Welcome to the North American Subaru Impreza Owners Club Wednesday October 17, 2018
Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 11-30-2008, 06:32 PM   #151
olig
Member#: 192443
Would these work?
http://cgi.ebay.com/ebaymotors/JDM-V...Q5fAccessories
If not, could someone link any that would work.
Not alot of coils here in iceland...
olig is offline   Reply With Quote
Old 11-30-2008, 06:44 PM   #152
keirnna
Member#: 50167
1996 Subaru STI RA
Those are stock replacements. They will have just as many problems as the ones you already have. You need US 2002+ EJ20 coil-packs.
keirnna is offline   Reply With Quote
Old 11-30-2008, 06:53 PM   #153
olig
Member#: 192443
Allright, thanks for the quick answer.
US only?
Old 11-30-2008, 06:54 PM   #154
keirnna
Member#: 50167
1996 Subaru STI RA
No, but the model years are different elsewhere. Basically any bug eye coil pack will work. 2000+ if Japanese.
Old 12-10-2008, 09:51 AM   #155
tizer
Member#: 197120
Hi. I have a 95 WRX that has had an engine swap and it turns out that it actually now has a legacy engine the one that uses the twin bolt coils. I still have the old engine with the 1 bolt cols and was wondering if I could swap the rocker covers over so I can use 1 bolt coils in the legacy engine. Or do the coils bold in the cylinder heads as well?
I have already modified the 1995 1 bolt coils to fit the legacy engine so Im sure I could do if to the 2002 coils as well I just wanted to know if changing the rocker covers is another option since I have them anyway
tizer is offline   Reply With Quote
Old 12-18-2008, 05:14 PM   #156
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
Just a note for anyone looking at their original coilpacks. The back of the coilpack is filled with a clear white resin. If this resin turns black, it usually means the coilpack is no good - even if you can't see any cracks.
rockcrete is offline   Reply With Quote
Old 12-18-2008, 05:35 PM   #157
keirnna
Member#: 50167
1996 Subaru STI RA
Not all of them came from the factory clear like that. Some came black.
Old 12-19-2008, 12:30 AM   #158
sniper512
Member#: 189923
1993 JDM WRX
Mine are now discoloured brown lol and 2 are cracked to hell. I need new ones bad. I am still looking for a good used set of 02+ WRX coils
sniper512 is offline   Reply With Quote
Old 12-19-2008, 12:23 PM   #159
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
I just got a brand new set of replacements from Japan for mine - sure starts and runs a lot better now.
Old 12-23-2008, 10:55 AM   #160
sniper512
Member#: 189923
1993 JDM WRX
How much and where?
Old 12-23-2008, 11:47 AM   #161
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
Mine were a favour from a friend, but you can buy them online here at a decent price: http://www.grahamgoode.com/subaru/pa...93&item=GGS564
You may even be able to order them locally, the part number is 22433AA330
Old 01-08-2009, 05:15 PM   #162
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
so in a nutshell
get 4 02 wrx ignition coils, cut old ones, solder these in, cut off the wire and done?
JDMFLCL is offline   Reply With Quote
Old 01-08-2009, 05:21 PM   #163
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
then straight wire the ignitor^^^^^ and make a ground for the usdm coils to ground where the bolt holds the coil down.
gc8awdsti is offline   Reply With Quote
Old 01-08-2009, 09:48 PM   #164
sniper512
Member#: 189923
1993 JDM WRX
Just ordered a brand new set from Subaru today. I should have them in about 4 days. I'll let you know how my hesitation and power loss works out.
Old 01-13-2009, 12:53 AM   #165
sniper512
Member#: 189923
1993 JDM WRX
So the new coils are in and the misfire issues at idle are gone. The car is more responsive, but the car is still sometimes feeling like it has no power when you go wide open. The car is building full boost quick as usual. Its almost like the car isn't using the boost if that makes any sense.
Old 01-13-2009, 01:12 AM   #166
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
boost leak possibly^
Old 01-13-2009, 10:07 AM   #167
sniper512
Member#: 189923
1993 JDM WRX
So even with building full boost like normal it could be a boost leak hmmm........I wonder if it could be the recirc valve?
Old 02-06-2009, 05:00 PM   #168
random112
Member#: 168594
1993 JDM GC8 WRX
silver with dirt
Default latest
Sniper
Whats the latest on this? Sort out your issues?
