Welcome to the North American Subaru Impreza Owners Club Tuesday December 10, 2019
Old 12-13-2017, 11:03 AM   #1
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
Default 2008 STi - Rotate All The Things
What's up guys? I am new to the STi scene but not new to modding cars or driving Subarus by any means. A little bit of history, I owned a 2005 WRX back in 2007 but it didn't last long as it was totaled after less than 6 months and I also owned a 2016 Impreza hatch for a year that is now my wife's daily driver. Aside from those I have owned 2x Acura RSX-S(1 Turbo, 1 All motor), a 99 Mustang GT(full bolt ons), a Neon SRT-4(450whp), a Yamaha R6(full bolt ons), and my current toy car, a 1999 Corvette(single turbo, meth injection, roll cage, 950 whp).
I bought the STi(57K miles) as a daily when my wife took over my 2016 Impreza and it came with what is essentially all the Stage 2 bolt ons and a Surgeline Protune making 310/345, according to the previous/original owner.
Updated Parts List:
Engine
  • IAG Stage 2 Closed Deck Shortblock
  • Manley Forged 100mm Pistons
  • IAG H Beam Rods
  • ARP2000 Rod Bolts
  • ACL Bearings
  • Closed Deck
  • IAG Built Heads
  • BC Valvesprings
  • GSC +1MM Intake and Exhaust Valves
  • Valve Job
  • Vapor Hone
  • ATI Super Damper
  • Cobb Accessport V3
  • Cobb Oil Cap
  • Cobb 4 Bar Map Sensor
  • Grimmspeed EBCS
  • IAG Competition AOS
  • IWire Engine Harness
  • Killer B Oil Pan
  • Killer B Oil Pickup
  • Killer B Oil Baffle
  • KSTech 19mm Phenolic Spacers
  • KSTech 1/2" Throttle Body Spacer
  • Koyo Radiator
  • Mach V Header Heatshield
  • Mach V Air Pump Delete
  • Magnaflow 3" Catback(Extra 4" Vibrant Race Muffler Welded In)
  • MAPerformance EL Header
  • Perrin Radiator Shroud
  • TIC Idler Pulleys
  • Torque Solution TGV Deletes
  • Torque Solutions Motor Mounts
  • Visconti Tuning Wideband Harness(Rear o2)
Fuel Setup
  • AEM 320lph E85 Fuel Pump
  • Cobb Flex Fuel Sensor
  • Cobb Fuel Pressure Sensor
  • ETS 3Ē FMIC
  • ID1300
  • Radium Auto FPR
Turbo Setup
  • Perrin Rotated GTX3076R Kit
  • Garrett GT3076 .82 Turbine Housing
  • 3" Vibrant GESI UHO Catalytic Converter Welded In, V-Band Connections with removable test pipe
  • Tial MV-R 44mm EWG
  • Tial Q BOV
Transmission/Differential
  • Cobb Short Shifter
  • Comp Stage 4 Sprung 6 Puck Clutch
  • Comp Clutch Steel Flywheel
  • Goodridge Clutch Line
  • Group N Transmission Mount
  • Kartboy Shifter Bushings
  • TIC Trans Crossmember Bushings
  • Whiteline Differential Inserts
Suspension/Brakes
  • ARP Extended Wheel Studs
  • Cusco Center Floor Brace
  • Cusco Power Steering Rack Brace
  • Cusco Rear Lower Control Arms
  • Cusco Rear Member Power Brace
  • Cusco Rear Side Member Power Brace
  • Cusco Type 2 Lower Arm Bar
  • Enkei NT03+M 18x9.5 +40
  • Hankook RS4 265/35/18
  • Hawk HPS Brake Pads(Street)
  • Carbotech AX6 Brake Pads(Track)
  • ITS Pedal Support Bracket
  • Motorsports Tech Custom 10mm Wheel Spacers(Hub rings machined into them, hub centric to car and wheel)
  • Feal 441 Coilovers
  • Kartboy Endlinks
  • Perrin Brake Master Cylinder Brace
  • P&L High Pressure PS Hose
  • Redhorse Stainless Braided Lower Pressure PS Hose
  • Stoptech Slotted Rotors
  • Stoptech Stainless Braided Brake Lines
  • Soul Function Trunk Kit
  • Whiteline Anti Lift Kit
  • Whiteline Roll Center Kit
  • Whiteline Front Control Arm Bushings
  • Whiteline Power Steering Rack Bushings
  • Whiteline Rear Subframe Inserts
  • Whiteline Sway Bars Front and Rear
  • Whiteline Rear Sway Reinforcement
Interior/Exterior:
  • 2011-2014 Facelift
  • AEM X Series UEGO Wideband
  • AEM Oil Temp Gauge
  • AEM Oil Pressure Gauge
  • Aeroflow Dynamics Type 4 Splitter
  • Auto-Blip Rev Match Downshift Module
  • Billet Workz Teardrop Shift Knob(Black)
  • Billet Workz Reverse Lock Out(Red)
  • Billet Workz Arctic Camo Shift Boot
  • Billet Workz Arctic Camo Ebrake Boot
  • Billet Workz Ebrake Button(Red)
  • Custom Vinyl Tail light Red Outs
  • Dialed Mounts Accessport Defroster Mount
  • FastWRX Bumper Quick Release
  • FastWRX STI License Plate Trim Piece
  • Grimmspeed License Plate Relocation
  • JDMFY STI Grill Badge(Black)
