Welcome to the North American Subaru Impreza Owners Club Saturday June 23, 2018
Old 08-16-2001, 10:11 PM   #1
HomerJay
Member#: 1135
2005 WRX WAGON
Default How much boost are you guys running?
Just wondering how much most of you guys are running. I might go turbo down the line after my warranty runs out. Thanks for any info given!
-JOE
HomerJay is offline   Reply With Quote
Old 08-16-2001, 10:32 PM   #2
Andrew
Member#: 1170
2005 STi
but after i get my fuel management down ill be pushing it up a couple psi
Andrew is offline   Reply With Quote
Old 08-16-2001, 10:54 PM   #3
[email protected]
Member#: 67
1999 Outlasting
the competition.
we'll see after the Vishnu kit is installed. 12? 14?
[email protected]
Old 08-17-2001, 08:35 AM   #4
HRE | giulio
Member#: 481
which is weird since i have the "7psi" pulley on. i'm thinkin of getting a custom crank and alt pulley made so i can spin the compressor faster.
"You wont be happy till you kill the poor thing"
-mom
HRE | giulio is offline   Reply With Quote
Old 08-17-2001, 09:02 AM   #5
Fido
Member#: 1867
I'll be running 6 psi next Friday ...
Fido is offline   Reply With Quote
Old 08-17-2001, 11:40 AM   #6
wop
Member#: 1931
2000 00 impreza 2.2l
wagon
Originally posted by Andrew
5
me too, me too!!! I really need to get my tec II out of the box and in the car .
-wop
wop is offline   Reply With Quote
Old 08-17-2001, 04:24 PM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
3psi and loving not breaking anything.
Old 08-17-2001, 04:31 PM   #8
wop
Member#: 1931
wagon
3 psi? is it even worth it?
-wop
Old 08-18-2001, 02:39 AM   #9
ImprezaRS dot com
over boosted again
Member#: 1458
2017 WRX Limited
2015 Forester XT, Tribeca
8 psi on 93 octane and 10 psi on 95+ octane, and as high as 14 psi with a little timing retard added in, before my IC started to leak.
Now with this pressure leak and the boost controller turned all the way up I only get 8 psi in 1st gear, 9 psi in 2nd-3rd, 10 psi in 4th, and up to 12 psi in 5th after a while on the gas to get it to creep up. New air/water IC is on order.
Larry
PS: This is at 6,000 feet where we can run 25-40% more boost.
ImprezaRS dot com is offline   Reply With Quote
Old 08-18-2001, 06:04 AM   #10
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
-wop
Oh yeah, definitely. It's just proven to me more that I need to complete my plans rather then turning back.
Old 08-18-2001, 12:15 PM   #11
Greg 99
Member#: 1388
I run 12-14psi. No problems. Knock on wood.
Greg
Greg 99 is offline   Reply With Quote
Old 08-18-2001, 01:06 PM   #12
Andrew
Member#: 1170
2005 STi
Greg
mmm 12-14psi. cant wait to run that
Old 08-18-2001, 04:33 PM   #13
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Boost
I am running 6psi but I am finishing putting in my new clutch today and then my next investment is injectors so I can up the boost.
Joshua
Subaru Salesman
yebokmj is offline   Reply With Quote
Old 08-18-2001, 04:47 PM   #14
zaidallas
Member#: 4106
12 psi .......
20+ psi coming in a month or so .
zaidoun
project street terror coming soon......
zaidallas is offline   Reply With Quote
Old 08-18-2001, 10:47 PM   #15
Jeff 2.5RS
Member#: 1590
2004 Rx8
A little over 7psi tapering down to 5psi at redline in a attempt to save the gearbox.
Jeff 2.5RS is offline   Reply With Quote
Old 08-18-2001, 11:06 PM   #16
Andrew
Member#: 1170
2005 STi
can the stock internals handle 12psi?
Old 08-18-2001, 11:29 PM   #17
Ethan
Member#: 246
Only 6psi
Ethan is offline   Reply With Quote
Old 08-19-2001, 02:40 AM   #18
Greg 99
Member#: 1388
Stock internals can handle 22psi, but then the rods start to bend as seen on Adam Bloom's car.That is the highest boost i have heard of on a stock motor. So don't be shy guys just make sure you tune it properly for the higher amount of boost.
Greg
Old 08-19-2001, 03:03 AM   #19
kaos200
Member#: 2692
Greg
HUH? I don't think that's entirely true... Actually I'm pretty sure the pistons would be toast running that much boost, I've seen WRX pistons go at less than that.
kaos200 is offline   Reply With Quote
Old 08-19-2001, 03:05 AM   #20
kaos200
Member#: 2692
oh yeah was running 10psi fine on semi-daily basis
soon... well.. Let's cross that bridge when we get to it
Old 08-19-2001, 04:31 AM   #21
Kcz
Member#: 2038
2000 RS-T
Silverthorn Metallic
7# getting new injectors and engine management, I should be able to crank it up a few notches, since I have a pretty well built motor.
Kcz is offline   Reply With Quote
Old 08-19-2001, 04:23 PM   #22
zaidallas
Member#: 4106
KCZ : since when you moved to garland ? I'd say you can go 14 psi + with injectors easily since you got pistons and rods.
stock internals can take 12 psi NO problem with proper tuning , as long as you don't detonate , your internals will be fine. been done by many people.
zaidoun
Old 08-19-2001, 11:32 PM   #23
RyanC
Member#: 2634
1988 5000 CS Quattro
Tornado Red
I started out at 5psi w/no intercooler (in winter), then eventually added an IC and another 7psi along the way. The last month or so I was running 12psi with no problems. I even ran up to 13psi at the track without an issue. I chalk it up to tuning. A few guys have done blowed up their motors with 4psi or so, but if you look at the folks who have their cars tuned right the burnt pistons and bent rods are few and far between.
RyanC is offline   Reply With Quote
Old 08-20-2001, 11:19 AM   #24
jdchmiel
Member#: 926
I am running 4 psi right now. I am waiting for my EGT probe for the 2nd week or so from autometer. I dont trust my a/f gauge, so I am not going any higher than 4 until I see some temps.
jdchmiel is offline   Reply With Quote
Old 08-27-2001, 08:51 AM   #25
HRE | giulio
Member#: 481
i sent a stock crank pulley out for a place to custom make me a new pulley. it will be lightened, underdrive the AC, and overdrive the SC. weeeee. 6-8psi in 2 weeks
Im so happy with 4#... this little car is gonna be sweet!
how much boost are you running? Chino Bling Texas Impreza Club Forum -- TXIC 52 10-22-2008 04:38 PM
how much boost are you running in all gears WRXBOOST10 Engine Management & Tuning 56 02-06-2007 06:51 AM
so how much less boost are you guys running due to the summer heat? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-14-2006 12:55 PM
Quick Survey - EJ22T guys, how much boost are you running? Trizzle Normally Aspirated with bolt-on Forced Induction Powertrain 20 09-18-2003 09:19 PM
How much boost are you running? 2003 sedan Texas Impreza Club Forum -- TXIC 16 09-24-2002 11:29 AM
