#1 |
Member#: 51480
International
Vehicle:1984 AM5, 1984 AF1, 1994 BC4, 2015 Outback |
![]() I have access EUDM (up to 2005) and JDM (up to 2003) part CD-ROMs.
I can look up part numbers should you need any. Please always describe the part as clear as possibly, and state which model year. I can't promise I will look into this thread daily, but at least a few times a week. I will post the number as a reply to this thread, and will maintain a list in this first post. At your service ![]() Let me make clear that before you order anything based on the information and numbers I supply here, you should always double check with your supplier, to avoid disappointments! ![]() |
#2 |
n00b Moderator
Moderator Member#: 811
Vehicle:2000 RS-Ej20G It tastes like burning |
![]() Thanks for setting this up. Would it make more sense to split the G and K motors to their own thread?
First request; Check if there is a different part # for the STi 1/2 HLA versus the standard WRX HLA. I have used this thread a few times for early G stuff (some may be liberyRS specific) http://www.rslibertyclub.org/forums/...ad.php?t=54967 -Rob |
#3 |
Member#: 177
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
![]() car gc8d48d
build 5/97 engine EJ20KDW6HE tranny TY752VBCAA plug wires: -#1 - 22451AA793 not in system -#2,4 - 22452AA682 not in system -#3 - 22451AA822 not in system coil pack: 22433AA370 (1) 73.19 maf: 22680AA271 (1) 210.91 power steering lines -RHD 34610FA091 not in system -LHD 34610FA100 not in system ACCEL CABLE (EJ20K LHD): 37114FA070 not in system boost solenoid: 16102AA091 not in system map sensor: 22012AA160 (1) 219.39 iac: 22650aa132 not in system injectors: 16611AA231 not in system in fender overflow -tank 45152AA020 20.24 -filler 45132AA010 not in system -cap 45153AA001 3.39 pvc to block hose 807519082 head gasket: 11044AA355 (2) 27.78 sti reinforced head gasket: 11044AA463 not in system water pump gasget: 21114AA051 (1)1.93 rear main seal: 806786040 (1) 8.74 cam seals: 806732150 (4) 5.87 valve cover gasget: -right? 13270AA062 (1) 9.64 -left? 13272AA063 (1) 9.64 -?? 13293AA051 (4) 5.82 (says its for an 05-6 h6?) -wash rocker cvr (13271AA051 (12 or 16) 2.38 manifold to intake: 14035AA281 (2) 3.32 manifold to throttle body: 16175AA151 (1) 1.70 manifold to IAC: 22659AA060 (1) 3.88 manifold to injector: 16608AA020 (4) 5.22 crank -(#3 thrust bearing) 12200AA150 364.71 -(#5 thrust bearing) 12200AA2240 272.60 main bearings -(#3 thrust bearing) 12209AA000 84.80 -(#5 thrust bearing) 12209AA360 133.41 rod bearings: 12108AA290 182.80 rods 12100AA240 52.70 rings: 12033AA730 not in system head bolts: 11095AA041 7.26 rebuild gasket kit: 10105AA380 not in system heads -LH 11063AA742 not in system -RH 11039AB132 not in system cams (non STI) -13032AA240 not in system -13035AA240 not in system -13038AA240 not in system -13053AA240 not in system cams (STI) -13032AA390 not in system -13035AA390 not in system -13038AA390 not in system -13053AA390 not in system Non-RA valves: -EXH: 13202AA350 13.24 -INT: 13201AA340 9.21 vavle spring: 13217AA160 not in system rear deck cover -Up to July 1997: 65510FA001ML not in system -April 1997 on: 65510FA001OE not in system Last edited by Jaxx; 05-05-2007 at 01:51 PM. Reason: updated with info from below thanks! |
#4 |
Member#: 51480
International
![]() Plastic coolant tank on EJ20G intake manifold
TANK ASSEMBLY - WATER 21132AA001 (number is correct but not in Jamie's catalog) |
#5 | |
Member#: 51480
International
![]() Quote:
22433AA370 COIL ASSY IGN (1) 22680AA271 METER AY-AIR FL (1) 11044AA355 GSKT-CYL HEAD (2) 21114AA051 GSKT-WATER PUMP (1) 806786040 OIL SEAL 86x103 (REAR CRANK SEAL) (1) 806732150 OILSEAL-32X45X8 (CAM SEAL) (4) 13270AA062 GSKT-ROCKER COV (1) 13272AA063 GSKT-ROCKER COV (1) 13293AA051 GSKT-ROCKER CVR (4) 13271AA051 WASH-ROCKER COV (12 or 16) 14035AA281 GSKT-INT MANIF (2) 16175AA150 GSKT-THROT CHAM (1) 22659AA060 GSKT-AIR CONT (1) 16608AA020 SEAL-FUEL INJEC (4) 34610FA091 P/S HOSE ASSY RHD (1) 34610FA100 P/S HOSE ASSY LHD (1) 16102AA091 VALVE AY - DUTY (1) 22012AA160 SEN ASSY-VAC (1) |
#6 | ||
Member#: 51480
International
![]() Quote:
#7 |
n00b Moderator
![]() AHA! They are different numbers. The lightweight STi variant may exist afterall.
