Welcome to the North American Subaru Impreza Owners Club Thursday April 18, 2019
Old 04-14-2019, 08:07 PM   #1
Gasguzziler
Member#: 473806
Default Can someone help identify these hoses
Putting this New shortblock in and rebuilt heads and a couple of these hoses were brittle from 155k miles and broke while taking them off. Been looking at online parts diagrams but can't find what I'm looking for. Car is a 2007 wrx.
Gasguzziler is online now   Reply With Quote
Old 04-14-2019, 10:57 PM   #2
ilovedemhotrides
Member#: 326147
I think if you just got the mishimoto ancillary kit it would replace these. Double check
ilovedemhotrides is offline   Reply With Quote
Old 04-15-2019, 05:44 AM   #3
MortonCharbo
Member#: 487057
2002 WRX Wagon
Those are breather lines for the vents by the valve covers. That one in the second picture is about 35 bucks from Subaru. I either have a spare, or can get you the part number next time I'm in the garage. I just replaced the same hose on my engine.
That smaller one looks like 99071AB352
It's just a 90 degree elbow right?
Try 99081AA060 for the one on the left side (if you're facing the front of the engine)
Still trying to find the other hose.
MortonCharbo is offline   Reply With Quote
Old 04-15-2019, 08:12 AM   #4
Blktrax
Member#: 220971
2002 WRX 223K Mi.
90 Deg Elbow = HOSE-VACUUM = 99071AB352
Left Driver PCV = HOSE ASSEMBLY-PCV = 11815AB960
Right Passenger PCV = HOSE ASSEMBLY-PCV A = 11815AB143
Would strongly recommend you replace the main PCV assembly just below the turbo.
Assembly = HOSE ASSEMBLY-PCV = 11815AB711
Blktrax is offline   Reply With Quote
Old 04-15-2019, 08:22 AM   #5
MortonCharbo
Member#: 487057
2002 WRX Wagon
I second the recommendation to replace the pcv.
I think the third part you listed is different. I remember changing that hose too when I was going through my engine. It's quite a different shape.
99071AB333 is the part number for the hose on the right side (looking towards front of engine)
If you look at parts.subaru.com look under the engine category, in the "water pipe" section. You'll find most of the hoses there. You might want to replace more.
Old 04-15-2019, 01:10 PM   #6
Gasguzziler
Member#: 473806
Thanks everyone, this is quite helpful
