Welcome to the North American Subaru Impreza Owners Club Wednesday February 21, 2024
Old 10-11-2007, 02:46 AM   #1
preacher#1
Top Scoob 022
Member#: 129894
FSTI '04 4EAT Sierra
Gold Metallic 20G-XT, EWG
Default coolant leak after turbo install
I had a shop do some workyesterday, and every thing seemed fine till today. immediately saw smoke early this morning..and it seems that there is a leak under the vf39. The shop was cool and said to bring it in, but I WAS WONDERING IF THIS is something that I figure out myself? what hose is it?
Should I take the hose off and put on a better hose fitting? I didn;t allow the coolant overflow to get too low, but the smoke freaks me out.The shop is 25 miles away, and I don't want to drive that far. AARRgggHHH I am pissed.
preacher#1 is offline   Reply With Quote
Old 10-11-2007, 10:39 AM   #2
STIBungy
Member#: 51684
The coolant feed hose is easy to check. The coolant return hose is a little tougher as it runs underneath the turbo. I'd check those. Also check the reservoir, itself.
STIBungy is offline   Reply With Quote
Old 10-11-2007, 11:35 PM   #3
JO'S TR
Member#: 127012
2006 WRX 18g+Meth
6spd WRB
Check the bolts on the banjo fittings, you can check them from under the car with a 17mm wrench. I had this problem 2 days ago.
JO'S TR is offline   Reply With Quote
Old 10-12-2007, 02:36 AM   #4
preacher#1
Top Scoob 022
Member#: 129894
coolant return line wasn't cranked down...$hi++y clamp!!
Coolant leak after turbo Install 855m0n0 South East Region Forum 5 03-27-2018 08:09 AM
Coolant leak after motor mount install. stikboy9 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 11-03-2009 06:29 PM
oil leak after turbo install eb_rat_7 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-25-2008 10:09 PM
coolant leak after turbo install Wookie768 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-02-2007 06:06 PM
Coolant Leak After Uppipe Install... timman_24 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-29-2004 04:56 PM
