setup.
[IMG]https://i.imgur.com/GMpi5xF.jpg
Seeing that XP class, have a build thread?
Old 02-17-2019, 04:49 PM   #927
ryansport22
Member#: 157775
2006 WRX
No recent build thread, I was thinking about making one this year though. I'll be at the packwood tour this year if your in the northwest. See if I can hang with the big boys.
ryansport22 is offline   Reply With Quote
Old 02-19-2019, 04:23 PM   #928
Homemade WRX
Member#: 33782
96 3MI Racing
Yeah, I'm in North Carolina, so pretty much opposite corner from you.
Old 02-20-2019, 06:36 PM   #929
ryansport22
Member#: 157775
2006 WRX
Bit of an update to a very old build thread. Ill try to keep it a bit more up to date this year.
https://www.rs25.com/forums/f145/115...roject-28.html
Trying to get competitive with cars like speedyhams and the where to race Porsche but I think I'm still a bit behind.
Old 02-20-2019, 10:24 PM   #930
Homemade WRX
Member#: 33782
96 3MI Racing
I need to get back over to RS25.com more often. Sean's car is pretty stupid light.
Old 02-24-2019, 02:46 AM   #931
JerseyKid
Member#: 135901
2017 STi
Crystal White Pearl
Facility: EFI Logics - Calvin Dotson
Type of Dyno: Mustang
Baseline #'s: ~230ish on a stock VA STi
Boost: 19 psi
Fuel: 93 octane
Target AFR: 11.2
SAE Corrections: CORRECTED
Peak HP: 290
Peak Torque 324
2017 STi - 11,000 Miles
Stock Motor / Trans / Clutch - 93 octane ONLY
Mods:
Cobb SF with Airbox
MAP Performance ELH
Cobb AP V3
Cobb Catted Downpipe
Cobb Catback
Cobb 1050x Injectors
Cobb FPR Kit
Cobb EBCS
ETS Top Mount
DW 300c Fuel Pump
Socal Porting TGV Deletes
IAG 3mm Phenolic Spacers
IAG Street AOS
Perrin Inlet
GDT Number Four Cylinder Coolant Re-route Kit
KS Tech Airpump Block Off Plates
NGK Iridium LFR7AIX ( One step colder at .28 )
OEM BPV Crush Mod
https://i.imgur.com/lDynfz8.jpg
JerseyKid is offline   Reply With Quote
Old 03-03-2019, 07:15 PM   #932
mgus773
Member#: 495113
2017 WRX Limited
https://i.imgur.com/Iy3XfIW.jpg
2017 WRX Limited
Cobb AP
BigSF
Grimmspeed EBCS
Invidia Catless J Pipe
R400
mgus773 is offline   Reply With Quote
Old 03-04-2019, 11:41 AM   #933
Superchargedk20
Member#: 466477
2018 STI
Dyno : dynopack
Mods : borla catback, cobb catted dp, mishimotoFMIC, mishimoto intake, deatschwerks fuel pump, Ngk 1 step colder plugs
320 whp 348 wtq
Superchargedk20 is offline   Reply With Quote
Old 03-13-2019, 04:03 PM   #934
Kbubb
Member#: 479790
So my car makes 480 whp according to procom racing with a stock location turbo 440 xt turbine upgrade 10 hot side motor bottom end is built with bc cams all supportings mods and a front mount how is this possible with such a small flowing turbo can the numbers be that high and wrong ?
Kbubb is offline   Reply With Quote
Old 03-18-2019, 05:28 PM   #935
JerseyKid
Member#: 135901
2017 STi
Crystal White Pearl
Knowing a few people who got dynoed there - it seems their dyno reads really high. Local kid to me made 360tq on 100% stock fuel on a 2018 STi. Mods were inlet , intake, and a turboback. No EBCS, No pump, no injectors, literally no fuel added at all.
My car is listed a few posts above .... made 325 tq.
