Welcome to the North American Subaru Impreza Owners Club Monday October 15, 2018
Old 07-24-2009, 01:54 PM   #1
BGPunk2001
Member#: 46134
Default What's the easiest way to check your O2 sensor?
My car is stumbling at idle, and hesitates while accelerating under 2k rpm. Above that, it runs like a champ all the way to redline.
It threw a code the other day, and it said it was a lean condition on cylinder bank 1. The Thing said that I could have a maf sensor issue, low fuel pressure, and O2 sensor malfunction, or vacuum leak....
I replaced the fuel filter because I hadn't in about 2 years or so. Then I took it to a mechanic I know, but he is going out of town for the next week. He said it sounded like I had a large vacuum leak or a bad O2 sensor.
I don't hear any loud sucking noises, so I doubt it is a leak.
I do know that when it is raining and I go over bumps, I seem to get this clunking right behind my seat, and sometimes it sounds like I have an aftermarket muffler on my car. Maybe the exhaust is loose in the middle, and maybe the rear O2 sensor is mounted there.
That would make sense because it started doing it after it rained the other day, and I got a whole hell of a lot of that banging right behind my seat. Maybe it got shorted out or fouled from water or something.
Sorry for rambling, but I may have just helped myself out a lot.
CN: HOW DO I TEST MY REAR O2 SENSOR?
PS: Its an 01 4cyl Camry.
BGPunk2001 is offline   Reply With Quote
Old 07-24-2009, 01:56 PM   #2
RALLYT-WRX
Member#: 9369
F#ck U & Your Stance
BLOD
You really can't test them. When they go bad you should be getting a CEL for it.
Did you try cleaning your maf sensor yet?
RALLYT-WRX is offline   Reply With Quote
Old 07-24-2009, 01:57 PM   #3
matt.chase
Member#: 191850
2005 LGT stg 2
psm
Smile
I think this is the wrong location to post this. I'm sure the rest of OT will let you know.
matt.chase is offline   Reply With Quote
Old 07-24-2009, 01:57 PM   #4
BGPunk2001
Member#: 46134
Its not a Subaru.
Old 07-24-2009, 01:58 PM   #5
matt.chase
Member#: 191850
2005 LGT stg 2
psm
sorry didnt notice it was for a camry.
Old 07-24-2009, 01:58 PM   #6
Qcanfixit
Member#: 135762
2059 Venturi Skimobi
transparent aluminium
scan tool program for my laptop.
read the voltage from the sensor to see if it is within spec.
Qcanfixit is offline   Reply With Quote
Old 07-24-2009, 01:59 PM   #7
Jard
Member#: 34935
Phil Kessel is a 2x
Stanley Cup Champion!
Uninstall it from your car and install it in your anus.
Jard is offline   Reply With Quote
Old 07-24-2009, 01:59 PM   #8
BGPunk2001
Member#: 46134
Great, can you come over in an hour?
Old 07-24-2009, 02:00 PM   #9
RALLYT-WRX
Member#: 9369
BLOD
Just replace it. It can't be that expensive.
Or buy a Miata.
Old 07-24-2009, 02:00 PM   #10
hondaeater69
Member#: 60324
1998 RS
disconnect it and see if anything changes? i don't think a bad rear 02 will cause the issues you're describing though.... if it's anything like scoobs, it's only there to monitor, and don't really control much of the fueling.
Old 07-24-2009, 02:01 PM   #11
subysleeper
Member#: 59144
... My car is
Front-Mid Engine
I thought rear o2 sensors are just to make sure the CAT is there. I don't think the second sensor has anything to do with the way the car drives.
edit: damn it honda!
subysleeper is offline   Reply With Quote
Old 07-24-2009, 02:01 PM   #12
WRX Shenanigans
Member#: 101378
I'd try cleaning the MAF sensor first...easy and free.
And your o2 sensor isn't in your exhaust manifold?
WRX Shenanigans is offline   Reply With Quote
Old 07-24-2009, 02:02 PM   #13
BGPunk2001
Member#: 46134
I think they're like $50 a pop. $100 to fix nothing is pretty steep.
Old 07-24-2009, 02:03 PM   #14
RALLYT-WRX
Member#: 9369
BLOD
Try cleaning your maf yet?
Old 07-24-2009, 02:03 PM   #15
Qcanfixit
Member#: 135762
sure hold on, let me get in my UFO...
Old 07-24-2009, 02:05 PM   #16
subysleeper
Member#: 59144
... My car is
Front-Mid Engine
I new it!
Old 07-24-2009, 02:06 PM   #17
RALLYT-WRX
Member#: 9369
BLOD
Wait a minute. Did you spool it at 12mph.......... again?
Old 07-24-2009, 02:08 PM   #18
BGPunk2001
Member#: 46134
A - No, right now i'm at work.
B - WAT?
Old 07-24-2009, 02:09 PM   #19
subysleeper
Member#: 59144
... My car is
Front-Mid Engine
You probably spoolled at 12mph.
Old 07-24-2009, 02:09 PM   #20
beethoven
Member#: 6654
2006 Odyssey
2006 Prius
When the O2 sensor failed in my Forester I was getting some MAF code. Buy an after market replacement, it should be a lot cheaper than OEM.
beethoven is offline   Reply With Quote
Old 07-24-2009, 02:10 PM   #21
Wagon Of Fury
Member#: 47982
Your MAF, it may be dirty. Have you considered removing said dirt ?
Wagon Of Fury is offline   Reply With Quote
Old 07-24-2009, 02:10 PM   #22
Wagon Of Fury
Member#: 47982
Should have got the diesel
Old 07-24-2009, 02:13 PM   #23
BGPunk2001
Member#: 46134
HOLY ****ING BALLS!!!! An O2 sensor is $68 for my ****ing car!!!!
Old 07-24-2009, 02:13 PM   #24
RALLYT-WRX
Member#: 9369
BLOD
B - WAT?
A - Leave work early, afterall it's Friday. Clean MAF.
B - You can't be serious.
Old 07-24-2009, 02:14 PM   #25
hondaeater69
Member#: 60324
1998 RS
today is friday? sweet
What's the easiest way to search for your own posts? thehalogod Off-Topic 25 05-12-2008 08:30 PM
Preferred Packages are the easiest way to outfit your vehicle for winter -- the ideal [email protected] Tire & Wheel 3 11-01-2007 12:32 PM
Preferred Packages are the easiest way to outfit your vehicle for winter [email protected] Tire & Wheel 0 10-12-2006 04:19 PM
What's the easiest way to get signal from factory deck? styng88 Car Audio, Video & Security 8 05-06-2005 03:24 PM
What's the easiest way to run cables? ZenerDiode Car Audio, Video & Security 9 02-11-2004 12:40 AM
