06-14-2005, 07:30 PM | #1 |
Member#: 53975
South East
Vehicle:2004 Forester XT Java Black Pearl |
Spark plug socket problems (not in FAQs)
I am trying to usethe 5/8" spark plug socket everyone says to use, but it is not turning the plug at all. I tried to place it on my new NGK's to see if it fit, and it doesn't! So does 5/8" not work for aftermarket plugs and i am doing something wrong with the oem plugs or what is the deal here? I have an 04 wrx. Thanks!
06-14-2005, 07:53 PM | #2 |
Big Ron
Super Moderator Member#: 18062
Are you putting it 100% down on the plug? A spark plug socket is very deep and needs to be 100% seated in order to turn as the socket is only a socket WAY up inside and the distance between the rubber "holder/gripper" thingy and the actually socket is an inch or two. Otherwise, you might have some hillbilly spark plug socket that isn't 5/8". Use a regular 5/8" deep well socket instead. I don't mean to belittle you if you did 100% seat it, just making sure you knew that a spark plug socket is slightly different than a normal one.
06-14-2005, 11:03 PM | #3 |
Member#: 53975
South East
Oh yeah I know its different, no offense taken, but the one I have must be crappy and just not deep enough, i guess at least. I picked a new 5/8" up at the store tonight and will try in the AM. Thanks!
06-15-2005, 08:55 AM | #4 |
Member#: 11808
My new socket with a rubber insert took quite a bit of force the first time I used it. Seems the rubber insert is sized on the small side.
Spark plug socket? | Xtreme Racer | Legacy Forum | 3 | 03-26-2010 06:51 PM |
2.5 Spark-Plug Socket | jacksonww1 | Legacy Forum | 11 | 01-13-2005 02:15 PM |
E-town ppl: may I borrow a spark plug socket? | Titanium Samurai | Canada Region Forum | 4 | 07-02-2003 11:35 AM |
Spark plug question/problem | sbsnyder | Normally Aspirated Powertrain | 1 | 04-28-2001 04:47 PM |
Yikes! Spark Plug Install Problem | Narso | Newbies & FAQs | 6 | 11-12-2000 08:21 AM |
