05-28-2002, 07:09 PM | #1 |
Member#: 19333
Vehicle:2002 wrx doggbox black w/ drag radials |
mobil 1 synthetic oil 15w 50?
Has anyone used this oil in there wrx im thinking about changing from my 5w 30 to the 15w 50 since it is alot better for turbo motors is it too thick for the wrx ?
05-28-2002, 07:11 PM | #2 |
Member#: 3792
Vehicle:2002 6MT almost GDB |
I would say "too thick"...5-30 is a good weight!
Andy |
05-28-2002, 09:34 PM | #3 | |
Member#: 12344
Vehicle:2002 2JC blue |
05-28-2002, 09:50 PM | #4 |
Member#: 14934
Vehicle:2002 WRX WRB |
I'd use 10w-30 synthetic in the summer time. Motor oils that have a wide spread usually have a lot of viscosity enhancers that can form deposits if they get too hot.
Rich |
05-28-2002, 11:55 PM | #5 | |
Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
05-29-2002, 01:43 AM | #6 |
Member#: 19333
thanks for all the feed back
05-29-2002, 02:22 AM | #7 |
Guest
Member#: 14110
Vehicle:2002 2002 WRX Swirly Black |
Try Motul 300v 5w30 you will not regret it.
05-29-2002, 02:44 AM | #8 |
Member#: 19333
how much is that stuff for one bottle do u know would love to use it but im thinkin its alot of money and where can i get some
05-29-2002, 02:55 AM | #9 |
Guest
Member#: 14110
Motul can be ordered through any motorcycle dealership and prestige subaru they are a vendor, as for price it can really vary from place t oplace but this is what I use in my daily driver I am building a group N car for rally and Prodrive told me 5w40 motul 300v for the race motor and 300v 5w0 for the road car. IT may cost a little bit more but engine protection is not a place to cut corners. Call up local motorcycle shops they will be able to help.
05-29-2002, 03:14 AM | #10 |
Member#: 19333
thanks
05-29-2002, 04:56 PM | #11 |
Member#: 13423
Vehicle:2002 WRX Silver |
Yep, Living in S. Fl. I use Mobil 1 15w-50 in my WRX. There is absolutely no problem with using it. Look in the factory manual for oil viscosities..you can use up to 20w-50 depending upon conditions. for extreme driving conditions and heat the higher viscosity is recommended and preferable. My car does lots of stop and go driving puncutated with full boost acceleration. Car runs and idles much smoother using the 15w-50.
05-29-2002, 06:15 PM | #12 |
Member#: 4980
I talked to someone at Mobil not too long ago and basically from what I was told the 15-50 does not have the friction modifiers used in the other viscosities.
This is why you can use their 15w 50 in a motorcycle's wet clutch system and not the other viscosities. The other versions will make the clutch slip because they are more slippery. I don't know if this is good or bad for the WRX but thought I would share some info on this. I've used both and can't tell the difference in the WRX. That reminds me, gotta change that oil! Just my 2c. Phil TurboXS |
Mobil 1 Synthetic Gear Oil Question | unwrittenlaw | Transmission (AT/MT) & Driveline | 18 | 06-27-2005 11:07 PM |
1/2 off for Mobil 1 Synthetic Oil | battousai | Texas Impreza Club Forum -- TXIC | 10 | 02-12-2005 07:23 PM |
mobil 1 synthetic oil | wrXiconZ | Service & Maintenance | 13 | 07-08-2004 08:50 AM |
Mobil 1 Synthetic 5q oil for $19.08 @ Walmart again. | Rally1 | Service & Maintenance | 18 | 05-17-2003 07:33 PM |
Mobil 1 Synthetic motor oil... | AcIdRoX | Vancouver Impreza Club Forum -- VIC | 4 | 11-18-2001 05:47 PM |