  • JDMFY STI Trunk Badge(Black)
  • RallyArmour Mud Flaps
  • R205 Fender Badges
  • SMY Clustermaker Dual Gauge Pod
  • SolidMods Vent Pod
  • Sony XAV-AX100 Head Unit w/ Apple Car Play
  • "STi Style" Front Lip
  • Painted OEM Headlight Shrouds/High Beam Buckets
  • Morimoto X-VF 7440 Reverse Lights
I didn't get a chance to take any pics before a tractor trailer backed into me at a redlight in my own office complex. At that point I decided I would do the facelift since I prefer the 2011-2014 look anyways.
Turpid Porpoise is offline   Reply With Quote
Old 12-18-2017, 10:50 AM   #2
Turpid Porpoise
Member#: 476573
Finally found some time to lift the rear and pop the subframe inserts in and I must say that it is amazing how much of a difference bushings/bushing inserts make to this car. Since purchasing the car I've added the Kartboy shifter bushings, Whiteline diff inserts and subframe inserts and the car feels much more solid. I can feel the road better and the car inspires much more confidence when throwing it around corners. Now I would like to try to steering rack bushings and control arm bushings to finish out the bushings in the suspension.
Old 12-19-2017, 11:17 AM   #3
maperformance
Member#: 141043
2011 STI
black af
Clean rig you got there! Let me know how the header works out!
-Ian
maperformance is offline   Reply With Quote
Old 08-22-2018, 09:04 AM   #4
SirBrass
Member#: 207263
2019 WRX Limited
I think your car can take the new STI's quicker steering rack as well. I forget the ratio for the 08 STIs, but the new ones are at 13.3::1, and still hydraulic, so it should be more or less a direct swap.
After the BRZ came out, Subaru really tightened things up with the WRX and STI suspensions.
SirBrass is offline   Reply With Quote
Old 08-22-2018, 09:08 AM   #5
Turpid Porpoise
Member#: 476573
That is in my plans for next year. Ill be doing the VA steering rack, whiteline rack bushings, cusco rack brace and a bump steer kit all around the same time. I'll probably be due to have my coilovers rebuilt around the same time so I'll be getting the road race valving and much higher rate springs.
Old 12-20-2017, 08:19 AM   #6
Turpid Porpoise
Member#: 476573
Thanks Ian. I'm ordering my adjustable FPR and Cobb fuel pressure sensor today so that I can get it on the dyno in the next month and then I'll be going to lay down a baseline before I install the header and get tuned. Still not sure if I am going to go through Cleo or JR @ IAG.
Old 01-11-2018, 09:12 AM   #7
Turpid Porpoise
Member#: 476573
Wasn't able to get a baseline put down before installing the header but I will still post results of the dyno tune.
I got the MAPerformance EL header, Mach V header heatshield and Radium Auto FPR w/ Cobb fuel pressure sensor installed last night. I ended up making the fuel feed hose out of the Redhorse Performance lines and fittings I had laying around since the fittings that came in the Radium kit would not stop leaking. The header and heatshield went on very easily and the fitment was perfect.
Here are my thoughts on all of the parts I just installed thus far:
MAPerformance Header - Very easy install, I had absolutely no fitment issues. The header did eliminate about 90% of the boxer rumble but I don't mind because it also seems quieter at idle and cruising which was one of the secondary goals when I bought the header. One note, if you are waiting to do an oil pick up install, do it before you install a MAPerformance header as you will have to remove the header to remove the oil pan anyways. I have not been tuned yet so I haven't gone WOT but I have noticed a bit more lag but nothing that I would say is a night and day difference.
Radium FPR - Install was very easy except for getting the 5/16 fuel line disconnect tool inside the OEM fuel line connectors. The kit was sold as the STI stumble fix but it came with the wrong orifice installed, no big deal as they include all 3 orifice so swapping over was easy. Fuel pressure is stable and I have not witnessed and dips or spikes. Also, I did have a noticeable stumble around 3100 rpm which is no longer there. Overall, I'd say it was a successful install.
