Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 11-18-2012, 07:00 PM   #101
ogintheback
Member#: 99163
I'm having a problem filling the gas tank (tried several different gas station to make sure it wasn't a bad pump at the station) - the nozzle shuts off over and over and over - making it take forever to fill the tank. Start up is fine. Would removing the purge valve correct this?
05 STi, stage 2.
ogintheback is offline   Reply With Quote
Old 11-18-2012, 10:03 PM   #102
EvenSteven
Member#: 156542
I dont think it could be the purge valve. It sounds like something is clogging or restricting your filler neck. Or possibly something around the charcoal canister.
EvenSteven is offline   Reply With Quote
Old 11-29-2012, 05:24 AM   #103
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
This is a bit confusing. On some cars, the bottom hose from the solenoid goes to the intake manifold, however it's reversed for others. What are the symptoms that the hose is on the wrong nipple?
Old 11-29-2012, 09:46 AM   #104
ogintheback
Member#: 99163
05 STi, stage 2.
Update: Sent someone over to one of the gas stations to fill his truck and he had the same issue. When I was filling up the other day, I was paying attention to other people at the same station and noticed they were having the same issue. These are at local Shell stations....maybe the pumps are a bit sensitive?
Sorry to get OT, but wanted to give update.
Old 11-30-2012, 03:36 PM   #105
grinch77
Member#: 198758
2004 STi
So is this correct?
grinch77 is offline   Reply With Quote
Old 11-30-2012, 03:49 PM   #106
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
looks to be correct. I just installed a JDM unit with JDM hoses this past weekend on a 2002 US WRX and routed it the same way.
[email protected]
IA Performance is offline   Reply With Quote
Old 11-30-2012, 04:03 PM   #107
grinch77
Member#: 198758
2004 STi
Old 11-30-2012, 04:14 PM   #108
ogintheback
Member#: 99163
I did mine last night and had the hose coming from the gas tank going into the nipple with the arrow (was the nipple on the outer edge of the pcs for an 05 STi) - which left the hose that is connected to the intake manifold in its original position.
Old 12-05-2012, 10:35 PM   #109
grinch77
Member#: 198758
2004 STi
Car runs soooo much better after doing this. I was having a bad idle problem guess all the old hoses had cracks and was causing vacuum leaks.
Old 12-14-2012, 02:38 PM   #110
ogintheback
Member#: 99163
Bump for updates. I have mine routed as stated in post 108 and grinch has his routed as shown in post 105. Which hose connects to the arrow? Is mine reversed? Is the purge valve to add pressure to the tank or vacuum on the fuel tank (I would imagine the later)?
Old 12-15-2012, 11:42 AM   #111
IA Performance
Member#: 25194
Dark Gray
Hopefully this image will help clarify things for 2002-2004 WRX owners. This is a JDM ver7 evap purge solenoid with the OEM JDM hoses attached. It is different on 2.5L models.
Simply mimic this image and then cap off the 2 unused ports (turbo inlet, intake manifold) and you are done. The image on post #1 does not depict it this way, so I'm not sure if that is a mistake in the OE manual.
Old 12-16-2012, 10:53 AM   #112
ogintheback
Member#: 99163
Thank you IA P! I can't see the arrow in the image. Do you remember which port had the arrow?
Old 12-16-2012, 11:37 AM   #113
IA Performance
Member#: 25194
Dark Gray
I do not recall which had the arrow. This particular unit was installed in a customer's car a few weeks back so I do not have it to reference. If I were you I would run out to my car and look to see which nipple has which hose. The 02-05 WRX were all the same. I want to say my 08 FXT is also the same, leading me to believe the 02-07 WRX were setup the same way.
Furthest nipple from the electrical connector = goes to intake manifold
Closest nipple from the electrical connector = goes to return hose back to gas tank
Stephen
Old 12-16-2012, 11:56 AM   #114
ogintheback
Member#: 99163
My purge control is just like grinch's. I do have my hoses the opposite of his though thinking that the arrow indicates flow direction.....meaning from fuel tank to valve to intake. Sorry, not trying to be slow here.
Old 12-16-2012, 01:05 PM   #115
IA Performance
Member#: 25194
Dark Gray
I'm working on some manuals now for a whole new Thread. The new thread will start with several factual posts to help clear up the Evap Purge dilemma that many have run into. I, like many, am finding there are vast differences out there between models and figured a central learning thread would be best.
