Welcome to the North American Subaru Impreza Owners Club Wednesday April 8, 2020
Old 10-22-2019, 05:16 PM   #1
Trob
Member#: 503820
Default 2011 Wrx Transmission fork pin??
Simple? Is there a fork pin in the 5 speed that I need to pull before pulling the motor? I know the 6 speed has one. Iím looking and do not see anything. Any help?
Trob is offline   Reply With Quote
Old 10-22-2019, 06:15 PM   #2
Trob
Member#: 503820
No one??
Old 10-22-2019, 09:53 PM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
It's a push style clutch so no pin to separate the two.
I will very strongly recommend that you replace the clutch fork and the pivot ball while in there. It's standard operating procedure for us here.
Old 10-23-2019, 11:14 AM   #4
gabo_s13
Member#: 468498
2014 WRX Hatch
Like TiC said no pin, but dowels might be corroded in place. 9 times out of 10 it's a bit%& to separate the engine from trans so take your time.
gabo_s13 is offline   Reply With Quote
Old 01-28-2020, 09:10 PM   #5
Trob
Member#: 503820
Thanks. Late response but it was just stuck on the dowels. Just finished putting in the new built motor. Running great with new clutch, pivot bearing and fork.
