Welcome to the North American Subaru Impreza Owners Club Tuesday October 16, 2018
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 09-08-2009, 02:55 PM   #26
KC
Member#: 442
17 Imp Spurt
00 S2k | 14 BRZ (SSC)
Originally Posted by Beaverboy View Post
The '99 still had the open rear diff.
.. not that it matters one bit on dry pavement. The viscous rear LSD isn't doing squat unless you're in loose/slippery stuff.
Hmmm... was it an option in '99? I think I remember mine having it for some reason.
--kC
KC is offline   Reply With Quote
Old 09-08-2009, 02:56 PM   #27
Draken
Member#: 16
1968 Saab
Sonett II V4
As previously asked, what class are you looking at? G-stock, ST, DSP, SM etc?
Draken is offline   Reply With Quote
Old 09-08-2009, 02:58 PM   #28
Draken
Member#: 16
1968 Saab
Sonett II V4
'99 were open rears.
In all my time running GS and STS/X 2.5RS, I never had issues with rear wheel spin
Old 09-08-2009, 04:06 PM   #29
9blackcobra9
Member#: 166084
05 WRX WAGON
WHITE COBB STAGE II
Not sure. What are the differences. I'm just now trying to find a car to get into the sport
9blackcobra9 is offline   Reply With Quote
Old 09-08-2009, 05:38 PM   #30
Boxologist
Member#: 21118
me-otter. A new subaru would be a better starting point. 15 year old cars are no what i would want to play with vs newer cars that are better from the get go. maybe an RS or L wagon in an XP build, otherwise u'll have fun in a DS/STX(2.0L) WRX, BSP/STU STi.
just go to an autoX locally and find out how the lot is. If u never travel to far events the feel of that lot will influence u more. For all u know u'll end up in a Solo Vee or F440.
Boxologist is offline   Reply With Quote
Old 09-08-2009, 05:57 PM   #31
mofugga
Member#: 19540
2000 2.5RS
BRP for sale soon
i'm kinda partial to the 2 door rs's
you should jump on that one for 3800 if everything checks out! they're pretty fun cars when stock but once you start modifying 'em a bit they're a blast even with leaving the drivetrain stock! figure out what class you want to run before you do anything and in all honesty, the rs isn't very competitive nationally unless you're a phenomenal driver and the car's prepped to the limits but locally they're lots of fun and depending on your ability you can do quite well.
regardless, you won't regret buying one!
mofugga is offline   Reply With Quote
Old 09-08-2009, 06:06 PM   #32
badfish1134
Member#: 172591
99' GM6
74F....sold :/
Having a coupe is really inconvenient, especially if you haul your drunk friends around when it's your turn to DD.
badfish1134 is offline   Reply With Quote
Old 09-08-2009, 06:06 PM   #33
badfish1134
Member#: 172591
99' GM6
74F....sold :/
doublepost EMBO
Old 09-08-2009, 06:30 PM   #34
9blackcobra9
Member#: 166084
05 WRX WAGON
WHITE COBB STAGE II
if i buy this car it is going to be a auto cross car only, completely gutted and completely built
Old 09-08-2009, 11:36 PM   #35
DougM
Member#: 799
2000 2.5 RS Coupe
Mitsubishi EVO IX
well then, sounds like you want to "build" something... so buying an RS would be a complete waste (of a good rs). buy a pre-obdii car and the lightest one you can find (94L? I forget which one specifically), then go play.
read the rule book, honestly
http://cms.scca.com/documents/Solo_R...Solo_Rules.pdf
start at section 13, it'll save you a lot of grief down the road (might be a few years out ...but it'll hit you like a ton of bricks)
DougM is offline   Reply With Quote
Old 09-09-2009, 01:00 AM   #36
dankster
Member#: 54592
Subydude, what wheel offset do you use to fit 275s? Are you on RS width or WRX width suspension?
dankster is offline   Reply With Quote
Old 09-09-2009, 07:23 AM   #37
KC
Member#: 442
17 Imp Spurt
This.
If that's your goal... don't even consider a 2.5RS. The '93-'94 Impreza L (Brighton) was the lightest of them all and the one you're looking for... and will take in swaps very well, even with current powerplants.
I do have to make an observation... these questions you're asking are the kind of questions that can be answered with some research on-line. Are you familiar with how to research what you're going to need to be able to even pull off a 'build'? Or are you expecting to come into the forums ask a rather easy, generic question and expect a long and detailed answer, like how to swap out, what parts are needed, and the dreaded (like this question) "What's best"?
'Building' a car is more than just stripping it of it's extra parts/materials. Be sure this is something you really want to do. As doug said... read the rules. "Stripping" the car is going to put in a class where it'll be uncompetitive right out of the gate.
--kC
Old 09-09-2009, 10:16 AM   #38
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Originally I did 17x8.5 +42 with a 275/40/17 but it was a bit to much positive offset and rubbed on the inside of the wheel well. Current setup is 18x10 +35 with a 285/30/18. I use camber plates in the back to tilt the rear strut as far inbound as possible, then use an eccentric bolt on the bottom to bring the wheel back to where I want it for rear camber.
This is all on RS width suspension.
subydude is offline   Reply With Quote
Old 09-09-2009, 10:25 AM   #39
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
also remember the stiffer chassis arguement goes out the window when you start adding cages and interior bracing.
Ive had all flavors , 2 door, sedan, and wagon.
I like the 2 door and any stiffness gained by the sedan was not noticeable.
jnorth85 is offline   Reply With Quote
Old 09-10-2009, 12:07 PM   #40
9blackcobra9
Member#: 166084
05 WRX WAGON
WHITE COBB STAGE II
Originally Posted by KC View Post
This.
--kC
all i was wanting to know what a suggestion on a pre 02 impreza auto x car.
and thanks for the link to the rules much appeciated!
05 STI or 06 WRX which is a better used buy? ImprezziveJack Impreza Forum 3 11-13-2009 02:48 PM
WTB: 93-01 Impreza 2dr AmdEmAll MWSOC Private Classifieds 25 01-21-2009 03:27 PM
FS: JDM Rear window and Wiper for 93-01 RS Sedan or Coupe dscoobydoo NWIC Private Classifieds 22 09-07-2006 01:43 AM
SoCal: 93-01 RS Hood $120, 93-01 L Hood $50 wal.lin Private 'For Sale' Classifieds 0 06-26-2005 06:15 PM
