Welcome to the North American Subaru Impreza Owners Club Monday September 24, 2018
Old 10-24-2009, 09:05 PM   #1
subypal
Member#: 218185
2016 WRX STI
Default turbo coolant and oil line question
Hello
I need to get coolant feed / return and oil feed/ return lines for my td06 20g-- any thoughts on where I can get this? I would like braided lines- i was thinking of going to a local speed shop and having custom ones built but if there is a place i can order them off the web that would be ideal. thanks!
subypal is offline   Reply With Quote
Old 10-26-2009, 09:47 PM   #2
subypal
Member#: 218185
2016 WRX STI
anyone have any input on this? or am i pissing in the wind here lol
Old 10-26-2009, 11:56 PM   #3
GDB FAN
Member#: 105814
GDB FAN is offline   Reply With Quote
Old 10-27-2009, 12:05 AM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
I bent mine to fit and drilled out the oil line to fit a larger banjo. It's been working fine. If you can't do that, those links above have what you need.
Old 10-27-2009, 01:21 AM   #5
subypal
Member#: 218185
2016 WRX STI
thanks all much appreciation
UP/DP and oil line questions [email protected] Normally Aspirated with bolt-on Forced Induction Powertrain 22 11-15-2007 05:15 PM
will vf turbo water and oil lines fit td05 16g? simprezl25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-02-2007 05:44 AM
td05 16g coolant and oil lines NEEDED simprezl25 Private 'Wanted' Classifieds 0 05-29-2007 07:09 PM
Coolant and Oil Lines for TD05-16g Jeramie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-14-2006 11:32 AM
How are you guys running coolant and oil lines to your turbos? BrysImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 0 10-01-2002 09:55 PM