Mach V Heatshield - Not much to say here. High quality piece and bolted right in place of the old plastic heatshield after it fell apart in my hands. Looks like it will do it's job well.
Old 09-26-2018, 03:14 PM   #8
Brock31
Member#: 128115
2008 STi Hatch OBP
enginuity is cool
Did you decide to install the control arm bushings and steering rack bushings?
I've owned my '08 for about a year and a half and the stumble is annoying. Does this FPR really eliminate it? Is it a plug and play deal or do you have to adjust for the new FPR tuning-wise to fix the stumble?
Brock31 is offline   Reply With Quote
Old 09-27-2018, 08:09 AM   #9
Turpid Porpoise
Member#: 476573
I haven't done the control arm and rack bushings yet but I may have Mach V toss the rack bushings in while the motor is out.
It is highly recommended to get a tune after replacing the FPR but I drove for a bit without a tune with no negative results. After my tune it completely got rid of the stumble on my car. If you are going to run it without a tune(which I don't recommend for an extended period of time) just make sure you get the base fuel pressure set exactly where it should be.
Old 10-14-2018, 08:23 PM   #10
IrishNYer
Member#: 492645
08 WRX
Shhhhh....
Hey everyone,
New to this site and the Subaru scene although I've always had an infatuation with Subarus. Now I am the proud owner after waiting and letting countless WRX's slip through my fingers. I just picked up an 08 WRX hatch. 104,xxx on it. It does have some body work needed to be done, but motor seems sound and largely entact! The car has got as some mods, mostly dress up and I am looking to mod it where it counts. First thing I need is new fender flares since the old ones on the car warped from the elements. Any tips would be greatly appreciated.
IrishNYer is offline   Reply With Quote
Old 10-14-2018, 08:24 PM   #11
IrishNYer
Member#: 492645
08 WRX
Shhhhh....
The fender flares are ugly and I need to replace them, but after that the money goes into the motor!
Old 01-15-2018, 08:35 AM   #12
Turpid Porpoise
Member#: 476573
I have to say... after doing the turbo inlet and fuel injectors on this thing I am much more fond of working on my Corvette. That said, I made a bit more progress this weekend(although it was not painless).
I have a tune with Cleo @ IAG on 1/17/18 so I spent my weekend installing the FIC1000 injectors which really werent all that bad. I did not have to remove the drivers TGV motor to remove the GBOD and I did not reinstall the GBOD after finishing everything up. The passenger side wasn't so bad but I did have to disconnect the passenger TGV motor and AVCS banjo bolt to remove the 12mm fuel line retaining bolt on the front of the head but other than that it went together easily.
While I was removing the AIR pump the electrical connector on the pump itself snapped off so I decided to do an AIR pump delete while I was in there. I also figured that if I was going to pull the intake manifold to remove the solenoids than I better buy a turbo inlet and knock that out at the same time. Removing the bolts under the intake manifold proved to be the only real PITA part of the inlet install. The biggest issue I had through this entire process was one of my air pump pipe bolts broke off in the back of the passenger head so I had to get creative with my air pump block off but here are some pics.
Engine bay all buttoned up after the FIC1000, Mishimoto Turbo Inlet and Mach V Air pump delete plates.
Little close up of the Mishimoto Inlet. Be warned, the barb provided by Mishimoto for the EBCS is too large and you will need to use 3/8" hose to slip over that barb. I wrapped the barb on the EBCS with electrical tape until it was large enough for the hose to barely slip over and then it was zip tied on both ends. Aside from that the fitment is good and the silicone looks nice and thick.
https://lh3.googleusercontent.com/F6...=w1319-h989-no
Since the passenger side GBOD supports the TMIC brace and the coolant reservoir I did not want to completely remove it but I did not want to reinstall the front bolt in case I have to get back under there anytime soon. I cut it in half and then spent some time on the belt sander smoothing out the cut edge.
Mach V Air Pump delete plate installed on drivers side port.
Here you can see the broken bolt in the upper right threaded hole and the large M10x1.0 bolt that I used to seal the air pump hole after drilling and tapping with lots of Dielectric grease to catch any metal shavings.
And here are a couple more pics of the Radium FPR setup since I haven't seen much about it on the forums or facebook.
Old 01-18-2018, 08:00 AM   #13
Turpid Porpoise
Member#: 476573
Had a good time at IAG Performance yesterday while Cleo worked his magic. Final numbers ended up at 328whp/352wtq on their Dynojet.
