Welcome to the North American Subaru Impreza Owners Club Friday November 22, 2019
Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Private Classifieds
Old 08-25-2019, 06:45 PM   #1
GK1707
Member Sales Rating: (1)
Member#: 373868
2004 STi
News NYC: Garage Clean Out 02-07 WRX STi Performance & OEM Parts
I have a bunch of parts for sale located in Queens NYC for local pickup. All parts are from an 04 STi with low mileage. Pics are below.
- Deatschwerks 850cc Side feed injectors - $350
- OEM VF39 Turbo - SOLD
- Steamspeed STX67 Turbo with Turbosmart IWG75 Wastegate - $450
- OEM STi Side Feed Yellow Injectors - $100
- OEM STi 6 speed shifter - $80
- OEM STi Radiator - $80
- APS 70mm Cold Air intake - $180
- Kinugawa turbo feed oil line - $30
- OEM turbo feed hard line
- OEM STi Lamco Boost gauge & Pod
- 3 port catch can with lines - SOLD
- 2 used Power steering pumps $60 & $40
- Coilover springs - $120
- OEM Side feed TGVs - $80
- (2) 4th Cylinder cooling water outlet for 4th cylinder cooling mod - $15 each
- OEM pitch stop mount - $20
- Benen rear tow hook - $SOLD
- TurboXS RFL BOV - $120
- OEM STi Up pipe - $100
- OEM STi Front left axle - $60
Scroll down for pics and description.
- Deatschwerks 850cc Side feed injectors - $350 - 2k miles on these injectors, perfectly functional.
PM me if interested. All parts are located in Queens NYC for local pickup
GK1707 is offline   Reply With Quote
Old 08-25-2019, 06:46 PM   #2
GK1707
Member#: 373868
2004 STi
- Steamspeed STX67 Turbo with Turbosmart IWG75 Wastegate - $450 - No shaft play and is in perfect condition, may need a rebuild as it has wisps of coolant smoking from it
- OEM STi Side Feed Yellow Injectors - $100 - Perfect condition - 40k Miles
- OEM STi 6 speed shifter - $80 - Perfect condition
- OEM STi Radiator - $80 - Perfect condition, will include upper and lower hoses
Old 08-25-2019, 06:47 PM   #3
GK1707
Member#: 373868
2004 STi
- APS 70mm Cold Air intake - $180 - Perfect condition, powdercoated gold
- Deatschwerks DW200 fuel pump - $60 - Perfect condition, used for only 2k miles
- Kinugawa turbo feed line - $30 - The line is brand new, the restrictor/fitting is for ball bearing turbos, but will work with the OEM turbo as well.
- OEM turbo feed hard line - $20 - Perfect condition
- OEM STi Lamco Boost gauge & Pod - $50 - Perfect condition
- 3 port catch can with lines - $25 - Functional
Old 08-25-2019, 06:47 PM   #4
GK1707
Member#: 373868
2004 STi
- 2 used Power steering pumps - $60 for the OEM and $40 for the reman - both of them need to be rebuilt, they both leak (note they will not come with pulley or brackets pictured
- Coilover springs - $120 - Perfect condition but dirty. They are 8KG front and 6KG rear. 220mm rear and 200mm front. They will fit almost any brand of coilovers (Tein, BC, Koni, D2, Fortune)
- OEM Side feed TGVs - $80 - Motors are perfect and functional
- (2) 4th Cylinder cooling water outlet for 4th cylinder cooling mod - $15 each - Brand new. These are OEM JDM Subaru water fittings that screw into the 4th cylinder hex plug, Tee them into a heater hose line to cool the 4th cylinder. Referece "GDT Cylinder 4 Chamber Cooling Mod" if you're not familiar. This is a must do mod.
- OEM pitch stop mount - $20 - Perfect condition
Old 08-25-2019, 06:48 PM   #5
GK1707
Member#: 373868
2004 STi
- Benen rear tow hook - $20 - Perfect condition
- TurboXS RFL BOV - $120 - Perfect condition
- OEM STi Up pipe - $100 - Perfect condition, all studs intact
Old 08-25-2019, 06:48 PM   #6
GK1707
Member#: 373868
2004 STi
- OEM STi Front left axle - $60 - Has a ripped boot and will need it replaced but otherwise no issues
Old 09-01-2019, 03:17 PM   #7
GK1707
Member#: 373868
2004 STi
bumppp
Old 09-07-2019, 03:09 PM   #8
GK1707
Member#: 373868
2004 STi
bump vf39 sold
Old 09-12-2019, 04:10 AM   #9
Skip62
Member#: 506279
Default I could use a front sub frame
If you have one.
Skip62 is offline   Reply With Quote
Old 09-12-2019, 08:38 AM   #10
GK1707
Member#: 373868
2004 STi
Originally Posted by Skip62 View Post
If you have one.
I do not. Not parting out any cars. I only have available what is listed above.
Old 10-13-2019, 01:21 AM   #11
GK1707
Member#: 373868
2004 STi
bumpppppp
Old 11-01-2019, 11:53 PM   #12
stockimpreza12
Member#: 420261
2013 Impreza WRX
Crystal Black Silica
Sti boost gauge still available?
stockimpreza12 is offline   Reply With Quote
Old 11-02-2019, 09:26 PM   #13
GK1707
Member#: 373868
2004 STi
Still have it available. PM coming your way
Old 11-17-2019, 03:46 PM   #14
GK1707
Member#: 373868
2004 STi
Bump it. I can ship most of the smaller items. Larger things like the Intake, radiator and turbo, I would prefer local pickup