What part number did you use to order them here in canada? Or did you get the UK versions?
I am running 93 jdm wrx here in vancouver. Some of the same problems, knocking sound at full boost, hard starts when warm, etc.
cheers
random112 is offline   Reply With Quote
Old 02-06-2009, 11:51 PM   #169
sniper512
Member#: 189923
1993 JDM WRX
I will have to look up the part number again. Basically any USDM 02+ WRX coils will work. One of the benefits to ordering new is that there have been several updates to the coils in the past few year. If you go into a dealer just get them to look up the latest coil for a 02 WRX.
I think I got it figured. The car came with some NGK platinum one step colder so #7's. I replaced these with NGK Lasers at the stock heat range #6's. This caused lots more misfires at idle. When I did the coil conversion it helped, but there was still a problem. I changed back to the plugs that came with the car and it was way better. Today I said screw it and got a set of Copper NGK BKR7E's because I was still seeing some misfires at idle. After the change to the cheap coopers the car is running amazing. I think my issues were both the coils and the plugs.
I think it is weird that I need to run colder plugs to not have misfires at idle could this mean that my ECU is tuned from Japan? or is it possible I have another issue going on?
Cheers
Old 02-07-2009, 09:49 PM   #170
sniper512
Member#: 189923
1993 JDM WRX
Well another update problem is not fixed. Power loss was gone for about a day and now intermittent power loss is back. Time to burn it.
Old 02-17-2009, 09:53 PM   #171
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
i converted mine to 05 sti coils... and i was in 3rd... WOT... and it still mis fired 2 times.. ( i heard it )... but i tried it again... it worked.... idk i guess it just reduced the occurrence for me..
azn0boi04 is offline   Reply With Quote
Old 02-25-2009, 01:54 PM   #172
luka
Member#: 194742
1993 Impreza WRX JDM
Well, I'm glad at least we're all in the same boat, I seem to have it the worst with the power loss issue but we're all experiencing the same misfires / power loss / unused boost (yeah, really weird) / relay click.
first one to solve it gets a cookie :P
luka is offline   Reply With Quote
Old 03-04-2009, 04:29 AM   #173
97sportwaggie
Member#: 171770
1994 Impreza Wagon
Dark Silver Mettalic
Add another to the conversion list. I felt like a geniuus after all the soldering and wires cutting etc...
97sportwaggie is offline   Reply With Quote
Old 03-04-2009, 07:38 AM   #174
olig
Member#: 192443
So it works for some people and some it doesn't ?
Anyway, can I use these?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=170306922175
This is what I am looking for right?
+ I do not have the Ej20G from an Impreza but from a (JDMyo)Legacy.
Does this matter?
From what I have seen there is a slight difference with the coils.
In the Impreza(this i have only seen on ebay) there is only 1 bolt that goes in the coil(to keep it in place) but on mine there are 2.
My country is broke and so am I so I am really concerned for buying the wrong coil.
Old 03-04-2009, 01:08 PM   #175
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Does this matter?
Yep, those are the ones.
I would say the conversion works for everybody. However some people have other issues that they suspect are ignition related, but turn out to be something else. I have been running strong ever since I first posted this conversion, and now I'm up to around 320chp with no hint of ignition trouble.
Since you have the Legacy motor, you will have to modify the new age coils a bit to fit the cam cover. Someone posted a really good detailed description of what to do (thought it was earlier in this thread). If you cant find it, I'll see if I can repost as I think I save the pictures.
-Rob
rob is offline   Reply With Quote
WTB: WRX coil packs for the EJ20G coil pack conversion ASAP! Joshb120 Private 'Wanted' Classifieds 2 05-18-2008 12:42 AM
2000 Intake manifold, EJ20G Intercoolers, EJ20G coil Woki Toki Engine/Power/Exhaust 3 04-18-2008 11:54 PM
EJ20G coil resistance? snowman4us Pre-2002 Factory Turbo Powertrain 4 11-15-2006 01:52 PM
EJ20g Coil on Plugs newgensti Subaru Conversions 7 09-15-2006 11:07 AM
EJ20G coil packs scoobyimprza Subaru Conversions 2 08-29-2005 01:36 PM
