Welcome to the North American Subaru Impreza Owners Club Tuesday February 20, 2024
Old 10-08-2006, 03:28 PM   #1
ImpreziveWRX
Member#: 17643
2002 WRX Wagon
Default Gas smell that is not related to cold weather
I am having gas smell problem for a long time...
It gets to a point that I stopped at a red light and I can smell it really bad
Most thread point to cold weather and the 02 WRX leaking problem but this one is not
It is not from my engine bay, I added RTV sealant to make sure no leak from my down pipe and cat back section... but the smell is still there...
Yesterday I have my car jacked up and I noticed the section with heaviest odor is my rear passenger side wheel...
I didn't overfill, didnít spill any gas when I filling it up... I just have no idea what happens.
Anything that I need to check into?
Let me know
Thanks in advance
ImpreziveWRX is offline   Reply With Quote
Old 10-08-2006, 05:03 PM   #2
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
Have you changed the fuel pump or removed it for any reason? The gasket under the cover where the pump goes into the tank may be damaged and this will cause a fuel smell in the car, if the leak is bad enough you may also get an evaporative system CEL.
Mulder is offline   Reply With Quote
Old 10-08-2006, 07:07 PM   #3
ImpreziveWRX
Member#: 17643
2002 WRX Wagon
Yes, I got the loose gas cap CEL before but it was gone after my "fuel filter" was replaced...
I have replaced my fuel pump before due to a turbo upgrade
What can I do myself to check for the damaged gasket?
I am not skilled expert but I do some work myself
Old 10-08-2006, 09:41 PM   #4
ImpreziveWRX
Member#: 17643
2002 WRX Wagon
Is this the part I need?
I need to get it fixed ASAP...
Thanks in advance
Gas Leak-Not due to cold weather. ChronicWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-02-2009 09:37 PM
Cold weather ticking --not related to engine speed nardvark Service & Maintenance 11 02-12-2009 09:40 PM
is boosted84wagonmonster capable of making a thread NOT related to food? boosted84wagonmonster Off-Topic 19 06-24-2007 09:48 PM
My STI Does NOT like the cold weather!!!! Mikemar Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 11-12-2004 05:28 PM
head lights not coming in cold weather reaubideux Electrical & Lighting 1 11-27-2003 10:28 PM
