Welcome to the North American Subaru Impreza Owners Club Friday October 19, 2018
Old 11-18-2008, 09:31 PM   #1
spulbi
Member#: 190378
2008 Dinan 335i
Default Messed up my tranny???? :(
Hey guys, I was driving up a little hill today and I shifted semi-hard from 3-2-3 again, and when I downshifted into 2, I heard a little pop somewhere near the back of my car. ( It sounded like) All gears seem to work, but there is a horrible clicking sound. Sort of sounds like a tractor engine. Its a 2002 WRX manual. I am scared to drive it/fast/slow/ etc.
What should I do???
I know these tranny's are notoriously weak.
PS: Forgot to add:
The tranny doesn't make any noise if it is in gear with clutch down and engine on.
Tranny doesn't make noise if car is coasting in neutral.
spulbi is offline   Reply With Quote
Old 11-18-2008, 09:40 PM   #2
Rexfan
Member#: 50993
02 WRX Wagon
2.5/Blouch Dom 3/Meth/6sp
Park it and have it towed (flat bed). Have it looked at. Don't take a chance on making it worse.
Report back?
Rexfan is offline   Reply With Quote
Old 11-18-2008, 10:55 PM   #3
spulbi
Member#: 190378
2008 Dinan 335i
Just drove it a little bit.... the noise occurs only when 2nd gear is selected.
Should I buy a new tranny or just replace 2nd gear? Could I have popped a synchro?
Old 11-18-2008, 10:56 PM   #4
rexman2002
Member#: 140244
2002 bugeye
still rippin' hard
speak for yourself, mine's perfectly fine at 143k miles. noobs!
Take it to a reputable shop and have them take a look at it. If you don't want to drive it there, get a flatbad to tow it.
rexman2002 is offline   Reply With Quote
Old 11-18-2008, 11:14 PM   #5
spulbi
Member#: 190378
2008 Dinan 335i
Ah can't you make me feel better considering my life's in shambles right now??
Old 11-18-2008, 11:59 PM   #6
v8eaterWRX
Member#: 108547
2017 Tundra 1794
Lifted, Armored, Muddy AF
Some people get sand in the vag syndrome about the 5mt.
+1 on the tow it and not make it worse.
Hope it works out for you man!
v8eaterWRX is offline   Reply With Quote
Old 11-19-2008, 12:13 AM   #7
BoberT-
Member#: 74168
2005 Legacy GT
Throwout bearing??
BoberT- is offline   Reply With Quote
Old 11-19-2008, 12:31 AM   #8
spulbi
Member#: 190378
2008 Dinan 335i
Originally Posted by BoberT- View Post
Throwout bearing??
wouldn't that squeak only when the clutch is depressed?? Anyways.. the only time it makes weird noise is when it is in 2nd gear. and i don't have to tow it... i was lucky enough to have it freak out on the last hill before my driveway. =/
Old 11-19-2008, 01:01 AM   #9
BoberT-
Member#: 74168
2005 Legacy GT
The throwout bearing will rattle when you have it in neautral and you have nothing pushed down.
Old 11-19-2008, 10:48 AM   #10
r3xor
Member#: 188129
02 WRX Cobb Stg 2
How does it shift into/out of 2nd? If the shift is OK but you are still hearing this sound, you most likely broke/chipped a tooth (or teeth) on 2nd gear.
r3xor is offline   Reply With Quote
Old 11-19-2008, 10:51 AM   #11
DS1
Vendor
Member#: 111780
Sounds like you broke a tooth off of 2nd gear
You should tow it to a shop you trust.
DS1 is offline   Reply With Quote
Old 11-19-2008, 01:38 PM   #12
spulbi
Member#: 190378
2008 Dinan 335i
Well I started the car this morning and moved it. It was making a slight grinding noise in neutral also. It shifts in and out of second gear just fine. I'm not driving the car.
But taking it to a shop is not an option for me. They charge too much and i'm already broke trying to pay for this car as it is. I have rebuilt transmissions before, would it be better to buy a used tranny, or try to rebuild this one?
Old 11-19-2008, 01:39 PM   #13
spulbi
Member#: 190378
2008 Dinan 335i
what if it is the throwout bearing? How bad is that? Can the car be driven?
Old 11-19-2008, 02:31 PM   #14
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
you are much better off rebuilding your tranny
vs buying a new one.
get it into a shop for a tear-down.
Old 11-19-2008, 02:36 PM   #15
DS1
Vendor
Member#: 111780
^^ I agree
Old 11-19-2008, 02:57 PM   #16
smurfwrx
Member#: 151928
09 Triumph S3
So does having sc/hc PPG combo in "N." I wish someone could've taken a pic of the look on mine and 4wdrift's faces when everything was buttoned up with the swap and we turned on the car on and heard that clacking.
That's what it sounds like. That's a bummer man. Try not to drive on it so it doesn't make things worse. Really sorry to hear that.
smurfwrx is offline   Reply With Quote
Old 11-21-2008, 12:39 AM   #17
jibber
Member#: 6675
98 SF5 some mods
97 LGT
If you have rebuilt trannies before why would you continue to drive and move the car? Surely you have seen the carnage that those pesky little chunks of teeth will cause if they get caught in any of the other gears.
My bet is that grinding noise is metal fragments in the bearings, if in fact you did break a tooth.
Just pull the trans and dissassemble, then you will know what is what.
jibber is offline   Reply With Quote
Old 11-21-2008, 07:17 PM   #18
spulbi
Member#: 190378
2008 Dinan 335i
It would be a good exuse to get ppg gears??? In reality, I just moved it from my driveway and parked it in our shop. Not too far... maybe 20 feet. I think it will be ok.
How bad did I mess up my WRX :( 2003yellowWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-06-2006 11:30 AM
Jiffy Lube messed up my tranny i think Tur1smoWRX Mid Atlantic Impreza Club -- MAIC 9 10-22-2003 02:43 PM
so i go to LA mess up my brakes and end up on the Fast and the Furious set gokou006 Southern California Impreza Club Forum -- SCIC 4 03-18-2003 07:27 PM
Help, Am i messing up my tranny? TheShadowWRX Transmission (AT/MT) & Driveline 6 07-06-2002 02:43 AM
I messed up my rim :( 25psi General Forum Archive 9 01-15-2001 04:52 AM
