Brakes & Suspension Forum sponsored by The Tire Rack |
05-01-2010, 03:14 AM | #326 |
Member#: 88501
BAIC
Vehicle:2011 WRX Hatch Dark Grey |
How about updating the first post with spring rates and ride heights?
06-14-2010, 12:25 PM | #327 |
Member#: 135252
Vehicle:2002 WRX Wagon |
Has it been mentioned what the spring rates and drop are for the MY04 JDM STi springs?
06-21-2010, 08:41 PM | #328 |
Member#: 246821
Vehicle:2002 WRX Sedona Red Pearl |
My sti springs are 2 purple, and 1 purple 1 green. Did I miss something?
06-22-2010, 07:01 PM | #329 |
Member#: 12732
Vehicle:2000 2.5RS-T Titanium silver |
I am being offered a set of spring that wont lower the car much but will be as stiff as STI's. This set is for the GC body. THe only problem there is no part number to check the spring rate... So here is a picture of them...
Anybody knows how to de-code the paint marks? |
06-24-2010, 09:22 AM | #330 |
Member#: 12732
bump!! for help needed
08-22-2010, 07:38 PM | #331 |
Member#: 210864
Vehicle:1998 impreza 2.5rs black on gold |
ive looked through this entire thread
what are these SPRINGS 1-pink over 1-blue 1-yellow over 2-green and STRUTS LK14 20360FA242 LK16 20360FA252 E8 STAMP w/1-blue dab, and 2-white dabs LK17 203LOFA842 w/1-blue dab, 2-pink dabs LK17 20310FA852 springs rates and what is this ? |
08-23-2010, 06:53 PM | #332 |
Member#: 210864
anyone? ^
l please! |
09-09-2010, 07:43 PM | #333 | |
Member#: 39086
Vehicle:2004 STi White |
I know that on my '04 it's purple/purple front and green/green rear. |
09-09-2010, 07:44 PM | #334 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
Nope, still wish I had an answer.
09-09-2010, 07:55 PM | #335 |
Member#: 39086
Hmm.
Your post #295 said they came off a '05 STi and post #314 says the purple/purple rear came off an '07 STI. Could Subaru have done one of their infamous running changes in '04-'05? I don't remember anything about a rate change in the rear. |
12-04-2010, 10:08 AM | #336 |
Member#: 265528
Vehicle:2004 WRX STI WRB |
I know this thread has been going on for years, and some patterns seem to have formed in the various dots on the springs. But one of the first things that came to mind, was that the dots are just assembly checks. One guy on the line installs his part, and puts a dot on a certain coil. The next guy installs his part, and then adds a dot. When the car reaches the end of the suspension installation, they check that all the dots are present, and the car goes on to be completed. I would assume the suspension is such a safety concern that insuring everything is installed, and torqued would be a priority.
This could explain different dots for different versions, separate assembly lines and different workers. Each worker may have a different color. And it could explain cars that are the same model having different dots, worker A is sick one day, worker B takes his place and puts his different dot in the same place worker A would have. Just an idea. |
12-04-2010, 10:23 AM | #337 |
Member#: 7958
Vehicle:09 GH B+ |
or they have lots and lots of iterations of springs (and bushings) on hand and need a way to correctly identify what is what
12-11-2010, 08:59 PM | #338 |
Member#: 265528
Just got done changing out my stock struts, and there were quite a few pink, purple, etc. lines here and there on different components.
Maybe they do use the dots to designate different springs in the factory, I didn't see any part numbers or anything on my stock ones. |
08-02-2011, 08:37 PM | #339 |
Member#: 276538
Vehicle:2003 Wrx Wagon 306awhp/277awtq-EWG/FMIC |
what do I have?
So I've searched high and low for a set of 04' struts for a set of springs i bought, ended up I could only get a full set so I took it.
