Welcome to the North American Subaru Impreza Owners Club Sunday November 28, 2021
Old 09-18-2021, 04:41 AM   #1
alexmartynyuk
Member#: 191967
2005 EVO VIII
instagram @boost_reality
Default Reserved thread for cars tuned by me for your entertainment
Hello everybody, my name is Alex as you may already know by my username. I have been meaning to start a thread and post the cars I tune, some of you may find it entertaining.
Most of these cars will be Subarus, although if its ok with the mods I might throw in some other cars here and there but I will try to keep it strictly Subaru related.
Short story about why I tune: I got into tuning many years ago after getting my bugeye wrx. I quickly figured you can't just bolt thing on without a tune. Also figured out that tuning is extremely expensive! So I started reading a lot and making small changes to the tune on my personal vehicle. As the years went on I got more experienced at tuning and started tuning other peoples cars.
Most of these will be logs ran through Virtual Dyno and may not be as accurate as I would like them to be as far as power numbers but they will still show spool/boost/afr.
Anyway I would like to start off with this Black 09 Hatch I'm currently working on remotely.
Car: 2009 JDM STI
Elevation: Pretty much sea level
Weather: HOT 90+
Fuel: 95 Ron on first graph and 95 ron plus VP octanium unleaded and spraying methanol on the second graph
Boost: Straight pump is 19ish psi, octane booster plus methanol injection 27.5psi
Modifications:
Stock Transmission
EJ207
2.5L nitrited crankshaft
Manley Htuff rods
Manley stroker pistons 8.5:1
Heads and cams are stock
FIC1000cc injectors
Walbro 255lph fuel pump
KSTech 73mm cold air intake
Front Mount intercooler
Unequal length headers of some sort
Uppipe with 38mm tial EWG
Grimmspeed 3 port
FPBlue Turbo(non antisurge)
Catless exhaust
Snow performance methanol injection system
Stock ECU tuned on the stock rom still using MAF
Here is straight pump gas, numbers are probably off by a bit as its hard to find a perfectly flat stretch on this island.
Ok here is the graph with VP octanium unleaded plus meth spraying, wideband disconnected during the pull but I have the AFR in the high 10s so if the meth system fails maybe it will not blow up immediately. This run was done on as flat of a stretch of road as possible
Methanol tune vs pump
alexmartynyuk is offline   Reply With Quote
Old 09-18-2021, 05:10 AM   #2
alexmartynyuk
Member#: 191967
2005 EVO VIII
Car: 2004 USDM STI
Elevation: 26 feet above sea level
Weather: 60
Fuel: 92 octane pump gas
Boost: 22ish psi
Modifications:
Stock Transmission
New 2.5L nitrited crankshaft
Saenz rods
JE FSR pistons if I remember right
FIC1000cc injectors
APS 70mm intake
Unequal length headers(agency power I beleive)
FPRed Turbo(non antisurge) 8cm hot side
Catless exhaust
Grimmspeed electronic boost control solenoid
4th gear log on a very flat stretch of road
Old 09-19-2021, 01:59 PM   #3
alexmartynyuk
Member#: 191967
2005 EVO VIII
Default jdm ej205 swapped bugeye wagon
Car: 2003 USDM Bugeye Wagon
Weather: 90* Fahrenheit
Modifications:
Stock Transmission
JDM EJ205 and ecu swap utilizing AVCS
Catless exhaust
Catless Uppipe
Stock USDM TD04
Stock intercooler and intake system
Grimmspeed 3 port EBCS
Old 09-19-2021, 02:40 PM   #4
alexmartynyuk
Member#: 191967
2005 EVO VIII
Default 04 WRX Sedan very well sorted stage 2
Car: 2004 WRX Sedan MT
Weather: 65* Fahrenheit
Modifications:
Stock Transmission
Stock EJ205
Catless exhaust
Catless Uppipe with tial 38mm EWG
Stock ported USDM TD04
Gimmick turbo inlet
Cold air intake(dont remember the brand)
Front mount intercooler
Walbro 255 fuel pump
Old 09-27-2021, 03:10 AM   #5
alexmartynyuk
Member#: 191967
2005 EVO VIII
Default 2014 WRX Sedan Stage2+
Car: 2014 WRX Sedan
Elevation: 26 Feet above sea level
Weather: 79 Degrees Fahrenheit
Fuel: 92 Octane
Boost: 19.5 psi peak tapering to 15.5psi up top.
Modifications:
Stock Transmission
Rebuilt short block with unknown parts
Cobb SF intake
Aftermarket top mount(mishimoto I believe)
Equal length headers(don't know the brand)
Stock untouched turbo
Catless exhaust
Grimmspeed 3 port
Old 09-27-2021, 03:25 AM   #6
alexmartynyuk
Member#: 191967
2005 EVO VIII
Default 2015 STI Stage1
Car: 2015 USDM STI
Weather: 60 degrees fahrenheit
Fuel: 92 octane
Boost: 16.5psi peak tapering to 14psi by redline
Modifications:
Completely Stock
