Welcome to the North American Subaru Impreza Owners Club Thursday November 21, 2019
Old 04-05-2019, 01:50 PM   #26
PA-Outback2000
Member#: 161832
2000 Outback Limited
SOHC heads don't flow nearly the same as DOHC heads, even with modified cams and head work. low-to-mid 400's CHP is still about right for 18psi of boost, but power application depends on the type of induction. SOHC power limit is around 500CHP with every mod and proper head work.
PA-Outback2000 is offline   Reply With Quote
Old 10-12-2019, 10:38 PM   #27
natedrew91
Member#: 507338
Default Supercharger a 2012 outback
Originally Posted by pcampbell View Post
I am actually selling my Raptor kit now in the classifieds section , asking $2k and it comes with sti injectors and 0 mile rebuild on the supercharger and will consider offers. Selling for a bigger one to support lots of power.
What year and vehicle are you thinking of putting it on? Transmission? It is basically all bolt on however there is some tinkering to be done, it is really not hard and I have pretty much documented the entire process beyond the manufacturers instructions.
Is it worth it, depends on your goals.
On 93 I think you can expect around 200whp and lb ft with 8 psi. Do you have access to e85? If you do water meth injection or e85 you can be at 300+ whp with 12 psi. The Raptor spins out around there (50k impeller rpm) so that is about all it can do. I have seen 315 g/s so figure 315whp possible maybe more with e85.
If you are looking for the most simple setup just slap it on there with the 6 psi pulley and no intercooler and be around 175whp. Upgrade later if you want. My kit includes 3 pulleys also. (6ish , 8 ish and 12ish psi). I do think 8psi pulley is the sweet spot on 93 octane and is very mild on your motor if you donít want to mess with e85 or water meth.
I have a bunch of notes Iíd be happy to share plus a huge thread on subaruoutback.org.
I'd be really interested in your notes. I have a 2012 outback I'd like to supercharge it.. and have some fun.
natedrew91 is offline   Reply With Quote
Old 10-16-2019, 07:55 AM   #28
pcampbell
Member#: 437670
2005 2.5 SC OB
Is it a manual transmission? Do you have access to e85?
I donít know if there is a kit for the 2012, you might check with Raptor.
pcampbell is offline   Reply With Quote
FS : Raptor Supercharger Kit WagonMafioso Engine/Power/Exhaust 10 09-30-2010 02:00 AM
Any one know much about the Raptor supercharger kits? eric92 Normally Aspirated with bolt-on Forced Induction Powertrain 11 02-12-2010 02:30 PM
raptor supercharger ZenMasterMike Normally Aspirated with bolt-on Forced Induction Powertrain 4 11-03-2009 12:57 PM
Raptor Supercharger machinegreen Mid Atlantic Impreza Club -- MAIC 14 03-26-2009 11:56 PM
Raptor SuperCharger Kit??? NYCshopper Normally Aspirated with bolt-on Forced Induction Powertrain 4 10-12-2004 10:43 PM
