11-20-2007, 12:33 AM | #1 |
Member#: 2539
Low RPM/low boost knocking?
Evening all.
Trying to tune some mid-RPM (3250-4500) knock out of my car in the 90-100 load points and ran across some VERY bizarre knocks. Very light throttle (11-12%), very low boost (-6)... Code:
***91;TSMP***93;***91;RPM***93;***91;PSIG***93;***91;MAF***93;***91;TPS***93;***91;LOD***93;***91;KN***93;***91;SNB***93;***91;SIG***93;***91;IDC%***93;***91;IGN***93;***91;FMVL***93;***91;BMV***93;***91;MMV***93;***91;WBO2***93; 985.47 1803 -9.8 1.9 8 0 0 14.3 34.2 4.8 ECU +1.0 ECU 1.9 19.87 985.67 1840 -9.1 1.9 8 0 0 14.0 35.3 4.5 ECU +1.0 ECU 1.8 14.42 985.87 1839 -8.9 1.9 8 0 0 14.5 35.0 4.8 ECU +1.0 ECU 1.9 14.63 986.07 1843 -8.7 1.9 10 0 0 14.5 34.9 5.0 ECU +1.0 ECU 1.9 15.02 986.27 1835 -8.5 1.9 10 0 0 14.3 35.1 5.2 ECU +1.1 ECU 2.0 14.61 986.47 1842 -7.9 2.0 11 0 0 14.3 35.4 7.2 ECU +1.0 ECU 2.1 14.05 986.67 1841 -6.3 2.0 11 0 1 13.6 37.4 6.8 ECU +1.0 ECU 2.1 13.63 986.87 1838 -5.9 2.1 11 0 0 14.0 37.6 7.0 ECU +1.0 ECU 2.1 13.53 987.34 1868 -5.7 2.1 12 0 2 14.3 35.6 6.9 ECU +1.0 ECU 2.1 14.38 Code:
***91;TSMP***93;***91;RPM***93;***91;PSIG***93;***91;MAF***93;***91;TPS***93;***91;LOD***93;***91;KN***93;***91;SNB***93;***91;SIG***93;***91;IDC%***93;***91;IGN***93;***91;FMVL***93;***91;BMV***93;***91;MMV***93;***91;WBO2***93; 995.63 1872 -3.0 2.3 20 0 0 14.3 30.9 9.6 ECU +1.0 155 2.2 14.28 995.84 1885 -2.8 2.3 20 0 0 14.3 26.9 9.4 ECU +1.0 155 2.3 14.16 996.04 1871 -2.8 2.3 20 0 0 14.3 26.2 9.4 ECU +1.0 155 2.2 14.11 996.23 1866 -2.6 2.4 20 0 0 14.3 26.8 9.3 ECU +1.0 155 2.3 14.15 996.43 1888 -2.6 2.3 20 0 0 14.3 25.9 9.7 ECU +1.0 155 2.3 14.18 996.64 1888 -2.4 2.3 18 0 0 14.3 25.6 9.6 ECU +1.0 ECU 2.3 14.16 996.84 1910 -2.8 2.3 16 0 0 14.3 26.0 9.5 ECU +1.0 ECU 2.3 14.19 997.03 1899 -3.6 2.1 12 0 1 14.3 27.7 8.9 ECU +1.0 ECU 2.2 14.26 997.23 1941 -4.7 2.1 12 0 1 14.5 31.3 7.8 ECU +1.0 ECU 2.1 14.42 Code:
***91;TSMP***93;***91;RPM***93;***91;PSIG***93;***91;MAF***93;***91;TPS***93;***91;LOD***93;***91;KN***93;***91;SNB***93;***91;SIG***93;***91;IDC%***93;***91;IGN***93;***91;FMVL***93;***91;BMV***93;***91;MMV***93;***91;WBO2***93; 998.23 1948 -5.3 2.1 12 0 0 14.3 32.6 7.8 ECU +1.0 ECU 2.2 14.44 998.43 1956 -5.3 2.1 12 0 0 14.3 30.6 7.8 ECU +1.0 ECU 2.2 14.41 998.63 1968 -5.3 2.1 12 0 0 14.5 30.7 7.8 ECU +1.1 ECU 2.1 14.33 998.83 1979 -5.3 2.2 13 0 0 14.3 30.8 7.8 ECU +1.0 ECU 2.2 14.30 999.02 1974 -5.5 2.1 12 0 0 14.3 30.8 7.6 ECU +1.0 ECU 2.2 14.36 999.22 1991 -5.5 2.1 12 0 0 14.5 30.9 7.5 ECU +1.0 ECU 2.1 14.50 999.42 1997 -5.5 2.1 12 0 0 14.5 30.8 7.8 ECU +1.0 ECU 2.2 14.56 999.62 2006 -5.3 2.2 13 0 1 14.3 28.9 7.8 ECU +1.0 ECU 2.2 14.44 999.84 1988 -5.5 2.1 12 0 1 14.3 28.9 7.6 ECU +1.0 ECU 2.2 14.27 Code:
***91;TSMP***93;***91;RPM***93;***91;PSIG***93;***91;MAF***93;***91;TPS***93;***91;LOD***93;***91;KN***93;***91;SNB***93;***91;SIG***93;***91;IDC%***93;***91;IGN***93;***91;FMVL***93;***91;BMV***93;***91;MMV***93;***91;WBO2***93; 208.27 2766 -1.6 2.8 23 0 1 14.3 34.6 16.1 ECU +1.4 170 2.8 13.94 208.48 2794 -2.0 2.8 23 0 1 14.0 34.7 16.3 ECU +1.4 170 2.8 14.04 208.68 2866 -1.8 2.8 23 0 0 14.3 35.1 16.4 ECU +1.4 170 2.7 14.10 208.87 2888 -2.0 2.8 23 0 0 14.3 34.8 17.1 ECU +1.4 165 2.8 14.08 209.06 2908 -1.8 2.8 23 0 1 14.3 35.2 17.4 ECU +1.4 165 2.8 14.05 209.27 2952 -1.8 2.8 23 0 1 14.3 36.0 17.2 ECU +1.4 170 2.8 14.08 209.47 3005 -2.0 2.8 23 0 1 14.3 35.9 17.5 ECU +1.4 165 2.8 14.09 209.66 3016 -2.0 2.8 23 0 1 14.3 36.4 17.5 ECU +1.4 165 2.8 14.07 209.87 3058 -2.2 2.8 22 0 1 14.3 36.6 17.7 ECU +1.4 160 2.8 14.07 First time I've ever seen