08-03-2005, 01:15 AM | #1 |
Member#: 71682
SCIC
Vehicle:2007 WRX Sti LTD. SWP |
Is my diferential damage for ever or I have a second chance???
My question is one time like 4 month / 3000 miles ago I was on a gravel terrain and It was perfect to do some slides and some lauches with my wrx. At that time I did not remember the fact of the hand break and awd. So I pull the e brake probably 4 times maybe close to 15 mile per hour for like 2 second each time to slide my car. Now after some reading about the same thing I remember my error couple month ago and I’m wonder if I caused any problem to my center diferential. My car has NO STRANGE SOUNDS OR VIBRATIONS while running no complain at all. I’m just concern of my diferential status because, beside that I take a really good care of my car.
Could be my diferential damaga because of those actions??? Or maybe I have a second chance!!!??? Thanks for your help guys redwrx
08-03-2005, 01:24 AM | #2 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
You should be fine. The damage noted in discussions is from prolonged use over a period of time. Eventually the center diff will wear out....but certainly not from what you're describing.
Jay Storm |
08-03-2005, 09:33 AM | #3 |
Member#: 66739
Vehicle:2002 WRX wagon silver |
you're probably o.k.! you were in gravel, which helped. if you did it on pavement you'd have a better chance of screwing it up! gravel is fun, i do it whenever possible! i wish i was a rally driver, damn!
08-03-2005, 02:41 PM | #4 |
Member#: 71682
SCIC
I hope my diff. is in good condition, all I want a good and reliable car!!!!!!
had any one broke his diff. because of e-braking??? like my case??? |
08-03-2005, 08:27 PM | #5 |
Member#: 76418
NESIC
Vehicle:04 wrx java black pearl |
nope i do it iin da snow!
08-03-2005, 09:00 PM | #6 | |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
....forget about it already..... |
is my turbo damaged? | don89 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 8 | 11-06-2009 07:23 PM |
Is my injector damaged? | rexee | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 09-23-2005 11:22 AM |
Hand break damage for ever or second chance???? | BBBsti LTD | Normally Aspirated with bolt-on Forced Induction Powertrain | 0 | 08-03-2005 01:01 AM |
Is my fuel pump going bad? Or is it worse? | NicGordon | Service & Maintenance | 5 | 10-15-2002 02:43 PM |
1/16" fitting mod: Is my boost solenoid now kaput or is there a fuse/reset? | Blitzer | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 07-17-2002 03:13 PM |
