Welcome to the North American Subaru Impreza Owners Club Saturday December 14, 2019
Old 10-07-2019, 01:23 PM   #1
denmark1
Member#: 19378
1997 STI Type-R 555
Default Headgasket for 103mm bore ej
Hey guys
I have a engine with sleeves and 103mm pistons but i need some headgaskets for it ,
1.6mm thick
Anyone know what Can be had ?
It Got 14mm studs and is going to run pretty high boost 2-2.5bar
Thanks
Skassa
denmark1 is offline   Reply With Quote
Old 10-07-2019, 08:42 PM   #2
can250
Member#: 452601
There's a few that make 102mm gaskets but don't know about 103mm you might have to get a custom one made
can250 is offline   Reply With Quote
Old 10-08-2019, 02:36 AM   #3
denmark1
Member#: 19378
1997 STI Type-R 555
I have seen cometic have 103mm in 1.52mm thickness ,
This block have liners that have dropped a bit and there is allready 1.6mm gaskets in it , so i need 1.6mm thickness maybe more depending on what needs to be removed to get it flat again
Old 10-08-2019, 02:44 PM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
That is not how I would approach this problem. How much did they drop, and when they did did they shift or rotate any?
If it's not much I would be more inclined to deck the block back to flat.
Old 11-03-2019, 10:03 AM   #5
denmark1
Member#: 19378
1997 STI Type-R 555
The problem i have with this engine , new build in the US , shipped to Denmark ,
I have only installed the engine , had it startet to heat it up , brake-in the the lot , all new parts
Sounds great when running , i turn it of , then i Will change oil and filter as i always to after the first heat cycle ,
The first thing that comes out if the oilpan is collant , then the oil
When drained , i let it sit 15min and the loosen the drain plug and again coolent comes out , so engine out again ,
I have the engine split , and have sent the blokhalves and heads to a machineshop to pressuretest it , and all 4 darton sleeves are leaking when they are pressuretestet ,
So i Will try to see if i Can remove the liners again , reseal Them and install again
But dont know if its possible
Also there is No pistonguide holes i the liners and its a pain to take apart an assemple again ,
The crank is 82mm
Does it matter that the pistons goes deep into the holes ?
If its not a problem i Will have the holes made when the liners are installed again
Old 11-03-2019, 10:32 AM   #6
denmark1
Member#: 19378
1997 STI Type-R 555
Its a EJ22T block we belive coolent is getting in past the sleeves at the topflange were the sleeve goes into the water holes ,
Its ej25 sleeves that is used , bored to 103mm
Old 11-04-2019, 03:07 PM   #7
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
I'd machine the deck, O-ring the flange, and order up a new set of Cometics.
Then compensate camshafts for the adjusted timing.
Old 11-06-2019, 12:50 PM   #8
denmark1
Member#: 19378
1997 STI Type-R 555
Thanks , here the sleeves also leaking , so coolent gets in the oil
Old 11-07-2019, 02:16 PM   #9
Turn in Concepts
Member#: 93646
Many Track Records
Oh man. It sounds like you got a steaming pile of garbage if I may be blunt.
Old 11-09-2019, 07:07 AM   #10
denmark1
Member#: 19378
1997 STI Type-R 555
Yes looks like it
