Welcome to the North American Subaru Impreza Owners Club Friday December 13, 2019
Old 04-01-2019, 11:42 PM   #26
ThinWRX
Member#: 401876
2008 WRX
Satin White Pearl
Originally Posted by 2slofouru View Post
Stock location is one thing, but calling turbos this size stock fitment is nonsense. Not that it's an outrageous undertaking, but the impression on their site explanation leads people to believe it's not much work at all. I mean really.. "simple to install turbo" is a little sugar coated lol.
I purchased the KillerB spoolinator setup knowing there would be a decent amount of modification required, and it's explicitly stated in the description. That is one of the several the things I admire about KillerB Motorsport as a company.
Definitely, I feel the same way. They should state that there are going to be major modifications to get this "stock location" turbo to fit. The rep from FP even mentioned how their own inlet pipe was difficult to fit correctly.
ThinWRX is offline   Reply With Quote
Old 04-05-2019, 05:50 PM   #27
subaru_gc8
Member#: 29292
2004 WRX wagon
The real question to ask does it make a difference over a 3 in inlet
subaru_gc8 is offline   Reply With Quote
Old 04-06-2019, 10:00 PM   #28
ThinWRX
Member#: 401876
2008 WRX
Satin White Pearl
I really doubt it. From what I can tell the 3.3" cold side is due to the surge housing and the compressor wheel is only 2.4"... Here is where I'm at now. What do you guys think about running the inlet pinched? There is really no way around it. I could grind a little off the tgv bolt area but there isn't much metal there to begin with.
Old 04-06-2019, 11:24 PM   #29
Rickyh
Member#: 40453
i have an fp black. i couldn't get the fp inlet to fit in any way that made me happy so I just put a turbo guard turbo screen on it. i don't like the way the inlet gets squished and kinked. I even have the jdm manifold with no tgv housings and i still couldn't get it to my satisfaction.
Rickyh is offline   Reply With Quote
Old 04-07-2019, 12:57 AM   #30
bp05obxt
Member#: 459799
Fitment appears to be as good as it gets. I have seen other inlet hit on the TGVs there should be fine you can shield it with something if you a worried. A hose clamp wrapped around the inlet there would keep the TGVs from rubbing and the clamp would stay in place. Sounds silly but itís a simple guarantee that the inlet isnít rubbing.
bp05obxt is offline   Reply With Quote
Old 04-07-2019, 08:27 PM   #31
08wrx440
Member#: 261040
04 STi
About as good as it will get
I have cut about 3/4 of an inch off my inlet, in almost an angled cut to help with fitment
Still fighting coolant lines
08wrx440 is offline   Reply With Quote
Old 04-08-2019, 12:20 AM   #32
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Not horrible, but FP could have designed a better fitting inlet. It's molded to a certain shape, and that could have been designed in to keep the manifold from putting pressure on it. Space is limited, but there aren't a million intake manifold configurations for them to consider. There are several turbo inlet manufacturers, but unfortunately they have different compressor end sizes, and we don't all have the time and money to waste to try them all. :/
2slofouru is offline   Reply With Quote
Old 04-16-2019, 09:33 PM   #33
ThinWRX
Member#: 401876
2008 WRX
Satin White Pearl
Here's a little update. I removed all of the hard lines for pcv/coolant and set up some custom hoses. I used a custom line for the bpv which should work fine, but I might trim it a little. I found a few wires frayed/torn so I'll have to solder some cables and I need to figure out how to route the inlet lines. It's setup for an sti with 3 holes instead of 4 with a wrx. Fp mentioned the two solenoids were merged so I'll just have to do some reading.
Old 04-16-2019, 09:49 PM   #34
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Nice progress, that first pic was straight spaghetti!! Glad you got past the inlet. Unfortunately that's a close as we can have the inlet be with the block on one side and the intake runners on the other. Surely someone could make hard intake tube that's molded to perfectly run around the runners and still have a lip that goes around the larger turbo inlet. I'm wondering how my perrin intake will work, but I will have more flexibility with routing since it's already going to have the oem big plenum manifold and lots will be custom routed anyway.
Old 04-24-2019, 12:32 AM   #35
08wrx440
Member#: 261040
04 STi
ditching the blanket
**** it
going together with fuel system
will update things here with a guide when she is running to warn the community of the dangers xD
Jeremy
edit:
PTP Lava blanket for sale for FP black
Paypal me $75 I'll ship it to you, no safety wire included
Old 04-25-2019, 09:34 AM   #36
ThinWRX
Member#: 401876
2008 WRX
Satin White Pearl
**** it
Jeremy
edit:
Yeah, I don't have any guard or heat shield on mine. I'm keeping hoses as far away as possible and sending it.
