Welcome to the North American Subaru Impreza Owners Club Monday October 14, 2019
Old 07-11-2002, 04:06 AM   #1
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default wearing bearings & long brake pedal stroke?
anyone seem to be getting this symptom?
if i go through a series of hard turns w/o braking and then come upon a straight section where i need to brake, my brake pedal stroke seems to be longer than usual and it throws off my braking distances.
i confirmed this w/ gary sheehan and he mentioned that i could very well have premature worn front bearings. the reason behind the longer pedal stroke is because the worn bearings are allowing the axles to deflect more than usual and thus allow the rotor to tilt/angle/deflect w/ respect to the caliper thus pushing the pistons further back into the caliper. thus, when i apply the brakes, the resevoir has to push more fluid to reset the caliper pistons.
anyway, does anyone seem to having this anomoly or just me?
please let me know!!!
duckboy
duckboy is offline   Reply With Quote
Old 07-11-2002, 04:26 AM   #2
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default worn bearings
yeah, but, i only have 11.6k mi on my WRX!!!
this just isn't right!!! this would have never happened on my civic si.
how much are we looking at to get the front bearings replaced?
what year is your car and how many miles do you have?
thanks for you help.
duckboy
Old 07-11-2002, 05:30 PM   #3
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default feedback please
anyone else getting this long brake pedal effect from worn bearings?
i'm especially interested in what car you have (GD or GC) and how many miles are on your car.
thanks
duckboy
Old 07-11-2002, 05:46 PM   #4
OnTheGas
Member#: 3807
2002 WRX Sedan
Silver, tinted
Default Re: worn bearings
Jeez... all that track and auto-x time, and only 11.6k miles total!
OnTheGas is offline   Reply With Quote
Old 07-11-2002, 06:38 PM   #5
GarySheehan
Member#: 2450
1996 2005 Subaru STI
You can do it yourself if you are brave and have a hydraulic press.
Gary
Sheehan Motor Racing
www.teamSMR.com
GarySheehan is offline   Reply With Quote
Old 07-11-2002, 07:41 PM   #6
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default :)
thanks for all your help gary in helping me to diagnose this problem. i don't think you know how long this has been bothering me.
but as for trying it myself, well, 1) i'm not brave on tackling something like this, and 2) i do not have a press
duckboy
Old 07-11-2002, 08:19 PM   #7
jeffg
Member#: 2958
2001 6.0?RS
so is this basically the same end result as knock back from a warped rotor?
J
jeffg is offline   Reply With Quote
Old 07-11-2002, 09:00 PM   #8
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default pad knock back
yes, in fact this is pad knock back but not from a warped rotor but from excessive amounts of rotor deflection relative to the brake caliper all due to what it seems premature brearing failure.
again, i can't believe this happened after only 11.6k miles. what a joke.
duckboy
Old 07-12-2002, 04:09 PM   #9
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default ???
anyone else???
duckboy
Old 07-12-2002, 04:30 PM   #10
shuman
Member#: 165
Default similar...
the subaru bearings suck...
i'm documenting so i can talk to a SOA rep and get store credit...
front and/or rear bearings should not fail this early even if hard driven...
****ty design. they replace with legacy bearings for rear now...not sure of the front.
hopefully they will put in a recall for this issue.
shuman
shuman is offline   Reply With Quote
Old 07-12-2002, 07:49 PM   #11
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default !!!
shuman,
thank you very much for your reply. yes i realize now how crappy the subaru bearings are. but i did NOT realize that the legacy design has been revised. very interesting point!!! well, on that note, yes our WRX pieces should have been redesigned before release.
on another similar note, are the WRX Type RA Spec C bearings the same as the legacy pieces? i heard this car's output shafts are bigger than our pieces.
duckboy
Old 07-13-2002, 12:55 AM   #12
Jsunn
Member#: 15467
2013 BMW 335i xDrive
Default What kind of noise are you hearing?
Originally posted by brucelee
I'm sorry to say, but you need to get your wheel bearings replaced.
(I need to do it soon... mine are making horrible noises now... D'oh!!)
What kind of noise are you hearing? I am hearing what seems to be a slight rubbing noise when the car is in a turn, i.e. a side load on the wheels. I have an apointment with the Subaru service dept next week. Should I have them look at the bearings?
Thanks,
-J
Jsunn is offline   Reply With Quote
Old 07-14-2002, 01:44 AM   #13
Jsunn
Member#: 15467
Default bump
bump for bad bearings.....
Old 07-14-2002, 11:36 PM   #14
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default bearings...
no bearing noises for me, YET. just a long brake pedal. i'm sure it's just a matter of time before it gets worse.
anyone else w/ this problem?
duckboy
FS:STi complete gas pedal & clutch/brake pedal covers. joe r Interior/Dressup/Audio & Security 11 12-27-2009 08:08 PM
brake pedal is mushy halfway through the pedal travel wrxmuch? Brakes, Steering & Suspension 28 11-13-2009 12:04 AM
04 manual shift boot piece. Gas pedal, auto brake pedal and auto shifter assembly scOOtNsOOby Interior/Dressup/Audio & Security 0 10-12-2009 10:05 AM
Pedal to the floor! Brake pedal that is. elcorazon01 Subaru Conversions 5 06-21-2005 01:48 PM
20mm swaybar wearing bearing? hayabusa Brakes, Steering & Suspension 1 05-07-2001 09:03 PM
