Welcome to the North American Subaru Impreza Owners Club Monday November 12, 2018
Old 01-05-2004, 11:44 PM   #1
KJR
Member#: 16879
Default strange boost fluctuation...help needed
I have been getting a rythmic boost fluctuation of about 4 PSI ONLY when in open loop, not when at partial throttle. i am using the FBC so i'm at stock boost right now. under partial throttle it will hold about 8 PSI firm with no fluctuation. it boosts to 14-14.5 and then comes down to about 10 psi and then goes back up when holding WOT thru the rev band. the higher the gear the worse it gets. i have checked and double checked the hoses from the FBC, wastegate and the turbo outlet and all connectors, the intake manifold as well as the bov and TB.
NOTE: all of this dissappears when i install an MBC. it holds boost firm when using any aftermarket boost controller. is my FBC going bad? is it normal to only do this in open loop? any advise would be appreciated. thanks,
KJR is offline   Reply With Quote
05 LGT OSECU strange boost problem - help bren wrx Commercial ECU Reflashes 7 06-16-2007 12:32 PM
Boost Gauge Help Needed ! loreley Interior & Exterior Modification 4 07-20-2003 01:58 AM
Manual Boost Controller help needed IMPREZIV Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-14-2002 01:12 AM
Autometer Boost guage. Help needed guage is reading wrong. Jasno999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-30-2002 01:46 PM
Boost Controller Help Needed! mountbiker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-25-2002 05:14 PM