My last issue has been a downpipe. I originally bought a grimmspeed divorced pipe with the "limited" milling on the wastegate tube, which I had been using previously. Well, now that I am going with an external wastegate a divorced pipe doesn't make sense. I measured my turbine exducer and its around 2.5", which is just a little larger than the divorced section... I ordered a used cobb downpipe next and was ignorant to the fact that the pipe tapers to a stock catback. Yeah I know I can have the end cut off and get a full 3" but it just wasn't worth my time. It will be easier to sell a pipe that hasn't been messed with.
My last choices were a CNT catted downpipe, or a hard to find (discontinued) HKS catless downpipe with 2 resonators. I called over 10 "distributors" and got the same answer from all of them. I ended up finding one in France from driftshop.com. I'm super excited to see what it will sound like with a catless system and 3 resonators total (one in my P&L catback).
Old 04-27-2019, 07:44 AM   #37
ilovedemhotrides
Member#: 326147
I too have the Fp black and was wondering if you had any bad effects of doing this??
I am wondering if it heats up too much from drawing heat from the motor right there??
Obviously speed density at this point. Love to hear back
ilovedemhotrides is offline   Reply With Quote
Old 05-03-2019, 11:08 PM   #38
Rickyh
Member#: 40453
it may be sucking in hot air but it still made 609 to the wheels. i really haven't noticed any problems
Old 05-12-2019, 08:56 PM   #39
ThinWRX
Member#: 401876
2008 WRX
Satin White Pearl
The car is up and running. It's on a base tune running ~12 psi (torqued performance tuning). Boost comes on fully by 4200rpm and its making around [email protected] and 319lbft [email protected] Injector duty cycle is only at ~54% so there is plenty of room for more power.
Old 05-12-2019, 10:02 PM   #40
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Congrats, curious to see what she does once you're ready to stretch her legs.
Old 05-12-2019, 10:28 PM   #41
08wrx440
Member#: 261040
04 STi
Wow impressive at only 12psi!!!
I have ID1300s with an aeromotive fpr, currently plumbing the fuel system
Excited to see what happens soon
Old 05-13-2019, 02:25 AM   #42
ThinWRX
Member#: 401876
2008 WRX
Satin White Pearl
I am running the same setup with IAG rails and a hardwired dw300c. Those power number are using ~e70, but I am happy for a base tune. There isn't as much tq as a vf52 maxed out, but the hp is already equal so I am excited to see it at ~20psi.
Old 05-16-2019, 06:39 PM   #43
Dontaedidwerk
Member#: 497599
Do anyone know the thread size for the coolant fittings with the fp turbo?
I dont want to run the -4an adapter that came with the turbo so I was looking for a different route
Dontaedidwerk is offline   Reply With Quote
Old 05-17-2019, 07:02 PM   #44
ThinWRX
Member#: 401876
2008 WRX
Satin White Pearl
They should be 14mmx1.5 pitch. I used a straight barb from atp turbo and one of the stock that fit. https://www.atpturbo.com/mm5/merchan...gory_Code=GOCL
Old 05-19-2019, 11:29 PM   #45
08wrx440
Member#: 261040
04 STi
Right on!!!
Should be able to get mid to upper 4s no problem
I'll be doing 93 (gas station issues) with a walbro 450 hardwire kit
Old 09-01-2019, 12:06 PM   #46
ThinWRX
Member#: 401876
2008 WRX
Satin White Pearl
Here is a small update fellas. I have the car running on 20% ethanol (trying to get to 0% ethanol/pure 91 octane). It's running about 20psi and the numbers look alright so far. Still more tuning to be done, but so far the turbo/external gate is ridiculous.
Old 09-01-2019, 01:49 PM   #47
TDagen
Member#: 163648
V9 6mt R180 Brembos
Awesome!!
Really it looks smooth even with the curvy boost plot. Wait until you add a some psi and that turbo steps into its efficiency range, it will “wake up” big time. What’s timing are you running at peak torque and at redline?
TDagen is offline   Reply With Quote
Old 09-03-2019, 06:14 AM   #48
ThinWRX
Member#: 401876
2008 WRX
Satin White Pearl
It looks like my timing at max tq (~4800rpm) is 13. The timing at max hp (~6400rpm) is 17.
Old 09-03-2019, 01:24 PM   #49
TDagen
Member#: 163648
V9 6mt R180 Brembos
Seems to be working very well, like I said nice smooth plot even with some boost oscillation.
Iirc at about 22psi and above this turbo will step into its efficiency range, and once that starts to happen you will be hard pressed to get traction in the lower gears
Old 09-03-2019, 11:46 PM   #50
subaru_gc8
Member#: 29292
2004 WRX wagon
https://www.youtube.com/watch?v=vydWdo21n14
I was wondering what the difference is between pure 91 or 91 with ethnanol?
