Welcome to the North American Subaru Impreza Owners Club Thursday July 19, 2018
Old 09-23-2001, 10:29 PM   #1
Flacco
Member#: 6673
2001 Impreza RX
Blue Black Mica
Default Strange Boost above 3000 rpm...
Has anyone noticed when the car gets to 3000RPM, it seems to boost.... Its only slight, but I noticed it the other day.....
Also when bracking up to a set of lights the RPM drops to near zero then quickly jumps up to above 500 (idling)... Are these problems or just caractaristics of the car...
Brad
Flacco is offline   Reply With Quote
Old 09-24-2001, 12:30 PM   #2
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
I noticed the "boost" you are talking about, but eventually relized it was caused by the "dead" zone in the RPM range. Around 3200 rpm, the engine has a little power drop, and then it all comes right back after another few hundred rpm. I've read about that flat area on this board many times, so I can only assume it is normal. Just something the engine does. As for the rpm's dropping to almost zero when you are coming to a stop, that's a new one to me. Do you have a manual or automatic?
HondaH8er is offline   Reply With Quote
Old 09-24-2001, 07:16 PM   #3
Flacco
Member#: 6673
2001 Impreza RX
Blue Black Mica
It is a manual transmission
Old 09-24-2001, 09:27 PM   #4
grimlock
Member#: 2683
2011 STi 5-Door
Mine really picks up the power right around 3k as well. Doesn't do the drop to zero, though.
grimlock is offline   Reply With Quote
Old 09-24-2001, 09:43 PM   #5
Flacco
Member#: 6673
2001 Impreza RX
Blue Black Mica
At least the power pickup is not a problem..... Ill have to keep my eye on the rev dropping. If it gets worse ill take it back to the dealer
Old 09-24-2001, 10:23 PM   #6
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
I've never considered power pickup to be a problem
Old 09-24-2001, 10:36 PM   #7
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
My RPM will drop a little and then come back, but you need to remember that the first mark on the tach is 500, not 0.
I noticed that it does it when the fan turns on mostly (I hardly ever use the AC though, so I wouldn't know if it was related to that)
Impreza Rider is offline   Reply With Quote
Old 09-24-2001, 11:19 PM   #8
Flacco
Member#: 6673
2001 Impreza RX
Blue Black Mica
True, I had thought about it and if it was at zero the car would stall... But it does drop dramattically
Old 09-25-2001, 03:15 AM   #9
jhonas
Member#: 9015
2002 Impreza 2.5RS
Platinum Silver Metallic
Truely interesting. If it's dropping to zero, or very near zero, I'd get it looked at. It's still under warranty isn't it?
-Matt
edit: I posted something, but after remembering this is in the NA forum, and then seeing that you don't have a WRX I realized that I was foolish for assuming... When you said "boost" it through me off.
jhonas is offline   Reply With Quote
06 WRX Hesitation between 3000 RPM - 5000 RPM dao Newbies & FAQs 11 01-19-2012 11:56 AM
Any dynos where a STi makes full boost around 3000 rpm and makes peak pwr at redline? plumpzz Newbies & FAQs 76 01-22-2007 08:31 PM
Target Boost level at 3000 RPMs, TXS stage 2 rogue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-22-2004 05:51 PM
Why we have to drag to above 6k rpm? V6 General Forum Archive 35 01-04-2001 12:32 AM