anything like this. I hadn't driven the car for about a week before yesterday. I threw on my snow tires, warmed it up, and drove about 10 miles yesterday. I drove it to work this morning (about 10 miles), after work I went to the neighboring town about 20 miles away, shut it off for about 35 minutes and then the problem started. I'm staying below the crossover so I think the UTEC's just reporting the knocks. I had it tuned in April and, aside from my mid-range knock I haven't really had any issues with the tune. Any ideas? Thanks! FFb
11-20-2007, 03:56 AM | #2 |
Member#: 37938
Vehicle:02 WRX Blue Mica |
It is quite strange because your car was knocking when the STock ECU still in control according to UTEC. Your boost still negative ... r u sure nothing making any noise under the hood?
Maybe for the temporary solution you can tune the 0% column timing (reduce the timing). just my 2 cnt |
11-20-2007, 06:43 AM | #3 |
Member#: 14141
Vehicle:2002 Impreza WRX |
I doubt that is real knock, probably some other cause like a loose heat shield etc.
You can't have detonation when the engine is not under load, unless the tune is totally in the wrong time zone so baddly it would instantly kill the engine under boost. Larry |
11-20-2007, 07:24 AM | #4 |
Member#: 123574
Vehicle:2005 STi CGM |
+1 for Larry's idea. I've been fighting the same problem, and have yet to discover the cause. I have noticed that my engine seems to do this more when it's a bit low on oil.
11-20-2007, 09:15 AM | #5 | |||
Member#: 2539
Anyone have any idea what things to check under the hood? I'll need to drive with the window down when pulling away from stop signs/lights to tell if I can hear it at all. If I could hear it all the time (even if it's only causing knock some of the time) that'd sure be helpful for tracking it down. Heck, I don't have anything else to listen to while I'm driving (friggin' Infinity crap ). |
11-20-2007, 09:50 AM | #6 | |
Member#: 14141
Try finding a location like a narrow alley where you can drive with your window down right next to a concrete or brick wall. It makes it very easy to hear noises that are impossible to hear effectively inside the car. Larry |
11-20-2007, 11:42 AM | #7 | |
Member#: 2539
Thanks for all the help, guys! I'll report back... |
11-22-2007, 10:53 AM | #8 |
Member#: 2539
Last night when I was running some errands I noticed the knocking at various RPMs, still with no positive boost. It got me thinking, I checked my plugs about 3 weeks ago and a 12mm socket fell down on the passenger side of the engine compartment. It went down near the coils, and after spending about 30 minutes looking for it (rock guard, exhaust shields, etc) I gave up. I had summarily forgotten about it, but I thought about it again yesterday as a good candidate for causing the knock. Hopefully tomorrow I'll have some time to crawl under the car and see if I can track that down.
11-22-2007, 10:59 AM | #9 |
Member#: 123574
If that works, I will blame mine on one or both of the 8mm sockets that my engine bay ate during a turbo swap. |
strange noise - low RPM/low speed | Nick02 | Newbies & FAQs | 5 | 07-08-2008 09:38 PM |
Low rpm knock? | NJ2.5RS | Open Source Reflashes | 4 | 01-27-2008 09:05 AM |
Low RPM Low Load Issue | xolosis | Commercial ECU Reflashes | 1 | 11-01-2006 12:52 PM |
Knock at low rpm and throttle | PharmCo | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 02-02-2004 10:28 PM |
Flashing CEL at mid-low RPMS / low Throttle - then gone | johnnytran | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 06-06-2003 03:45 AM |
