Welcome to the North American Subaru Impreza Owners Club Thursday April 18, 2019
Old 04-14-2019, 06:54 PM   #1
Shake-n-Bake
Member#: 324646
2007 WRX Wagon
Default Smoke from exhaust after AOS install
Hi all, looking for some help with an issues I recently started happening. I just installed the IAG AOS Street Series on my 2007 WRX. After everything was put back together, I started it up and noticed smoke coming out of the exhaust. Oil burning smell. I decided to go back and look over all the connections. After pulling the IC, I noticed the line for the PCV line was kinked. Ran it a different way, put the IC back on and started it up. Everything was now clear at idle, but when I let it get to temp and gave it some gas, started smoking when revving engine. Checked the oil and it was fine. I did spill a fair amount of coolant from the turbo when disconnecting that line. I proceeded to fill and burp the system 3 times. Coolant levels remain full. Haven't driven the car, only let idle. Any ideas what the cause of this might be? Car never smoked before, only a little on startup since it sits for days without use. Mods are:
Cobb stage 2 tune
Invidia catted downpipe
Cobb catback exhaust
94k on motor and turbo
Thanks in advance.
Shake-n-Bake is offline   Reply With Quote
Old 04-14-2019, 11:36 PM   #2
pyraxv
Member#: 493972
2002 built wrx/sti
grey
check the routing for the lines of the AOS. Incorrect routing may have played a roll in this.
pyraxv is offline   Reply With Quote
Old 04-15-2019, 10:51 AM   #3
Shake-n-Bake
Member#: 324646
2007 WRX Wagon
Thank you, and will look over those lines again. Also reached out to IAG for some help as well. pyraxv Do you have the IAG Street Series AOS?
Old 04-16-2019, 01:10 AM   #4
binny
Member#: 198108
MY98 WRX
You will have oil in the intercooler either take it off and clean it out or give it some boosting until the smoke goes away
binny is offline   Reply With Quote
Old 04-16-2019, 07:57 AM   #5
Shake-n-Bake
Member#: 324646
2007 WRX Wagon
That's a good thought, thank you. Will look at that and report back.