Details to follow once it is listed. Here is direction that I've started with (rough draft):
I flipped through a few manuals and came up with the following diagrams that correspond accordingly:
2002 WRX = Diag A
2003 WRX = Diag A
2004 WRX = Diag A
2005 WRX
2006 WRX = Diag B
2007 WRX
2004 STi = Diag B
2005 STi
2006 STi = Diag B
2007 STi
[email protected]
Old 12-16-2012, 02:54 PM   #116
ogintheback
Member#: 99163
Thank you Stephen! I think what caused the confusion is that they flipped the pcs ports.
Old 12-26-2012, 06:29 PM   #117
Ed05WRX
Member#: 319401
05 WRX
WR BLue
I did the Jdm way, but every time I fill up gas at try to start my ignition it take a few seconds and then idles like it wants to die ,but once I gas it a little it starts idleing fine
Ed05WRX is offline   Reply With Quote
Old 12-28-2012, 01:56 PM   #118
IA Performance
Member#: 25194
Dark Gray
Ed05WRX- would you happen to know which Diagram matches your factory system before setting it up the JDM way? Please see post 115. My guess is your 05 WRX best matches Diag A, but please let me know and I'll try to better assist with the rough idle.
Stephen
Old 12-28-2012, 03:25 PM   #119
Ed05WRX
Member#: 319401
05 WRX
WR BLue
Originally Posted by IA Performance View Post
Here is another option, it is free and avoids the hassle of the hoses coming off in the future. This is how the JDM ver7/8 STi cars are setup. We have lots of customer cars running this configuration without any CELs or negative side affects.
This is what I did, because my purge valve broke and don't wanna spend 150 for a piece of plastic.
Old 12-28-2012, 03:29 PM   #120
IA Performance
Member#: 25194
Dark Gray
so did your factory system look like Diag A or B in post 115 before the work?
Also, did the electronic purge valve break or the diaphram thing that is round in shape?
Stephen
Old 12-28-2012, 03:45 PM   #121
Ed05WRX
Member#: 319401
05 WRX
WR BLue
Stephen
Diaphragm B looks like my old set up but don't remember very well. The round piece purge valve, not the soleniod piece.
Once it fills up and I start driving it runs and turns on nicely,but every time I fill up and turn the car on it kinda acts like it doesn't want to turn on and after a 2second or so it turns on and idles real weird and sounds like it wants to die.
Old 12-28-2012, 05:23 PM   #122
pimpsterrr
Member#: 230100
oh yea i have a 2004 wrx too. forgot to mention that
i am having the same idle issue that ed05wrx is having after doing this. driving around is fine but if i am just idling it starts to idle like it wants to stall out and the lights will dime in and out as the idle slows/goes way down.
i have it set up like diagram A right now with the plug closest to the sensor going under the intake mani and the plug furthest away from the sensor going up to the nipple pointing down.
but before i did this it was set up opposite like diagram B. the plug closest to the sensor went up to the nipple pointing down and the one further away going under the intake mani
I don't know if this could be the reason for the rough idle or maybe my battery is on its way out but you seem to know way more about this than i do so any help would be great! but either way my check engine light did turn off! which i am greatful for.
thanks!
pimpsterrr is offline   Reply With Quote
Old 01-04-2013, 01:33 PM   #123
WrxFtw02
Member#: 231192
PROs Tuned 270/251
I have the same problem both of the above posters are having!!! I have a 2002 wrx and it was set up like diagram b
WrxFtw02 is offline   Reply With Quote
Old 01-04-2013, 09:34 PM   #124
IA Performance
Member#: 25194
Dark Gray
WRXFTW02- The 02 WRX should be setup like Diagram A. If you were to make it like the JDM car then:
- Keep hose showing in FU0002
- Remove everything shown in FU0365
- Replace the removed parts with a new hose that connects from the solenoid to the metal fuel rail line.
The end result should be something that looks like the image in post 111. Are there any check engine lights?
Stephen
Old 01-05-2013, 11:59 AM   #125
Ed05WRX
Member#: 319401
05 WRX
WR BLue
Any idea?
WTB: Purge control solenoid valve jblaine Private 'Wanted' Classifieds 7 04-21-2009 08:51 PM
Purge Control Solenoid valve? Synx Service & Maintenance 4 07-02-2008 05:40 PM
Broken Nipple on Purge Control Solenoid Valve 48mpg Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 02-24-2008 07:40 PM
Purge Control Solenoid Valve?? abosworth Normally Aspirated Powertrain 3 07-21-2005 04:20 PM
Code 35 purge control solenoid valve troubles theascen Service & Maintenance 2 04-02-2004 04:36 AM
