Welcome to the North American Subaru Impreza Owners Club Sunday November 28, 2021
Old 09-11-2021, 04:22 PM   #1
jeff6666p
Member#: 400078
1998 2.5rs06wrx swap
black
Default Autox sway bar set up question
I read if you put a bigger front sway bar your get quicker turn in. If you put a bigger front bar on but then put a larger rear bar on does it negate the turn in response from the bigger front bar?
jeff6666p is offline   Reply With Quote
Old 09-11-2021, 05:42 PM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
if you put on a larger rear sway bar you get more rotation. I would more use the front bar if you need more stabilization in the middle of a corner
Old 09-13-2021, 11:01 PM   #3
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
All changes affect the balance and particular handling characteristics of a car. Depending on the relative bar sizes front and rear, and the spring rates and dampers a bigger rear bar can negate the turn in response from a larger front bar. That is where balancing spring rates and bar rates becomes important.
My '96 XP autocross car for instance ran 800 lb/in front and 600 lb/in rear springs with a 22mm front bar and no rear bar for a very balanced and active suspension.
Also very important is the alignment. It has as much effect on handling as any other component in the car.