Thanks, Rob |
#8 |
Member#: 177
![]() WRX EJ20G HLA
13230AA160 ADJ CP-VLV LASH -28.45 STI V1/2 EJ20G HLA 13230AA170 ADJ CP-VLV LASH - not in system |
#9 |
Guest
Member#:
#10 | |
Member#: 19470
SWIC
Vehicle:1981 Brat GL Blue |
![]() Quote:
#11 | |
Member#: 468107
International
Vehicle:2001 JF1 Rs GM-coupe Blue |
![]() Quote:
If you have information on how or where to get it please. |
#12 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
![]() very interesting...
#13 |
Member#: 70256
RMIC
Vehicle:2000 STI V2 Swapped Silver |
![]() Indeed....
#14 |
Member#: 11620
Vehicle:1997 GF4-STiV3 clone |
![]() Marnix,
Would you be kind enough to look up the number for intake valves for a Version 4 Type R. The valves have a marking of "I H" on them. They are different from a version 3. Cheers, Bruce |
#15 |
Guest
Member#:
![]() WJM's request:
The 2003 JDM, STi Spec C Type RA standard size Pistons (92.0MM, for the A and B bore sizes) thanks! |
#16 |
Member#: 832
RMIC
#17 |
Member#: 70256
RMIC
![]() Marnix, could you get me the part number for the 90 degree rubber inlet piece that comes directly off the turbo? Thanks!
#18 |
Member#: 51480
International
#19 |
Member#: 78658
Vehicle:2005 LGT Limited Black/Black |
![]() EJ20G part numbers for the rubber inlet peice off the turbo intake and all subsequent pieces from that point to the air box. thanks!
#20 |
Member#: 51480
International
#21 | ||
Member#: 78658
![]() Quote:
![]() nice man...gonna go check out and see if they work at the stealership monday. |
#22 | |
Member#: 177
![]() Quote:
https://www.subarugenuineparts.com/oe_parts_cat.html it will be cheaper too BOOT 46023AA150-not in system RESONATOR 46032AA050 -not in system BOOT 46023FA000-not in system |
#23 | |
Member#: 78658
![]() Quote:
#24 |
Guest
Member#:
![]() But Marnix posted he can get up to 2003 JDM part numbers, that includes an EJ207....
#25 |
Member#: 51480
International
![]() EJ207 piston 'A' 12006AB430
EJ207 piston 'B' 12006AB440 But those are ridiculously expensive. |
EJ20G & EJ20K Parts | awdeclipseguy | 1993 - 2001 Impreza Specific Parts | 17 | 06-15-2009 08:04 PM |
EJ20G Gasket Part Numbers... | scoobydorift | Subaru Conversions | 13 | 02-14-2005 11:43 PM |
Official XT Oil Filter Part Number thread | BrysImpreza | Forester Forum | 8 | 10-30-2003 12:23 AM |
NAPA Part numbers- can we have a nice thread with numbers listed? | Tex-WReX2 | Service & Maintenance | 5 | 12-15-2001 10:21 AM |
