03-29-2013, 01:14 AM | #26 | |
Member#: 42048
BAIC
Vehicle:03 WRX Wagon Sonic Yellow |
I can usually get my fobs to program if they aren't being super flaky during programming mode, and when they work, they work fine. However, most of the time, the LED stays on either halway dim or full bright after pushing one of the buttons and I end up just button mashing for a while. If I can push one of the buttons 8 times without the LED acting weird, then it will start working but after a few minutes, it will require a bunch of button mashing to work again. It's super frustrating which is why I just give up every time. Pushing a button 8 times is what you're supposed to do to reinitialize the fob to the car after replacing the fob batteries. I've tried new batteries in the fobs, and a new control unit in the car, but the fobs are both still flaky and both started acting weird at the same time. I couldn't believe replacing the control unit and remarrying the fobs to the car didn't fix it! How much? This would work with the locks and everything?
03-07-2014, 09:28 PM | #27 |
Member#: 99961
Vehicle:03 Super Obnoxious Wrx. A rare blue one. |
03-25-2014, 12:06 PM | #28 |
Member#: 149383
NWIC
Vehicle:2002 RS BRP |
Old thread with a recent post!
I am running into the same intermittent issue--when I press Unlock/Disarm the light will stay lit (and sometimes dim). I've even tried to get the alarm into Valet Mode so I can access my car without tripping the alarm, but that requires a fully functioning fob. While not a solution, if I press the button enough times it will eventually operate normally. However, it may require me to push the button 5 times or 50 times. Simply, is there a solution or is it time for a new fob? |
03-26-2014, 12:38 AM | #29 |
Member#: 42048
BAIC
Both my fobs started doing it at the same time and changing the controller under the dash didn't fix it. I gave up and still don't have keyless entry. :|
04-27-2014, 12:21 AM | #30 |
Member#: 385737
Vehicle:2003 WRX Sedan PSM |
I'm having the same problem, 2003 WRX, the LED stays on dim and I've notice as soon as the red LED messes up, with that constant dim light, the remote 'un-marries' itself from the car and will work again after 6 button presses (the procedure for marrying it in my car). I figured it was losing proper connection to the battery (brand new) so I took out the circuit, having read about people finding solder connections on the battery housing broken. I couldn't find any bad solder connections, but when the LED would come on dim, lightly torquing the circuit board with my fingers would make it work right with almost no pressure, lighting fully after pressing buttons. I tried holding the battery down too, but it didn't seem to change much, though like I said the connections looked solid. This leads me to believe there may be a faulty component on the circuit board, so I might just have to buy a new one
04-27-2014, 04:37 AM | #31 |
Member#: 338666
Vehicle:2022 Crosstrek Ltd. Magnetite Gray |
04-28-2014, 10:43 AM | #32 |
Member#: 385737
It's definitely a worn part on the remote inside, and ive had mine working for 2 days straight now *knock on wood*. Like I said I spent all of Saturday fiddling with the circuit inside. I looked for broken, weak, and cold solder connections, but the circuit looked fine on every connection. Like I said in my previous post the circuit would work when I torqued the board one way or another, but malfunction on occasion if I just pressed the button not holding it some special way.
So, I went on to put spacers in random places where the circuit was held down by the cover (under the small screws, where the little + shaped supports are on the top, etc...) it always worked for a few times leaving the car and coming back, but always malfunctioned again after a few times (keeping the fob in my pocket to simulate going to work, running errands, etc...) this was frustrating to say the least because every time I thought I fixed it, that dim constant light would come on meaning it just malfunctioned again and unmarried itself from my car. So this is the point where I was writing my first post, having almost given up. HERE'S HOW I FINALLY FIXED MINE Sunday morning I had it apart one last time, and it had that dim constant red LED again. I started prodding at components with the plastic tip of a led pencil to see if any consistently made the dim light turn off. Battery connections: nothing consistent, the LED itself: didn't do anything, random other components: nothing that pushing on the board itself wouldn't have caused anyway. Then I pushed on the large rectangular black Alpine chip (largest on the board) and it turned off, and it seemed to do so very consistently. So I took a random plastic piece out of the bottom of my toolbox, dusted it off and put it on top of that chip, then put the cover on making sure the plastic piece was thick enough that it became wedged between the chip and the cover, in turn pushing the chip once the cover was screwed in place. I could see the cover bend slightly as I tightened the screws so I knew the piece was wedged there keeping pressure on the chip. Since doing this I have yet to see the dim light, and it has been working consistently for 2 full days out and about the town ( I've probably gone at least 30 places and left my car and come back) and I would know if it malfunctioned even once since this would unmarry it from my car requiring me to press it 6 times before it would work. Apologies for the excessively long post, but I'm hoping this will help save someone the time it takes to troubleshoot a finicky circuit |
09-15-2019, 04:21 PM | #33 | |
Member#: 495957
Fix really works! pushing on Alpine chip in keyfob 2004 STI impreza
Thank you so much for sharing your trouble shooting!
I went through the tedious process of replacing battery, repairing the remote to car, inspecting remote circuit board both sides. The ONLY to fix it was adding a small cardboard wedge on top of the alpine chip on the remote circuit board. Searching for the dim light remote found this thread. Just in-case, here are the EXACT repairing instructions as well. 1. Open the drivers door, sit in drivers seat. 2. Close drivers door. 3. Put key in ignition and cycle to on 10 times within 15 seconds. (DO NOT remove till Step 7!). 4. Horn beeps once. 5. Within 45 seconds open drivers door, close drivers door, push any button on the fob. Horn beeps twice. 6. Repeat #5 for any other fobs up to four. 7. Remove key from ignition. Horn beeps three times. Thank you again. It has been a few years since posted. -Monterey Quote:
09-15-2019, 05:00 PM | #34 | |
Member#: 453087
03-30-2021, 07:28 PM | #35 | |
Member#: 33999
NWIC
Vehicle:2005 9-2x Aero MT Black |
I don't think I've posted here in about 15 years. Weird |
Keyless entry horn not working?? | GTR STI | Car Audio, Video & Security | 14 | 01-15-2022 03:07 PM |
FS: 2003 WRX Keyless Entry Unit | lettucemanatee | Interior/Dressup/Audio & Security | 20 | 01-13-2012 02:54 PM |
Q: 2005 WRX Keyless Entry Remote work on my 2002 WRX? | Xymox | Car Audio, Video & Security | 12 | 06-16-2008 04:55 PM |
dome light, map light, keyless entry will not work | Samirr76 | Electrical & Lighting | 4 | 10-09-2003 08:41 AM |
Keyless entry does not work when WRX is running?? | burton13 | Car Audio, Video & Security | 9 | 10-28-2002 11:51 AM |
