Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Old 11-26-2009, 03:25 PM   #1
atprex
Member#: 227601
Default 2.5 built motor questions
Im planning on putting a built ej257 in my wrx. I was wondering if these parts on my ej205 can be used for the new 2.5.
Just these for parts for now
camgears ?
crank pulley-alt pulley-powersteering pulleys and belts ?
is it also recommended to get a new idlers and tensioner kit even if theres nothing wrong with the ones on the 2.0lt ?
Also is a better timing belt guide required ?
atprex is offline   Reply With Quote
Old 11-28-2009, 02:26 AM   #2
Ensi
Member#: 90329
05 Sti
Gray
If you have anything more than 35k you should get new idlers, tensioner, oil pump, oil cooler(you can reuse yours if you didn't spin a bearing on your old block), waterpump, and timing belt. Consider it semi cheap insurance.
Ensi is offline   Reply With Quote
Old 11-28-2009, 12:44 PM   #3
atprex
Member#: 227601
Wow thanks man appreciate it exactly what i was tryn to find out.
Old 11-29-2009, 12:23 AM   #4
roc sti 13
Member#: 227540
2005 wrx STI
blue
i just spun a bearing in my 05 STI and am amazed it took me 80,000 miles to do it w the way i drive ....time to start planning the street monster blue print
roc sti 13 is offline   Reply With Quote
Old 11-30-2009, 05:26 PM   #5
atprex
Member#: 227601
Alright ive come to the question of what 400whp (mustang dyno HP /not dynopack) bolt on turbo should i get that will get me to this goal . id like that turbo to get me that number on pump fuel and perferably not running over 24 psi. and then want it to get as close to 450 on race fuel before 28psi.
I realise there a quite a few turbos out their that will do that. So which one should i get ?
Old 11-30-2009, 06:50 PM   #6
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
New blouch 3.0XT-R, Or OG 3.0R with the 10cm^2 turbine housing. Or ATP 3076, or 35r
FP hta green or larger to name a few.
Do you plan on any head work?
rexworx is offline   Reply With Quote
Old 12-01-2009, 12:17 AM   #7
atprex
Member#: 227601
Yes most definatly, will have full pnp- complete valvetrain upgrade-cams-1mm oversized valves. ect .
would all that have a bearing on which turbo i should go for ?
WTS Built 2.5 hybrid motor (project) - MD Kaldar142 MAIC Private Classifieds 9 11-25-2009 10:01 AM
2.5 sti motor, 2.5 wrx motor olsen726 General Community 19 09-24-2008 03:31 PM
04 2.5 Forester motor in a 99 2.5 RS? R.B. WRX Wagon Subaru Conversions 3 08-24-2007 06:21 PM
whats better v5 sti 2.0 motor or 04 sti 2.5 sti motor? drift king Pre-2002 Factory Turbo Powertrain 19 08-07-2007 08:19 PM
Built motor question cornerbuddy28 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-15-2005 12:17 PM