Here's what I got, the seller claimed these are a JDM STI Pink set.. He laughed when I said, those are stock springs not "Pinks" Either way my cars in pieces and not being driven, so I bought em just to get it back on the road, and me happy again. Front struts- RA RH - 20311FE300 RA LH - 20311FE310 as seen in pic below both front have a "purple, purple" blot marking on the third coil up Rear Struts- 20360FE852 20360FE842 also as seen below paint markings are "green, purple" I noticed the struts do have KYB stamped on them. going off the first post... This what I assume to have... GDB(d) STi spec C Right Front strut - 20311FE300 Left Front strut - 20311FE310 Right Rear strut - 20360FE840 Left Rear strut - 20360FE850 Front spring - unknown Rear spring - unknown What set is this? Is it still unknown, and what's it expected or normal "used" price? TIA Last edited by Board junkie; 08-02-2011 at 08:40 PM. Reason: update |
10-13-2011, 09:31 PM | #340 |
Member#: 170475
Vehicle:1995 GF8 WRX Wagon GC8 STi RA ver. II |
I noticed no GC8 STi take off info so here is mine:
WRX Sti Sedan Version 4 Positon .......Part number... Paint mark on spring Front Left.... 20310FA610 ...Orange dot/ Red dot Front Right... 20310FA600... Orange dot/ Red dot Rear Left .....20360FA252.... Pink dot/ Pink dot Rear Right.... 20360FA242 ....Pink dot/ Pink dot Feel free to add it to the first page. |
11-21-2011, 08:59 AM | #341 |
Member#: 133498
Vehicle:2007 2.5i grey |
07-01-2012, 02:50 PM | #342 |
Member#: 320058
Vehicle:2005 Impreza 2.5RS PSM |
Did anyone ever figure out what the rear 1 purple 1 green springs are?
I have two sets of STi springs, one set has 2 purple markings on both the front and rear springs. These were sold to me as '05 STi springs. The other set has 2 purple dots on the front and 1 purple 1 green on the rear. They were sold to me as part of '04 STi takeoffs. I'd like to know the specs on the rear springs so I can figure out which ones to use. I'm guessing the purple/green springs have a higher spring rate due to the extra dead coil? Any differences in ride height? |
07-01-2012, 11:34 PM | #343 |
Member#: 39086
On ebay someone one was selling a set of springs off of an '06 STI recently and they were purple purple front and rear.
slintux, Dead coils per se don't add to to the spring rate all other things being equel. It's the number of active coils. K=(W^4)*G/*8*N*(D^3) K=spring rate lb/in W=wire diameter in G=120,000,000 for steel N=number of active coils D=diameter of the coil at the center of the wire. |
11-06-2012, 11:33 AM | #344 |
Member#: 83120
Vehicle:1992 SS EJ225T cj91legss |
Did anyone ever run into white, green, green for front springs?
07-30-2013, 01:46 PM | #345 |
Member#: 111755
this thread has been infinately helpful to me, so thanks guys for putting this together.
Do you guys know the ride height differences between v7 sti take offs and 04 sti suspension? I searched and I see that 02-03 MY01-02 wrx's are about 10mm taller than the STI springs but I cannot see WHICH STI is being referenced. the v7? or v8 models? I have V7 sti fronts and the mythical V7 GENOME rears and I have read that the GENOME rears are 20mm shorter than stock.. but stock compared to WRX's.. I am a bit confused as to what I'd end up with in installing these to my 02 wrx.. Thanks for help, if any.. |
07-30-2013, 01:48 PM | #346 |
Member#: 111755
Is there any ride height differences between v7 and v8 sti suspension?
12-05-2013, 10:50 AM | #347 |
Member#: 372262
I picked up a set of sti springs yesterday that were both the front and rear are purple/purple. Granted He pulled these out of a pile of springs so not sure if they were all off the same car. The only ting I am certain of is the coil count is correct.....I think I know in the picture its hard to see the purple on all of them but they all have it. Some are just rubbed off a little more
Similar Threads | ||||
Any 06 STI with a perrin 30r, please read | Dana Daray | Southern California Impreza Club Forum -- SCIC | 4 | 04-09-2010 07:42 PM |
$425 JDM GC8 WRX sti suspension takeoffs COMPLETE 4 corners | supermoose | Private 'For Sale' Classifieds | 12 | 06-29-2006 02:57 PM |
please post pics of wrx with sti suspension | 04wrx555 | Member's Car Gallery | 10 | 03-30-2005 03:35 PM |
JDM V8 STi suspension takeoffs (long) | Jeff_DML | Car Part Reviews | 19 | 08-20-2004 03:09 PM |
Everyone with a modded car, please read. | jimb | Tri-State Area Forum | 17 | 10-24-2003 06:25 PM |