Old 01-22-2018, 11:42 AM   #14
Turpid Porpoise
Member#: 476573
Signed up for my first ever AutoX event at Summit Point. It's called the BSR Refrigerator bowl and they seem to be using the majority of the track so it almost seems more like a road course event than an AutoX to me.
I already have a legal helmet that I use to drag my Corvette so I decided that to be on the safe side I should make a fire extinguisher hold down just in case. I ended up chopping the legs off a Brey-Krause extinguisher mount that fit my C5 Corvette and welding it to a stick of 2"x1/4" steel flat bar which I then notched to fit around the raised areas on the passenger seat's mounting feet. It works great but I can't slide that seat any farther forward than it is or it contacts the extinguisher, I may mod it later on to fit better but I may say F it and leave it as is.
Old 02-05-2018, 12:47 PM   #15
Turpid Porpoise
Member#: 476573
Took a couple quick shots because I was early to a "work dinner" and the lighting in the garage was kinda neat. Since the last ones I've added an ABS "STi style" front lip, IAG clutch reservoir cap, IAG windshield reservoir cap, Carbotech AX6 pads for autocross. I also finally ordered an AEM 320lph fuel pump for peace of mind.
Old 02-06-2018, 10:58 PM   #16
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
IAG this IAG that, another IAG fan boi
user1029 is offline   Reply With Quote
Old 02-07-2018, 08:33 AM   #17
Turpid Porpoise
Member#: 476573
I live 30 minutes from them and nobody else makes colored billet caps to replace those garbage yellow plastic ones. Move along if you donít like it.
Old 02-07-2018, 11:35 AM   #18
baggedhawk
Member#: 344203
i like how people judge you for enjoying a brand.
It's your money spend as you'd like sir
baggedhawk is offline   Reply With Quote
Old 02-07-2018, 03:50 PM   #19
Turpid Porpoise
Member#: 476573
Thanks buddy. It's not like I even have a ton of IAG stuff.... Just the AOS, a couple of caps and I got tuned there...
That's not to say I didn't have a good experience with them because I did but it is quite a stretch to call me a "fan boi."
Edit: just noticed his profile says he has an IAG built STi lol
Old 02-07-2018, 04:09 PM   #20
user1029
Member#: 57064
2008 STi IAG built
Did you also see my IAG-built journal? I'm typing on a IAG-built laptop as we speak http://www.iwsti.com/forums/gr-membe...000-miles.html
Old 02-07-2018, 04:17 PM   #21
Turpid Porpoise
Member#: 476573
Lol I have been through about half of that read so far. I figured you were joking after I saw your profile. Beautiful car.
Old 03-05-2018, 08:37 AM   #22
Turpid Porpoise
Member#: 476573
Finally got around to giving the STi a nice wash and wax. While I was at it I installed the black R205 fender badges. I still have the RCE black springs on in these photos but the Feal 441 should be here today and installed tomorrow.
Old 08-06-2018, 08:24 AM   #23
Turpid Porpoise
Member#: 476573
Long time no update. I've updated the original post with the current mod list. These pictures show everything on the list except the ETS FMIC, GS EBCS and IAG fuel rails. Since my last post I've done 4 AutoX events and I've take 5th, DNF(broken end link), 1st and 3rd. The 1st and 3rd were against a C6Z06 and a Camaro ZL1 so I'm very happy with those results. I may have an even bigger update coming soon as I was down quite a bit on oil during the most recent change and I've been noticing a bit of smoke out the tail pipes on start up so I'm hoping it's the turbo but it may be the infamous ringlands. I'l be doing a compression and leakdown prior to installing the FMIC and EBCS to diagnose the oil loss.
Sorry for bad quality pics but I'm no photographer and these were just taken on my way into dinner.
Old 08-22-2018, 08:34 AM   #24
Turpid Porpoise
Member#: 476573
Here's a little sneak preview of what's coming up next...
Picked up a used ETS 3" FMIC kit with stainless piping on ebay and immediately got the piping powder coated wrinkle red. Also, grabbed a used Blouch 20G XTR with 10cm turbine housing and 3" inlet that has zero shaft play and spins very smooth. While I'm at it I bought IAG fuel rails, Redhorse 205 lines and fittings, Grimmspeed EBCS, APS 3" inlet and TGV deletes to install at the same time. I decided to hold off on the flex fuel kit until next year since I've already spent enough on this car for this year. Retune with updated numbers should be coming early September.
Old 08-22-2018, 08:41 AM   #25
sleepyGV7
Member#: 314360
2018 STI
CWP
half of your photos don't work and it makes me sad.
sleepyGV7 is offline   Reply With Quote
