Welcome to the North American Subaru Impreza Owners Club Tuesday October 15, 2019
Old 11-10-2009, 07:13 PM   #1
wrxmuch?
Member#: 196486
2004 WRX
Default brake pedal is mushy halfway through the pedal travel
Recently I have noticed that my brake pedal gets progressively mushier as it goes through the pedal travel. I have made sure that my brakes have been bled properly and I checked my brake fluid level. What gives?
Brake fluid used:
Valvoline synthetic dot 3/dot 4 from Autozone. <-- hoping this isnt the problem.
wrxmuch? is offline   Reply With Quote
Old 11-10-2009, 07:22 PM   #2
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Does it still behave that way when the car is off?
chimchimm5 is offline   Reply With Quote
Old 11-10-2009, 07:29 PM   #3
wrxmuch?
Member#: 196486
2004 WRX
Angry
yes
Old 11-10-2009, 08:26 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
if all the calipers are working properly---not sticking
then the mc may be on the way out
Old 11-10-2009, 09:20 PM   #5
wrxmuch?
Member#: 196486
2004 WRX
o boy....
Sounds like I should replace it before I have a massive brake failure....
Old 11-11-2009, 10:05 AM   #6
skell215
Member#: 229675
Unhappy I'm mushy too!
I'm having similar issues. I replaced my brake pads and suddenly the brakes are worse than before, so then we changed the rotors thinking that the pads weren't catching because of grooves in the rotors.... no help. The brake pedal goes all the way to the floor, then I reclaced the master cylinder, flushed and bled the whole system, checked for pin holes in the lines. No improvement. They have pressure when the car is off but as soon as you turn the car on the goes to the floor. Any ideas???
Signed, Just a girl...
skell215 is offline   Reply With Quote
Old 11-11-2009, 10:27 AM   #7
vanddelor
Member#: 127319
MBP
i've been in three other wrx i've worked on including mine have this issue. I've bled them before every roadcourse event and yet still "mushy" and goes all the way to the floor...I mean C'MON!!! My mom's CR-V have way better brake pressure...
the other thing i might do is switching lines to ss lines and see if my brakes will have better feel to it...
vanddelor is offline   Reply With Quote
Old 11-11-2009, 11:24 AM   #8
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
^^I doubt the SS lines will help. I've been fighting the exact same issue for a while. There are a few other threads with the same problem. One, IIRC it was willaty's, he just lived with it till a few years later a big air bubble blurped out and it was all better.
FWIW I have SS lines, during the course of chasing my problem I hace changed out the MC, put in 4-pots, and done multiple fluid changes and bleeds. I've used Speed bleeders, made a vacuum bleeder, done it old school, done it old school with vacuum on it, done hard stops on gravel to cycle the ABS, and cycled the ABS using the under dash connectors. Nothing has helped. I'm taking it in to the dealer tomorrow and making it their problem. Will post up results.
bushflyr is offline   Reply With Quote
Old 11-11-2009, 11:25 AM   #9
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
SS lines did not help mine.
Same problem sins new.
Badmunky is offline   Reply With Quote
Old 11-11-2009, 03:10 PM   #10
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Actually, mine did get better then went to **** again. I have a feeling I may have a bad master cylinder that's managing to pull air through a seal somewhere over time.
Old 11-11-2009, 03:19 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
and i have come to the conclusion that some of these 'mushy pedal' issues are air leaks that are JUST small enough to let in a bubble but not really leak
I chased these issues and went back and broke loose and re-tightened everything I took apart and the issues stopped
Old 11-11-2009, 04:40 PM   #12
DumbstixLars
Member#: 205942
2003 WRX,00 2.5RS
2007 2.5i, 04 STI, 99 OBS
Just like most of the other posts it sounds like air in the lines. I fought this same problem on my 70 Dodge for years and it eventually turned out to be a bad MC that would just barely let air leak into the system. It was even new when I bought it.
DumbstixLars is offline   Reply With Quote
Old 11-11-2009, 05:22 PM   #13
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
It sounds like a lot of people with "fairly new MC's" have this problem.
Is this a quality issue or a design issue?
Old 11-11-2009, 11:08 PM   #14
wrxmuch?
Member#: 196486
2004 WRX
Funny you mention a CR-V.... I just got back from test driving a CR-V with my wife. When we switched and it was my turn to drive the first time I hit the brake my head jerked forward..... It was embarrassing. Guess that shows how weak my brakes are..... I have hawk hps pads and brand new brembo blanks and ss lines and I've bled the brakes twice. Now I'm hoping I don't have a massive brake failure and slam into someone. I mean I can stop no problem it just seems like I've surprised myself a few times and how slowly I stop and how progressively quick my pedal goes to the floor and how quickly abs saves my ass.....
We need to solve this problem before one of us gets hurt..
Old 11-12-2009, 02:06 PM   #15
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Well, just got back from the dealership. We went for a drive and the SM, who comes highly recommended, said my car stops way harder than most STi's. And there wasn't much they could do. Even though the pedal is on the floor it was engaging the ABS. That's the way Subie brakes are. It's not a Toyota. He also said it didn't feel like there was any air in the system.
