Welcome to the North American Subaru Impreza Owners Club Wednesday January 22, 2020
Old 04-26-2013, 04:15 PM   #1
onebadwrx
Member#: 223240
2003 WRX
World Rally Blue
Default Manley 99.50A and 99.50B Pistons
Hey guys my 06 WRX has been struck by the curse of the Subaru ring land failure. I have got a new STI shortblock from Subaru but I want to put a set of forged pistons in it. Manley has released their standard bore 99.50 pistons with Subaru A and B sizes. From my understanding these are suppose to be drop in's as long as you get the correct ones for what your block is stamped with. Ring gap has to be checked of course but, has anyone used these in a build? can anyone give an idea of what the PTW clearance was on them?
onebadwrx is offline   Reply With Quote
Old 04-29-2013, 10:03 AM   #2
tja1618
Member#: 181995
2003 WRX
I am going to be building my new block with these pistons. I'm letting my builder order the pistons, but my block has the "BBBB" code stamped on top. I was going to go with Manleys anyway, and then these were just released. Looks like a good match for someone like me with a brand new EJ257 case.
They are pretty new, and I haven't seen anyone on the forums who have actually used them yet. Unfortunately I won't be able to give you an option until later this summer, although my block will be done in 3 weeks.
tja1618 is offline   Reply With Quote
Old 05-01-2013, 07:08 PM   #3
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
They have not been released yet. We have just placed our opening order for this new model piston. We should be seeing them sometime next week.
To order you will need to specify how many A or B's you need than we will ship out accordingly.
thanks
Adam
No Limit Motorsport is offline   Reply With Quote
Old 05-01-2013, 09:03 PM   #4
cbazq271
Member#: 330175
Just order my set of 4, "A"'s for No Limit Motorsports a few days ago. I called Manley and asked about these pistons. I was told the A and B pistons were the only true drop-in, no honing required. Their other standard bore 99.5 pistons still need to be checked for PTW clearance. Manley also recommended No Limit Motorsports as a place to order on the east coast. I went with them they were great to deal with.
cbazq271 is offline   Reply With Quote
Old 05-02-2013, 10:46 AM   #5
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Thanks cbazq271 for the kind words.
Here are the installation instructions for this new piston
http://www.manleyperformance.com/dl/...structions.pdf
Old 05-12-2013, 10:05 AM   #6
ipkyss
Member#: 353600
2004 Wrx 2.5 35R
Just to add to this. I was at the machine shop two days ago with my parts. My Manley 99.5 pistons that were purchased in October measured 99.49xxx. The 2010 EJ257 "b" block with 20k miles on it had very good cylinders with no abnormal wear. The ptw clearance were all between 0.0045-0.005. Being that I plan to track the car in the 450-500hp range this was considered to be ok in there eyes. I was also told to expect a rather noisy cold start which doesn't matter much to me.
ipkyss is offline   Reply With Quote
Old 05-13-2013, 04:37 PM   #7
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
We have received our shipment of these pistons. They look fantastic.
Old 05-13-2013, 10:33 PM   #8
sense of nature
Member#: 112759
2004 Stock OEM AsFu*
FoZZY SexyRP
Pics....?
sense of nature is offline   Reply With Quote
Old 05-14-2013, 07:25 PM   #9
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Originally Posted by sense of nature View Post
Pics....?
Old 05-14-2013, 09:27 PM   #10
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
So if you get a new block and install these pistons, what PTW clearances are you supposed to end up with? Also are these 2618 alloy, or 4032. I'm curious as to how loud these will be for a nice daily?
morrocco88 is offline   Reply With Quote
Old 05-15-2013, 01:45 AM   #11
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
They are 2618. I haven't handled a set in person but I am sure they are aimed at a .003-.0035 PTW based on the corresponding sizes.
Crystal_Imprezav is offline   Reply With Quote
Old 05-15-2013, 10:01 AM   #12
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Nailed it.
Old 05-15-2013, 02:20 PM   #13
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
I think I will try a set on my next build
aboothman is offline   Reply With Quote
Old 05-23-2013, 06:21 PM   #14
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
We've been getting some great feedback from customers building engines with these.
Adam
Old 11-07-2013, 02:02 AM   #15
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Adam
Just wondering what kind of feedback your getting on the noise/slap these make? Since you get a predetermined PTW clearance, they should all sound about the same huh?
I've heard people say regular manley pistons are on the noisy side.
Old 03-20-2014, 01:22 PM   #16
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Yes, this is the question I asked a while back and I'm still wondering.
Old 05-23-2013, 08:49 PM   #17
jrushing11
Member#: 300260
Rally Blue
Guess I know what pistons to put in my shortblock next spring.
jrushing11 is offline   Reply With Quote
Old 05-24-2013, 01:14 AM   #18
Delphi
Member#: 239335
Adam
How would these fair in an engine that blew a piston? Provided the bore was fine and just needed a slight hone to resurface the walls.
Delphi is offline   Reply With Quote
Old 05-24-2013, 12:26 PM   #19
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Just go 99.75 and remove any doubt. Sounds like the engine has not even been taken apart yet?
Old 05-24-2013, 11:06 AM   #20
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
Guess it depends on how it measures out in terms of out of roundness and taper.
theotherguy is offline   Reply With Quote
Old 05-24-2013, 11:33 AM   #21
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
Anyone know if the standard 99.5mm pistons are slightly larger then the A, and B drop in pistons?
I assume yes, I just want to make sure...
Old 05-24-2013, 11:52 AM   #22
theotherguy
Member#: 191514
'05 FXT 6spd, 98
A is 99.505-99.515
B is 99.495-99.505
Old 05-24-2013, 12:04 PM   #23
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
I know the regular 99.5 pistons usually mic out to around 3.9140-3.9145"
Haven't measure any of these new A and B types.
Old 05-24-2013, 12:49 PM   #24
Delphi
Member#: 239335
No I was asking just out of curiosity, motor is still running strong in my car. But someone locally is selling a short that had a piston crack a ringland. Was considering buying it.
Old 05-24-2013, 12:51 PM   #25
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Cracked ringland usually equals scoring. Go with the 99.55mm piston and you should be able to get a clean cylinder unless the scoring is bad.
