Welcome to the North American Subaru Impreza Owners Club Thursday April 18, 2019
Old 04-12-2019, 06:16 PM   #1
forester04xt
Member#: 452493
2004 FXT
Default EJ255 - Timing Belt Questions
I have a 2004 Subaru Forester XT and I had to do a valve job on it. Well long story short, I have the heads back on and have the valve clearance correct, and the next step is the timing belt. The crank was rotated when the heads were off to inspect the cylinder walls
My question is, once the heads are on, how do I know that the engine is at top dead center? If the mark on the crank pulley is lined up to the line on the block(oil pump) does that mean it is at TDC? I read somewhere that the motor has to make a few revolutions before cylinder #1 is at TDC.
Thank you for any info, and I would like any other tips for doing timing belts also.
forester04xt is offline   Reply With Quote
Old 04-12-2019, 10:50 PM   #2
Subie_
Member#: 419354
2007 STI
Crystal gray metallic
The timing belt doesn't get installed with any piston at TDC.
That aside, I like to find TDC by inserting a metal rod through the spark plug hole which contacts the face of the piston and I use a dial indicator gauge.
Subie_ is offline   Reply With Quote
Old 04-13-2019, 08:09 AM   #3
jeff6666p
Member#: 400078
1998 impreza 2.5rs
black
Line up all your marks and put the belt on. after you release the pin for tensioner turn the motor a few times by hand to make sure the valves don't hit. If you take the plugs out it will be easier to turn and feel.
jeff6666p is online now   Reply With Quote
Old 04-13-2019, 12:04 PM   #4
JSR84
Member#: 469585
This. Timing on these engines is quite easy to do. You'll need either a second set of hands or something to old the left hand Cam's in position while you align the belt. As jeff6666p said, spin it over twice and see if everything goes smooth and lines up again.
JSR84 is offline   Reply With Quote
Old 04-14-2019, 08:27 PM   #5
forester04xt
Member#: 452493
2004 FXT
Thank you for the info! I'll be doing it next weekend!
Old 04-14-2019, 09:22 PM   #6
viper_crazy
Member#: 298403
2008 WRX Premium
Spark Silver
Big binder clips, if you have any, can help hold the belt in place on the cam gears. I keep a few in my tool box for various things; holding stuff (wire harnesses, hoses, etc) out of the way when working on stuff, even soldering.
viper_crazy is offline   Reply With Quote
Old 04-15-2019, 10:26 AM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Correct, Subaru 4 cylinder engines have the pistons at mid stroke UNLIKE most other engines when doing the valve timing/timing belt.
Once everything is lined up and tensioner has been sprung a few minutes, I spin the crank clockwise multiples of 2 times and recheck the timing marks.
Note, the marks on the belt will no longer match the crank and cam marks. Not an issue.
Charlie-III is online now   Reply With Quote
Old 04-15-2019, 12:46 PM   #8
Compendium
Member#: 498453
Have a gander at your MY Service manual for a detailed step by step. Try searching for the pdf, or you may be able to get away with the 2004 wrx/sti equivalent if the engines are the same. below are the WRX/STi links for each MY and one link I found for the 04 Forester. it will be in the Mechanical section under Timing Belt. along with a plethora of other handy info for any DIY you want to tackle.
Lastly have a watch of the youtube link of a detailed timing belt change on an EJ from my local shop.
http://www.wrxinfo.com/service_manuals/
https://www.manualslib.com/manual/12...004%20FORESTER
Compendium is offline   Reply With Quote