Old 03-19-2019, 07:19 PM   #936
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
Facility: Fast Performance, Huntsville, Alabama
Tuner: Ed Hawkins
Type of Dyno: Dynocom
Baseline #'s: 240hp
Boost: 20psi
Fuel:*e85
Target AFR: 11.7
Peak HP:*435
Peak Torque:*425
2011 sti
Mods,
Iag closed deck stage 2 block
2200cc id injectors
Fmic
450lph fuel pump
Aem map sensor
3 port bcs
5858 turbo rotated
70mm I take
Aeromotive fpr
Car would have made alot more but the maf sensor volts were getting high at 4.9 volts. Had to stop at 21 psi.
fastblueufo is offline   Reply With Quote
Old 03-20-2019, 07:44 PM   #937
fastblueufo
Member#: 212154
02 billet crank
Tuner: Ed Hawkins
Baseline #'s: 240hp
Boost: 24psi
Fuel: e85
Target AFR: 11.4
Peak HP:*525
Peak Torque:*490
Cobb Speed Density
Mods
Fp black
Id 1300cc
Fmic
3 port bcs
450lph fuel pump
Etc
Etc
This car would easily make close to 600hp. Customer wanted a setup to do over 500hp with a conservative tune. Well he got exactly that.
Old 03-20-2019, 10:08 PM   #938
Spoolinva
Member#: 268071
2011 STI SWP
2011 Sti w/ 135k on the clock
Tuned at Moore Automotive in Fairfax Va
On 93 pump, about 50 degrees outside
321hp 385lbs @21psi
Tomei UEL header & UP
Invidia catless Dp
Cosworth short ram intake
Perrin turbo inlet
Iag fuel rails and lines
Iag TVG Deletes
Grimmspeed TMIC & y pipe
Grimmspeed 3port EBCS
GFB full recirculating
Air pump delete
3mm phenolic spacers
Iag AOS
Aeromotive FPR
Cobb AP3
Car is all factory unless listed above. Have a picture of the graph but can't figure a way to up load it. Sorry
Spoolinva is offline   Reply With Quote
Old 03-21-2019, 10:44 AM   #939
WarWagonPA
Member#: 12846
Facility: The Shop CT-Tuned by Mikey Botti
Boost: 21 psi
Fuel: 93 octane
Peak HP: 340
Peak Torque 332
2018 WRX - 6500 Miles
Mods:
Cobb SF with Airbox
Killer B IWG Header
Cobb AP V3
PRL Catted J and Mid Pipes
PRL FMIC
Grimmspeed EBCS
PRL TGV and EGR Deletes
XR FP Blue
Turbosmart IW75 Internal Wastegate with appropriate springs
Injen Catback
Cobb AOS
WarWagonPA is offline   Reply With Quote
Old 04-03-2019, 07:01 PM   #940
Sboarderk03
Member#: 465407
Figured I'd get in on this now that I have figured out how to post pictures:
Car: 2005 STI
Boost: 23-24lbs
Fuel: 93
Mileage: chassis-115k block-18k
Block: built
Peak WHP: 368
Peak WTQ: 375
Mods:
killer b pan, pick up and vband el headers w/ ewg up pipe
Blouch dom 2.5xt, AP hard inlet, kstech intake and heat shield
Process West tmic, Perrin pulley,
Tial ewg 38mm, Invidia catless dp, Invidia N1 race exhaust
Walbro 400lph pump wired, ID 1000, Perrin rails/ lines
Moroso catch can, Mishimoto radiator
Car runs like a top and will make more power if I upgrade injectors, go e85 and or speed density just don't feel the need to right now.
