Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2019
Old 02-17-2019, 08:45 AM   #926
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
Originally Posted by ryansport22 View Post
Big thanks to the great guys at Surgeline for the awesome tune up and dealing with my weird autocross specific setup.
[IMG]
Seeing that XP class, have a build thread?
Homemade WRX is online now   Reply With Quote
Old 02-17-2019, 03:49 PM   #927
ryansport22
Member#: 157775
2006 WRX
No recent build thread, I was thinking about making one this year though. I'll be at the packwood tour this year if your in the northwest. See if I can hang with the big boys.
ryansport22 is offline   Reply With Quote
Old 02-19-2019, 03:23 PM   #928
Homemade WRX
Member#: 33782
96 in the garage
Yeah, I'm in North Carolina, so pretty much opposite corner from you.
Old 02-20-2019, 05:36 PM   #929
ryansport22
Member#: 157775
2006 WRX
Bit of an update to a very old build thread. Ill try to keep it a bit more up to date this year.
https://www.rs25.com/forums/f145/115...roject-28.html
Trying to get competitive with cars like speedyhams and the where to race Porsche but I think I'm still a bit behind.
Old 02-20-2019, 09:24 PM   #930
Homemade WRX
Member#: 33782
96 in the garage
I need to get back over to RS25.com more often. Sean's car is pretty stupid light.
Old 02-24-2019, 01:46 AM   #931
JerseyKid
Member#: 135901
2017 STi
Crystal White Pearl
Facility: EFI Logics - Calvin Dotson
Type of Dyno: Mustang
Baseline #'s: ~230ish on a stock VA STi
Boost: 19 psi
Fuel: 93 octane
Target AFR: 11.2
SAE Corrections: CORRECTED
Peak HP: 290
Peak Torque 324
2017 STi - 11,000 Miles
Stock Motor / Trans / Clutch - 93 octane ONLY
Mods:
Cobb SF with Airbox
MAP Performance ELH
Cobb AP V3
Cobb Catted Downpipe
Cobb Catback
Cobb 1050x Injectors
Cobb FPR Kit
Cobb EBCS
ETS Top Mount
DW 300c Fuel Pump
Socal Porting TGV Deletes
IAG 3mm Phenolic Spacers
IAG Street AOS
Perrin Inlet
GDT Number Four Cylinder Coolant Re-route Kit
KS Tech Airpump Block Off Plates
NGK Iridium LFR7AIX ( One step colder at .28 )
OEM BPV Crush Mod
JerseyKid is offline   Reply With Quote
Old 03-03-2019, 06:15 PM   #932
mgus773
Member#: 495113
2017 WRX Limited
2017 WRX Limited
Cobb AP
BigSF
Grimmspeed EBCS
Invidia Catless J Pipe
R400
mgus773 is offline   Reply With Quote
Old 03-04-2019, 10:41 AM   #933
Superchargedk20
Member#: 466477
2018 STI
Dyno : dynopack
Mods : borla catback, cobb catted dp, mishimotoFMIC, mishimoto intake, deatschwerks fuel pump, Ngk 1 step colder plugs
320 whp 348 wtq
Superchargedk20 is offline   Reply With Quote
Old 03-13-2019, 03:03 PM   #934
Kbubb
Member#: 479790
So my car makes 480 whp according to procom racing with a stock location turbo 440 xt turbine upgrade 10 hot side motor bottom end is built with bc cams all supportings mods and a front mount how is this possible with such a small flowing turbo can the numbers be that high and wrong ?
Kbubb is offline   Reply With Quote
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-02-2016 11:43 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 05:40 PM
