Welcome to the North American Subaru Impreza Owners Club Wednesday February 21, 2024
Old 03-26-2008, 09:30 PM   #1
deathskrye
Member#: 153471
2002 Impreza WRX
Midnight Pearl Black
Default Coolant Leaking from turbo
I have been having a coolant leak problem now for a while. I finally found where the leak was coming from the right side of the turbo where a hose is connected to. What do i need to get/do to fix the problem. Im not too knowlegable about cars so some help would really be appreciated. My car gets pretty hot sometimes and that cant be good
deathskrye is offline   Reply With Quote
Old 03-26-2008, 09:51 PM   #2
Arctic Penguin
Member#: 119532
2006 WRX
gently pull up on the lower hose
if you feel it move a bit and stop
give it a bit more and stop pulling
sometimes the lower hose clamp is not seated against the bead on the coolant hardpipe and pulling the hose up a bit seats the clamp against the bead and seals the leak
and no more leak
Arctic Penguin is offline   Reply With Quote
Old 03-26-2008, 10:10 PM   #3
deathskrye
Member#: 153471
2002 Impreza WRX
alright ill try that when i get off of work. if that dosnt work any other possibilities
coolant leaking from the turbo Mar48 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-22-2008 11:47 AM
coolant leak - from oil filter? Penphoe Normally Aspirated Powertrain 24 06-14-2004 04:40 PM
coolant leaking from under turbo The Deliverator Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-02-2004 07:01 PM
where does my coolant leak from? haszlan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-31-2003 06:40 AM
coolant leak, from near thermo(pics) biggreen96 Normally Aspirated Powertrain 26 06-21-2003 02:53 PM
