03-16-2003, 02:37 PM | #1 |
Member#: 12631
Vehicle:2000 RS-T 9psi! BRP |
Has anyone installed Vishnu Fuel rails and SX FPR?
Has anyone installed Vishnu Fuel rails and SX FPR? If you have let me know cause I am not getting fuel past the regulator! Diagram or pics would be great. I have a MY00 RS.
03-16-2003, 09:57 PM | #2 | |
Member#: 3461
South East
Vehicle:1998 BMW M3 Coupe Estoril Bleau |
Re: Has anyone installed Vishnu Fuel rails and SX FPR?
Once you have achieved the desired IDLE Fuel PSI, then tighten the nut to hold the andjustment screw in place. Hope this helps...This is what I have to do to my Aermotive Piece which is very similar in design to yours. Kevin |
03-16-2003, 10:09 PM | #3 |
Member#: 12631
Kevin I got the Fuel going was wondering what your idle pressure is? I have a link2, 550, vishnu fuel rails. The car bogs over 2k. My AF gauge is not working so I am not sure if it's rich or not.
Thanks Ralph |
03-16-2003, 10:16 PM | #4 | |
Member#: 3461
South East
If that doesn't work, try raising your base Fuel PSI to 55psi if you have an uprated fuel pump. This is if you're forced induction though. If you are N/A keep it at 43psi.... Last edited by latinskllz; 03-16-2003 at 10:32 PM. |
03-17-2003, 07:16 AM | #5 |
Member#: 12631
I Have a ludespeed turbo kit so 55psi at idle?
03-17-2003, 08:48 AM | #6 |
Member#: 3461
South East
Yes, I believe that should be fine since SHIV stated that he prefers 55psi at idle with the fuel rails and a uprated fuel pump...
How did you connect the fuel lines to the FPR? |
03-17-2003, 12:10 PM | #7 |
Member#: 12631
Ok Off of fuel filter to rails then off of each rail back to fpr then FPR bottom outlet to reurn I think I have a diagram I got from this group if you want it Very good!
03-17-2003, 12:37 PM | #8 | |
Member#: 3461
South East
Make sure that you feed from the filter to the rail ends that face the front of the engine and then connect the lines that feed from the fuel rails closest to the firewall to the FPR. Make sense? Anyhow, how did the adjustment of PSI go? |
Perrin Fuel Rail And Lines Fpr | wrxxer | Engine/Power/Exhaust | 8 | 06-26-2007 08:59 PM |
Has anyone done the fuel rail fix to eliminate the cold weather fuel smell? | Snowphun | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 15 | 11-01-2005 09:20 AM |
Vishnu Fuel Rails, SX Rising Rate FPR, Earls Lines and Fittings | dan avoN7 | Private 'For Sale' Classifieds | 10 | 01-03-2005 09:30 PM |
Has anyone installed MRT brake bracket? and cheap brake pads | m750 | New England Impreza Club Forum -- NESIC | 10 | 11-29-2002 07:46 AM |
which dual inlet FPR to get with my Vishnu Fuel Rails | latinskllz | Normally Aspirated with bolt-on Forced Induction Powertrain | 8 | 09-26-2002 10:21 PM |