I'm going to try Uncles loosen and retighten all the joints and see how that goes and replace the Hawk HPS in front with EBC reds. If it doesn't help I'm going to look into swapping out to a (stronger?, larger?, better?) different MC of some sort.
Old 11-12-2009, 02:36 PM   #16
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Are you guys experiencing mushy pedal when stopped but when actually braking you reach the max the brakes can grab before you really get deep into the mush?
If the car is on and not moving, and I push the brake pedal hard, I get into a mushy zone that "oozes" very low. I blame the booster. When I'm moving and braking, the wheels will lock up (ABS) before I can really get deep into the mush zone.
Old 11-12-2009, 08:20 PM   #17
wrxmuch?
Member#: 196486
2004 WRX
That's exactly my symptoms.... It's not all that confidence inspiring.... I don't like to ride the abs..... I WANT A SOLID PEDAL DAMN IT!
Old 11-12-2009, 08:25 PM   #18
wrxmuch?
Member#: 196486
2004 WRX
o yeah also,
I called my local dealership. They said they've probably sold 7 master cylinders ever.... So that kinda points me in another direction...
Old 11-12-2009, 09:06 PM   #19
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Originally Posted by wrxmuch? View Post
o yeah also,
LOL I've got a spare now.
In my case the ABS will engage, but it does it with the pedal on the floor. Under normal driving it's fine, but when you want max braking with modulation it just ain't there. I have to put the pedal on the floor and, like a previous poster says, "ride the ABS", which I really don't like.
Old 11-12-2009, 09:39 PM   #20
Uncle Scotty
Member#: 16200
OK buy Nates beans
my 02 sucked until I put the 4pots on the front and did the h6 rears and put a MC brace on
getting the abs module replaced wasnt as big a deal as the h6 rears
and putting a grabby pad in the rear...I used the Ultimates, was the real trick to it all, I think
the factory 02 brakes were horrible
Old 11-12-2009, 10:15 PM   #21
lil'redwagon
Member#: 10854
'02 WRX; '08 OBXT;
'08 G37 (S/C'd); '09 XF
i wouldn't do this, but if you want non-abs modulation, pull the abs fuse by your right knee. it makes the pedal firm and disengages the abs. i used to race like this. but i don't recommend driving on the street like this. if you're used to abs on the street, and need to stop fast, there's a good chance that you won't think to modulate the brakes like you do on the track, and just lock up instead. don't ask how i know. i think it has something to do with being much more relaxed on the street versus on the track. i think the relaxed state of mind makes you think of just hitting the brakes like you usually do (on the street, with abs). similar to "muscle memory", only this is more conditional. anyway, pull the abs fuse and see if that changes the feel. if it does, it give you another step in diagnosing your problem.
lil'redwagon is offline   Reply With Quote
Old 11-12-2009, 10:28 PM   #22
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
My brother had this SAMe damn problem on his nissan.
We argued back and forth about whether the "pot" was leaking or if it was his MC.
Turns out both his fronts calipers had a very very very very small leak in them, so small i didn't notice it even after MULTIPLE times of inspecting them. He swapped the calipers and BOOM, he can lock his fronts like no joke.
Are you sure you don't have a leak in one of your pots???? Because of your symptoms, i'm going to lean toward this.
DHRDAN is offline   Reply With Quote
Old 11-12-2009, 10:40 PM   #23
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Check.
First brake mod.
Got the Perrin.
Going back to EBC reds in front. Not particularly happy with the HPS's.
Too true. Tragic that FHI let it out of the factory like that.
Old 11-12-2009, 10:41 PM   #24
wrxmuch?
Member#: 196486
2004 WRX
If I had a leak wouldn't my brake fluid level go down slowly over time?
Old 11-12-2009, 10:48 PM   #25
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
This is what i argued with my brother about over and over again. I said his fluid level would drop, he would see leaks.
However i was wrong, he swapped his fronts for aftermarket infinity breaks and he fixed the problem.
I even rebuilt his old breaks, but for some reason they leaked. We would sit there and bleed them for hours, i'm not kidding, it was a huge deal. However he was right, the calipers where leaking, now sure how, but there were.
If I install a front big brake kit, is there any way the stock front will fit rear? bullittman68 Brakes, Steering & Suspension 9 01-19-2010 08:25 PM
Vibration through the pedals at 50-60 mph... help! yellowmellow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-12-2006 10:16 PM
Problem with battery: water is bubbling up through the little screw caps Shadow_Viper Service & Maintenance 4 07-18-2005 05:41 PM
B-FORCE for Street. (This brake pad is a product for the United States.) vividracing Vendor 'For Sale' Classifieds 4 01-22-2004 03:25 PM
help, my clutch pedal is mushy! SUBACHI Transmission (AT/MT) & Driveline 1 07-08-2003 01:15 PM
