04-09-2021, 11:27 PM | #1 |
Member#: 237190
South East
Vehicle:2003 Matte White Wrx 2006 WRB STi 2007 SWP STi |
Fuel Pressure Loss Help!
Hey guys been tackling this for a few months now and can't figure this out for the life of me. Basically when I get into boost my fuel pressure drops instead of rises. Base pressure is set at 45psi and I'm only on my 2nd or 3rd revision at 20psi and fuel pressure drops to 25psi only towards red line. Daily driving everything is fine and fp lingers in the 45ish range. My injectors shouldn't be hitting over 100%idc but are compensating for the lack of fuel pressure. If I'm not mistaken they should be around 60%idc if I'm not mistaken.
mods: walbro 450 pump (274) new less than 800 miles id1300 recently sent to ID to be cleaned and flow tested Fuel Labs 6 micron inline filter with new filter iag rails and fuel lines fore innovations t2i fpr installed just a few days ago (fuel labs Fpr for sale with gauge btw lol) cobb flex fuel kit cobb fuel pressure sensor omni 3 bar map sensor johnson tuning iat sensor bcp x500+ turbo el header up pipe full catless exhaust manley htuff rods wisco pistons stage 1 bc racing cams and valves i know there are a few other threads like this but no one ever posted if they solved it or not.
04-10-2021, 11:28 AM | #2 |
Member#: 469585
W. Canada
Vehicle:2009 STi White |
How is that pump wired?
04-10-2021, 11:51 PM | #3 |
Member#: 237190
South East
hard wired...it happens when wiring is oem wired or hard wired pump
04-12-2021, 12:45 PM | #4 |
Member#: 469585
W. Canada
You'll need to go through the fuel system front the back. There can be several possibilities.
1) The pump is NFG. I know it's new, but stranger things have happened. 2) There is a restriction somewhere between the pump outlet and the FPR. At low demands the restriction has a negligible effect, but once demand increases the restriction becomes more apparent. A common restriction would be a clogged fuel filter. 3) The pump inlet is restricted. I had the exact issue on a 2005 Ford Focus. The car would run fine under low loads light to light, but the second you put any demand on it, the engine would feel like it hit a soft rev limiter. Eventually it got bad enough that even low load started showing issues. When scanning fuel pressure you could see it fall off as the demand for fuel flow increased. First thing I did was change the fuel filter, which helped, but didn't completely solve the issue. I then went to replace the pump, but when I got it out of the tank I found the suction sock was clogged with sludge from the bottom of the fuel tank. I ended up cleaning the tank and replacing the pump and sock which solved the issue. 4) The FPR may be bad. Does you fuel pressure track vacuum like it should? What I mean by that is, if vacuum is reading -10PSI does the fuel pressure = Base - 10PSI? Even if it does, there could be an issue in the regulator that only manifests on the boost side of things. 5) Fuel vaporization, but this generally only happens with higher fuel temperatures and with pumps that are running in the upper end of their rated flow capacity. The hot fuel combined with high suction levels at the pump inlet cause the fuel to vaporize inside the pump housing. You're going to have to systematically eliminate components and scenarios. Start with the free things like ensuring there aren't any restrictions in the system on both the pressure and suction side, even if it means pulling the system apart. Then move to looking at individual components. |
04-13-2021, 12:00 AM | #5 |
Member#: 237190
South East
That makes sense. I just order a new fuel sock. This is my 4th, maybe 5th, fuel pump testing the issue due to the possibility that it was a "bad" pump out the box. Also this is my 3rd fuel pressure regulator and 3rd brand of regulator. After changing the regulator my IDC has gone down but FP still drops just as bad. My bet after reading what you said it could be a possibility my sock is clogged. Other than the hard lines from the firewall to the tank that's the only other oem part of the fuel system left I haven't replaced.
04-14-2021, 11:55 AM | #6 |
Member#: 469585
W. Canada
Please report back when you figure it out. I would like to know.
Also check that you're getting a good vac/boost reference to you FPR. Good luck. |
04-14-2021, 10:09 PM | #7 |
Member#: 237190
South East
I for sure will. I hate it when people don't update their problem threads.
04-23-2021, 01:23 AM | #8 |
Member#: 237190
South East
Fuel sock did nothing. Going to get vac leak test
05-05-2021, 09:13 AM | #9 |
Member#: 523885
Vehicle:2000 Legacy Red |
What kind of wire used to wire the pump? That pump needs a lot of power when running full and stock wiring is really bad for it. We had one Forester on a dyno that had same pump and stock controller and it acts quite same when it gets to boost.
05-05-2021, 06:44 PM | #10 |
Member#: 237190
South East
Hmm good question. It's a fairly old kit I've been running for years. Maybe it's finally showing its age? I'm out of town for a bit but when I get back I'll check on that and a vac leak test
05-14-2021, 12:43 PM | #11 |
Member#: 50902
RMIC
Vehicle:98 $$$ Green |
As others have stated this sounds like a wiring issue or possible dying pump, even if it's new. That pump draws a lot of amperage and needs a decent gauge wire if you are hard-wiring all the way from the engine bay to the tank. Even with good wiring there will be voltage drop due to the distance. If the pump is not seeing enough amperage it will cause it to prematurely die, ask me how I know. A well placed and designed surge tank is the best way to go in the long run.
05-20-2021, 07:37 PM | #12 | |
Member#: 237190
South East
05-20-2021, 08:40 PM | #13 |
Member#: 469091
Replace the fuel filter.. The sock that is on the pump is NOT the filter. The filter is built into the fuel pump assembly, but can be replaced ( the lower bucket )
Good luck! |
05-26-2021, 10:26 PM | #14 |
Member#: 237190
South East
Thank you but I've already done that recently. I do not have the in tank filter. I have a inline race filter .
06-23-2021, 04:43 PM | #15 |
Member#: 524861
I’m having the same issue and running the same parts. I replaced my pump and it didn’t do anything. FPR is my guess. Since you’re dropping fuel pressure at WOT it seems that there’s something wrong with the regulator since it should be a raising fuel pressure 1:1 with boost.
07-17-2021, 03:31 PM | #16 | |
Member#: 237190
South East
07-17-2021, 05:45 PM | #17 | |
Member#: 524861
08-10-2021, 08:16 PM | #18 |
Member#: 254372
Assuming you are speed density. Did this issue start as a new build or did it develop?
If its a new build and SD on a AP3, it could be hitting the max allowed VE on the MAF table. COBB SD for whatever reason still references the MAF table which oddly has a very low VE limit. Bumping that up might solve your issue. |
09-23-2021, 12:25 PM | #19 | |
Member#: 492858
Vehicle:2011 JDM Impreza STi Grey |
Similar issue
