Welcome to the North American Subaru Impreza Owners Club Friday July 20, 2018
Old 03-03-2013, 12:13 PM   #1
mntnresq
Member#: 304288
Default Help- '04FXT Eating Turbos
Hey all- Looking for thoughts on this. My 155K '04 FXT is about to be on it's 4th TD04 in less than a year. Seems to be a lubrication issue- keeps eating the center bearings.
Car is stone stock, save for a Samco inlet I swapped with the last turbo, since the stock one broke during the swap. It is not driven hard- it's my GF's ride, and she drives it pretty infrequently.
The original TD04 went at about 145K, and I swapped with a fairly low mile used one. That lasted about 7k, and then ate itself. I wrote it off as being a not perfect used turbo. Bought a quality reman TD04, and swapped it. 3K later, here we go again.
Each time, I checked all the oil lines are clear, and any chunks it threw are cleaned out. The filter screens have all been removed, and I used a quality synthetic oil, and made sure it was never low. Gave it plenty of gentle driving to break in. I've never gotten any low oil pressure indications, and the rest of the motor is still tight, no smoke, no oil consumption, etc.
Any other thoughts on what other oiling issues I might have, or why these keep eating themselves? I'm stumped.
mntnresq is offline   Reply With Quote
Old 03-03-2013, 03:56 PM   #2
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
Is the banjo bolt the correct one and is it completely clean?
How do you know that the feed line is clear?
FCmaniac is offline   Reply With Quote
Old 03-03-2013, 06:13 PM   #3
mntnresq
Member#: 304288
Well, have to presume it is the correct banjo. was the original one on the car, with the original turbo, which lasted 145K.
The filter screens are all out, and I both chased the feed lines with a piece of cable, and blew them out with an air compressor @ 150psi.
It does seem to be getting good oil pressure to the turbo, I cracked the banjo fitting loose at idle this morn, and it spewed oil.
Others have suggested maybe the cat in the up pipe is blowing chunks. Could be I spose, but I haven't heard anything that would suggest that.
Old 03-03-2013, 06:17 PM   #4
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
Yeah you need to get rid of that up pipe. it is most certainly blowing out bits of cat material and eating your turbos. This is very common and should be replaced.
Edit: Replaced with a catless up-pipe.
endrswrd is offline   Reply With Quote
Old 03-04-2013, 12:47 AM   #5
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
Replace up pipe with cat less one.
Did you make sure you got oil to the turbo before running the car?
You should be pulling the ECM fuse and cranking the car over for about 15 seconds before you start the car. If your not doing this after you install the new turbo then your oil starving it on first start up. That will shorten its life a lot.
Make sure the drain tube is clear as well. If the oil has no where to go it will back up in the turbo and coach the bearings, and that will cause it to fail.
If the up pipe cat is bad you will see it in the turbine wheel. It will be chewed up from ingesting cat bits.
Replace it ether way. At this point its a time bomb.
Badmunky is offline   Reply With Quote
Old 03-07-2013, 10:28 PM   #6
mntnresq
Member#: 304288
Yes, I did pre-oil both of the last two turbos. I believe the drain side is clear, but will try to verify again when/if I pull this one off.
Old 03-07-2013, 11:40 PM   #7
[email protected]
Member#: 301037
2004 Forester XT
That's an expensive meal!
art@grimmspeed is offline   Reply With Quote
Old 03-08-2013, 01:11 PM   #8
donkey_cart
Member#: 151448
2008 OBXT 5spd
Grey
My friend had the same thing happen with 2 used TD04s. One of turbos only had 40k and looked brand new, but still took a dump. Both were under stock tune and had proper priming. The third turbo was brand new and has never had an issue in 10k miles.
Lesson: used turbos are used
If there is any way you can measure your oil pressure, check that too. Even though you may be getting pressure to the line, it may not be enough to keep the center bearing happy. A small clog or leak somewhere in the system (oil pickup tube) could cause low pressure, but not enough to do damage an a stock car driven easily. Chunks of old center bearing can make their way deep into the engine.
donkey_cart is offline   Reply With Quote
Old 03-13-2013, 02:11 AM   #9
mntnresq
Member#: 304288
It's certainly getting that way!
I hate to say it, but I'm half tempted to trade this one in on a newer one with less mi. LOVE this FXT, and it is really in great shape, but between turbos, the cold wx fuel leak prob, timing belt replacement probs, and oil leaks, this thing has cost me about half what I paid for it over the last year and a half...
Old 03-13-2013, 02:14 AM   #10
mntnresq
Member#: 304288
Well, that was what I figured after the second one went, it was a used 60K unit. But, this is a reman from a reputable builder ($600!) that I thought would last for another 100K. Been about 4K. I spose it's possible I just got a lemon, but seems less likely.
Grrrrr.
Old 03-13-2013, 09:22 AM   #11
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Grrrrr.
That sucks, i feel your pain. I'm in the "probably the cat going to pieces" boat.
Old 04-20-2013, 01:32 PM   #12
mntnresq
Member#: 304288
Ok.... I got the current dead turbo off, and the up pipe looks fine. Oiling problem. Looks like I missed the banjo filter in the one at the back of the head. it is pretty full of metal chunks, on the upstream side of the screen.
So, for one, I doubt that the rebuilder will warranty the turbo, as this is pretty much my fault. That was a nice $600 in the toilet. But, more concerning to me are the metal chunks in the oiling system. I haven't dropped the oil pan (yet) but the dipstick is clear, no obvious big chunks, nor metallic-paint look to the oil.
Should I just slap the cheapest used TD04 back on this, and sell/trade it in before the motor goes boom? I can't say I'm real excited about dropping the pan (kinda afraid of what I will find) but will if need be. But, if experience from other folks says it's a time bomb no matter what I do, then I guess there is no point in bothering.
Thoughts?
Old 04-20-2013, 01:46 PM   #13
stevejones19
Member#: 275250
2006 WRX
Thoughts?
Well you sure sound like a stand up individual. You should fix your car.
stevejones19 is offline   Reply With Quote
Old 04-20-2013, 02:10 PM   #14
mntnresq
Member#: 304288
Well, pulled the pan, and it is full of shiny bits. Guess that answers that ques.
Old 04-21-2013, 08:47 PM   #15
nacoffee
Member#: 354167
Default need a turbo
Have an 05 forester xt that the turbo went out on this afternoon. Where is the best place to buy an OEM turbo new, used, or rebuilt?
nacoffee is offline   Reply With Quote
Old 04-22-2013, 02:11 AM   #16
lavid2002
Member#: 226864
lol nacoffee. I'm chasing you forum to forum.
OP.. no knocking from the engine? Your main + rod bearings are probably not very happy with the oil they have been getting.
Old 04-22-2013, 08:21 PM   #17
Xx02rexxX
Member#: 331883
04 forester xt 5mt
jbp
ABSOLUTELY NOT!!!! Dont just f someone bc you're tired of it. i own a 04 fxt 5mt with 191k on it and its just awsome.. dont sour someone else's taste with you're mess.
Xx02rexxX is offline   Reply With Quote
