Welcome to the North American Subaru Impreza Owners Club Wednesday January 22, 2020
Old 12-05-2019, 11:57 PM   #1
OHTOORECKS
Member#: 159723
2016 Forester XT
Crystal White Pearl
Default 2016 FXT lots of knock part throttle
I am noticing a lot of knock events on my FXT on an OTS Stage 1 tune. Is this DAM dancing around and the feedback and fine learning knock I'm seeing enough to cause concern? I use Costco 93 octane gas, maybe I should try Shell and see if it clears up? Maybe go to the 91 octane map? Or just ignore it becuase it's fine at WOT? Any insight would be appreciated!
Mods:
K&N drop in panel filter
Go Fast Bits BOV (stock plastic one was leaky)
Removed the resonator from the airbox because I like turbo noises :|
https://docs.google.com/spreadsheets...it?usp=sharing
OHTOORECKS is offline   Reply With Quote
Old 12-08-2019, 06:50 AM   #2
Hostil.Hatch
Member#: 509118
Default Get A Protune
So first off, if you see your DAM changing, immediately stay out of boost. Feedback knock isn't as important but since your DAM is changing then it could be a real problem. Stage 1 for FXT your year is stock intake and filter so if you've changed either of them in any way then you shouldn't run the map. Running 93 while a tune requires 91 will not negatively effect your car, running a lower octane would. My suggestion is to get a protune.
Hostil.Hatch is offline   Reply With Quote
Old 12-09-2019, 07:16 PM   #3
ShinjiML
Member#: 257231
2011 STI ShinjiTuned
I see knock mainly at low boost and cruising. This is probably why the DAM is dropping, so it doesn't look too bad. However, because you made a few changes to your intake side, the fuel trims are now adding a bit more fuel, so trims are a bit high.
I'd recommend getting a custom tune to work out the little kinks.
ShinjiML is offline   Reply With Quote
