Welcome to the North American Subaru Impreza Owners Club Thursday April 18, 2019
Old 04-10-2019, 10:13 PM   #1
pyraxv
Member#: 493972
2002 built wrx/sti
grey
Default No Oil Pressure!!!
Hey guys. i just finished my hybrid wrx build with an 11mm Orbit pump.
I have tried almost everything including filling the bottom of the pump through the bolts with assembly lube, cranking the engine over for 30 seconds to a minute, and taking off the oil filter.
I installed the pump completely dry. no lube whatsoever. Ive tried over and over again but nothing. Its a brand new pump. How can i get oil pressure?
heres a video
pyraxv is offline   Reply With Quote
Old 04-10-2019, 10:43 PM   #2
JSR84
Member#: 469585
You can try pulling the plugs and getting some more RPM out of the started. I made the same mistake in my build by not packing the pump. I talked to IAG and they told me to send it and be ready to shut it off if I didn't get any oil pressure. So, I did and it had oil pressure immediately. Not ideal, but lesson learned.
JSR84 is offline   Reply With Quote
Old 04-10-2019, 11:17 PM   #3
pyraxv
Member#: 493972
2002 built wrx/sti
grey
Originally Posted by JSR84 View Post
You can try pulling the plugs and getting some more RPM out of the started. I made the same mistake in my build by not packing the pump. I talked to IAG and they told me to send it and be ready to shut it off if I didn't get any oil pressure. So, I did and it had oil pressure immediately. Not idea, but lesson learned.
plugs are already out. i think ill send it. how many seconds should i wait if i dont get oil pressure? If not immediately, should i shut it off? thanks
Old 04-10-2019, 11:52 PM   #4
JSR84
Member#: 469585
I'm not going to give you a number, all I can say is I didn't even get a chance to start counting.
Old 04-11-2019, 12:28 AM   #5
pyraxv
Member#: 493972
2002 built wrx/sti
grey
got it if its not instant, ill shut it off
Old 04-11-2019, 08:49 AM   #6
Delphi
Member#: 239335
2011 WRX
I'd say about 1 second and if it doesn't get oil pressure kill it.
Did you check the back plate on the oil pump?? I've heard they can be loose on the ACL pumps.
Delphi is offline   Reply With Quote
Old 04-11-2019, 10:44 AM   #7
pyraxv
Member#: 493972
2002 built wrx/sti
grey
i havent. wouldnt there be a leak if it was loose? and wouldnt i see it while cranking? regardless, ill be taking the pump out to inspect it and pack it if i dont get oil pressure after one second of running timing
Old 04-11-2019, 11:32 AM   #8
Delphi
Member#: 239335
2011 WRX
You won't see it if you're cranking. It is the plate that holds the gears inside, I have heard they can be loose not allowing the pump to build as much pressure due to leakage.
If you do pull it apart, loctite the screws in with some blue and it won't come apart.
Old 04-11-2019, 11:50 AM   #9
pyraxv
Member#: 493972
2002 built wrx/sti
grey
ill definitely do that if i end up pulling it. Its an 11mm pump and i have a fully built short block. Do you know what good oil pressure would be? idle and under boost and vaccum? thanks
Old 04-11-2019, 11:59 AM   #10
Delphi
Member#: 239335
2011 WRX
20 psi at idle with 1000 rpm is good.
70+ psi under load.
Really all you need to worry about.
Where is your sending unit located? Under the alternator or the rear one by the crank case breather.
Old 04-11-2019, 12:01 PM   #11
pyraxv
Member#: 493972
2002 built wrx/sti
grey
70+ psi under load.
under the alternator
Old 04-11-2019, 05:00 PM   #12
thewolfe
Member#: 427424
2014 wrx hatch
black
I made the same mistake with my build. Would never build oil pressure while cranking. I unscrewed one of the bolts on the bottom of the oil pump housing and squirt assembly lube up in there with a hose. You have to get it up in the gears. The next crank I had oil pressure within seconds.
thewolfe is offline   Reply With Quote
Old 04-11-2019, 05:19 PM   #13
blurred
Member#: 47143
If you just did a fresh build you should have the oil feed off the turbo and pushing that oil into a bottle to make sure theres no crap in there, and also to ensure you actually have oil flow!
Do that first and crank it to ensure its all primed (and also to make sure you put oil in the car )
the attach the feed and fire it up.
blurred is offline   Reply With Quote
Old 04-11-2019, 05:44 PM   #14
pyraxv
Member#: 493972
2002 built wrx/sti
grey
how did you reach all the way up there?
Old 04-14-2019, 08:04 PM   #15
Gasguzziler
Member#: 473806
Going gonna have to remember this
Gasguzziler is online now   Reply With Quote
