04-05-2006, 09:40 PM | #1 |
Member#: 7140
Vehicle:2009 WRX satin white pearl |
PCV valve replacement
does anyone have detailed instructions on how replace the PCV on a '02 WRX? i'm trying to save money by doing as much maintenance as i can.
thanks! db97
04-05-2006, 09:52 PM | #2 |
Member#: 90156
Vehicle:1986 Syncro Vanaru 07 SV650 |
Test it first. If it ain't broke you'll save money by not fixing it.
Whatever the case may be, it is easy to change. It is located on the back of the intake manifold with a hose going to it from the crankcase breather, the little plastic widget with a hose to it and the intake hose. The PCV is a metal fitting with a hex flange. Unscrew it and it comes out. You can test it by pulling a line off the aforementioned widget and sucking/blowing on the line. The PCV valve should allow air to flow one way and not another. I know there is a guide for changing it on Scoobymods. |
04-05-2006, 09:54 PM | #3 |
Member#: 1134
Vehicle:2015 Outback H-6 White |
Yes there is, and it should also be on www.northursalia.com.
Probably slightly different location from the one on the RS, like my car. I think it's a 19mm socket. Easiest thing in the world to change. =S2= |
04-05-2006, 11:10 PM | #4 |
Member#: 5238
Vehicle:GGA Black |
an offset wrench makes this much much easier.
04-05-2006, 11:29 PM | #5 |
Member#: 22412
SWIC
Vehicle:2024 Legacy Sport |
or a deep socket and a flex joint.
they are cheap enough that I would just pick up a new one and replace it, rather than remove, check, and re-install. |
04-06-2006, 10:13 AM | #6 |
Member#: 1134
Regular deep socket is perfectly easy on my car, but yeah not sure about the WRX.
04-07-2006, 08:32 AM | #7 |
Member#: 7140
i still can't find the sucker??
does someone have a picture of the darn thing in a 02-03 WRX? |
04-07-2006, 08:36 AM | #8 |
Member#: 22412
SWIC
look under the throttle body on the rear side of the engine - it's grey and has a rubber hose put onto one end. you can see it well from the passenger side of the engine.
04-07-2006, 08:56 AM | #9 |
Member#: 11808
On my 2000 Forester 2.5L the PCV has one hose to the aircleaner box and one hose to the intake manifold. The valve looks to be about 2 &1/2 inches tall. Has Subaru changed the system that much?
04-08-2006, 09:22 PM | #10 |
Member#: 12368
Vehicle:2008 Infiniti G35X 2011 BMW X5 Diesel |
I changed mine this summer and it really isnt a piece of cake to get to and you will really need a light to see EXACTLY where it is.
Once you find it, should be a piece of cake. |
04-11-2006, 12:18 AM | #11 |
Member#: 21093
Vehicle:2002 WRX WAGON BLUE |
noob question
..what is a pcv valve for? i'm close to 60k. |
04-11-2006, 01:17 AM | #12 |
Member#: 53451
Vehicle:2000 JDM Impreza SRX w/ AVCS Silver |
04-11-2006, 09:22 AM | #13 |
GC84Ever
Super Moderator Member#: 301
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
04-11-2006, 11:48 AM | #14 |
Big Ron
Super Moderator Member#: 18062
Vehicle:on car parts so PM me b4 j00 buy |
Neither do I Jaime. If you hear it click back and forth, it's still fine. If not, replace it. But.....it is a cheap and easy part to swap out, so I wouldn't hate.
04-14-2006, 10:55 AM | #15 |
Member#: 6030
Vehicle:04 Gold FXT 07 WRB FXT Sport |
just did my last night after 120k miles, the old one looked like it could go another 120k.
I figured it wasn't listed in the maint. sched as a mistake, although those who change it every 30k seem a little over the top. dm |
04-14-2006, 11:46 AM | #16 |
Member#: 22412
SWIC
I agree that it probably lasts a lot longer than say the recommended replacement interval which some sites claim (15k miles, iirc) - but it's also not easy to tell how well it's working - clicking back and forth is important, but the quality of the seal when it's closed is what determines it's lifetime... I dunno - it's a pretty cheap part, so if you are doing the normal preventive maintenance at 15k or 30k or whatever, if you are going to check it, you might as well just replace it.
04-15-2006, 10:55 AM | #17 | |
GC84Ever
I'm not hating. I just dont get it..... but we sell loads of them at work so someone out there thinks they need to do this.... Jamie |
04-25-2006, 07:08 PM | #18 |
Member#: 77972
Vehicle:2019 WRX Limited DGM |
04-26-2006, 12:12 AM | #19 |
Member#: 62856
Vehicle:MBP SQC#197 Stockpiling parts... |
Hmm could've sworn it was one the maintenance list for 30k.....why the heck did i get it done? LOL
Where did I get at idea from.... Was it on there or not? |
04-26-2006, 09:18 AM | #20 |
GC84Ever
04-26-2006, 01:04 PM | #21 |
Member#: 30252
RMIC
Vehicle:2005 996GT3,'16 3500 04 Ducati 749R #249 |
well duh idk, i changed mine, nothing else to do and it was $3.00
04-27-2006, 01:05 AM | #22 |
Member#: 62856
Really? Or are you just fooling with me now? BTW, caught you on (damn forgot the name of the show) on the SPEED channel a couple days ago... Wow....$3 for parts...how much would they charge for labor on that anyway? Since I had it done on my 30k...guess I'll never have to change it.... |
04-28-2006, 10:18 AM | #23 |
Member#: 75021
Vehicle:2005 RS wagon gray |
quick question to hijack the thread, is it in a different place on the 05 RS? I looked for it yesterday and I found two hoses on the drivers side of the throttle body, and one hose from the valve cover to the "torque box" behind the throttle body. Thanks.
07-01-2006, 12:03 PM | #24 |
Member#: 65065
Vehicle:2004 EJ205 STi 2007 Forester STi |
well i bought one just because i thought it was required maintenence. im gonna check mine, if it still clicks, ill have a brand new one for sale
07-01-2006, 12:15 PM | #25 |
Member#: 11808
Not on my 2000 Subaru maintanance schedual and the OEM origional is doing great at 107,000 miles. Ed
Similar Threads | ||||
Confused on PCV valve replacement | goldice42 | Service & Maintenance | 15 | 11-27-2010 04:33 PM |
PCV Valve REPLACED Idle Problem GONE!! | deebee8 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 06-03-2007 10:55 PM |
PCV valve replacement interval | HudsoN456 | Service & Maintenance | 10 | 05-23-2002 03:22 PM |
PCV Valve Replacement Interval? | Silver2000RS | Technical Forum Archive | 1 | 10-12-2000 09:26 AM |
PCV Valve Replacement | richeich | SVX Forum Archive | 2 | 06-26-2000 06:53 AM |