https://i.imgur.com/3bKfbQNr.jpg
https://i.imgur.com/70Bqtmhr.jpg
https://i.imgur.com/nAnqHf6r.jpg
Sboarderk03 is offline   Reply With Quote
Old 04-04-2019, 06:49 PM   #941
CrowleyS
Member#: 460860
2003 WRX
https://i.imgur.com/3mk6a3x.jpg
Car: 2003 WRX
Facility: APM Chicago
Boost: Unknown ~15
Fuel: 93
Mileage: Chassis-157k | Block-7k
Block: Stock EJ20
Peak WHP: 224
Peak WTQ: 213
Mods:
-K&N Short Intake
-Perrin Turbo Inlet Hose
-Mishimoto Intercooler Y-Pipe
-STI Intercooler
-GFB Blowoff Valve
-GT-Spec UEL Header
-Grimmspeed Up-pipe
-Tial 44mm External Wastegate
-Brullen 3" Turboback Exhaust
-DW300 Fuel Pump
CrowleyS is offline   Reply With Quote
Old 04-12-2019, 04:52 AM   #942
scrabby
Member#: 115308
'13 NeighborAnnoyer
Car: 2013 WRX
Facility: Mofab, Denver CO
Dyno: Dynojet
Fuel: 91/E85
Peak HP/TQ (91): 280/325
Peak HP/TQ (E85): 324/394
Cobb Flex Fuel
Cobb SF intake
Cobb TBE w/cat
ID1000 injectors
DW300 fuel pump
Grimmspeed EBCS
Process West TMIC
Stock block
Stock VF52
Stock clutch / gears
scrabby is offline   Reply With Quote
Old 04-30-2019, 03:06 PM   #943
SuddenLos
Member#: 482373
2017 Wrx
Originally Posted by Chigliakus View Post
At FIS last friday.
Cobb catted dp, Borla Hush cat-back, AP Stg2 map 1.20 93 octane.
What year? What model?
SuddenLos is offline   Reply With Quote
Old 05-02-2019, 04:34 PM   #944
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Facility: SDR Performance
Tuner: jaz TUNING
Boost: 26 psi
Fuel:E85
Target AFR: 12:1 (gas referenced)
SAE Corrections: CORRECTED (unforgiving calibration)
Peak HP: 367
Peak Torque 367
2005 STi - 41k Miles
Manley A/B drop-ins and head studs on new short block
EFR 6758, ETS TMIC, 3" TBE
Unforgiving power @ 50 and weight...
DYNOmite Dyno at Edge Autosports in Denver, CO:
yamahaSHO is offline   Reply With Quote
Old 05-05-2019, 05:53 PM   #945
mgus773
Member#: 495113
2017 WRX Limited
2017 WRX Limited
Cobb AP
BigSF
Grimmspeed EBCS
R400
updated with Cobb Flex Fuel kit and TGV/EGR deletes
https://imgur.com/a/tKhVmdT
Old 05-05-2019, 05:56 PM   #946
mgus773
Member#: 495113
2017 WRX Limited
Old 05-07-2019, 09:51 PM   #947
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Facility: Boost Controlled Performance
Type of Dyno: Dynojet
Baseline #'s: N/A - 220whp vDyno
Peak HP: 349
Peak Torque: 317
Fuel: E78
Peak HP: 282
Peak Torque: 271
Fuel: 93 Octane
2017 WRX - 12,500 Miles
Engine Mods:
COBB Accessport
Grimmspeed J-Pipe
Grimmspeed 3-port EBCS
Grimmspeed Intake
Grimmspeed TMIC
Grimmspeed Charge Pipe
PRL TGV/EGR Delete Kit
COBB Flex Fuel
DeatschWerks DW65c Fuel Pump
https://i.imgur.com/P7tbeOm.jpg
gn4rwhals is offline   Reply With Quote
Old 05-10-2019, 11:10 PM   #948
danividi
Member#: 484789
Default Post your Dyno Plot and Mods, see format inside.
2018 WRX
Cobb Accesport
Grimspeed J pipe
Corsa catback
Perrin TGV delete
Grimspeed EBCS
EGR delete
Tune done by Fastech in Louisville TN on DynoDynamics
287 HP
329 FT/LB
Cant seem to be able to post pictures not sure why.
danividi is offline   Reply With Quote
Old 05-11-2019, 12:40 PM   #949
danividi
Member#: 484789
Pics included
Old 05-11-2019, 12:41 PM   #950
danividi
Member#: 484789
Originally Posted by danividi View Post
2018 WRX
Cobb Accesport
Grimspeed J pipe
Corsa catback
Perrin TGV delete
Grimspeed EBCS
EGR delete
287 HP
329 FT/LB
Pictures are up
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-03-2016 12:43 AM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 11:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 03:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 03:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 06:40 PM
