Welcome to the North American Subaru Impreza Owners Club Thursday January 23, 2020
Old 08-20-2019, 07:34 PM   #1
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Default Ď08 Legacy 2.5i turbo build
I know a lot of these posts come around, but never follow through. But I will follow through with this for sure. I've got my parts list complete, and have begun ordering bits & pieces.
Background: I've had the car for several years and have had the itch for a new car lately. I can't justify it, mine has been paid off and there's nothing wrong with it. So instead of spending 20k+ on a new(er) car, I'm going to spend less than $2500 and make this one a lot more fun and "new" to me again.
Car: 2008 Subaru Legacy 2.5i 4EAT 86k miles
Mods:
-H&R springs w/ Koni struts
-Damn near every suspension bushing is Whiteline/Energy
-Whiteline rear sway bar
-LGT brakes w/ DBA rotors
-Delta 1000 cams
-Grimmspeed LW crank pulley
-Grimmspeed phenolic intake spacers
-AEM dry-flow filter
-hybrid intake system
-WRX injectors
-e85 fuel
-Infernofab 4-2-1 header
-Infernofab high-flow cat
-stock GT midpipe
-HKS Silent Hi-Power axleback
Turbo build list in next post --->
tipsymechanic is offline   Reply With Quote
Old 08-20-2019, 07:35 PM   #2
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
I'd like to say I'm doing this the "right" way. But I suppose there isn't a perfect way to do it, aside from either swapping a factory turbo motor in or selling the car and buying a factory turbo car. (I'm sure I'll hear that a million times during this)
I'm not buying the AVO kit, I'm not cutting my crossmember or making a funky up pipe. I'm going to use as many stock turbo parts I can to make this appear like it came from the factory. I feel that is the right way to do it.
I won't type out the entire parts list, there's too many small things that most of you won't care about. But here's the main pieces:
-Kinugawa TD04HL-20T
-OEM turbo header/UP
-CNT catless downpipe
-LGT airbox lid/MAF
-OEM turbo inlet
-OEM BPV
-Water to air intercooler
-LGT front crossmember
-OEM turbo swaybar
I will have more parts and much more detail in future posts as I begin work.
Old 08-20-2019, 07:35 PM   #3
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
My friend has talked me into creating a youtube channel to document the progress of this build. This is my daily driver, so I will be doing a little at a time on weekends.
I will edit this post with videos as they become available.
Channel: tipsymechanics
First video is up!!
Our camera had some focus issues, we'll figure it out by the next video.
Part 1.5 is up!
Part 2 is up!
Old 08-20-2019, 07:37 PM   #4
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
All parts have been ordered! Getting excited!
Old 08-20-2019, 08:08 PM   #5
nvmylh
Member#: 243490
Hell yea do the youtube channel!
How are you going to tune it? I'd almost not bother with the 1000 cams, go straight for the 1500s or nothing at all. Especially if turbo'ing.
EDIT: Whoops, didnt realise you already had the cams installed. How have you found them? Noisy? Make much difference?
nvmylh is offline   Reply With Quote
Old 08-20-2019, 08:19 PM   #6
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Unfortunately they only offer the 1000 grind for the 06+ AVLS engines. Theyíre definitely more noisy than stock, but not too bad. I feel like they made a difference, I never drive the car that hard, so them helping the lower rpms is great for my driving style. Light/moderate acceleration seems easier Vs the stock cams.
As for tuning.. I had my ecu defined by the folks on the romraider forums many years ago. Iím doing a lot of research and will slowly tune this setup myself.
Old 08-20-2019, 09:33 PM   #7
Boxcar80
Member#: 491471
2009 Impreza
How much boost do you have planned?
Boxcar80 is offline   Reply With Quote
Old 08-20-2019, 10:03 PM   #8
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
I plan on starting at 5psi, running e85. I will go up from there, as far as my injectors will allow. Iím guessing 8psi max.
I want to stay with e85 for safety
Old 08-20-2019, 09:42 PM   #9
Subie_Doo
Member#: 338489
just subbed to you youtube channel. I've been wanting to do this to my 09 forester but haven't committed due to the same reasons you mentioned. cool to see someone go for it
goodluck with the build
Subie_Doo is offline   Reply With Quote
Old 08-20-2019, 10:03 PM   #10
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Thanks!
Old 08-20-2019, 10:14 PM   #11
Subie_Doo
Member#: 338489
what's your plan for fuel setup?
I read that returnless fuel setups on the newer vehicles are PITA to tune so I was planning to swap an STI or equivalent tank and matching upgraded fuel pump and route a return that way. disregard if your vehicle has a fuel return still.
Old 08-20-2019, 10:21 PM   #12
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Mine still has a return line, fortunately.
I've got a Deatschwerks 65c pump with WRX 565 injectors (they flow tested @ 590cc)
I'd rather not push them to their absolute limit, so if I have to stop at 6psi.. thats fine. 6psi on e85 should make ~210whp
Old 08-20-2019, 10:27 PM   #13
Subie_Doo
Member#: 338489
lucky duck.
Old 08-20-2019, 10:32 PM   #14
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
lucky duck.
yours doesn't? You're only one year newer than mine. Same ej253
Old 08-20-2019, 10:49 PM   #15
Subie_Doo
Member#: 338489
not to be a kill joy but I would double check your car does indeed have the fuel return line.
your engine bay looks exactly like mine tbh
Old 08-20-2019, 10:29 PM   #16
Subie_Doo
Member#: 338489
why'd you choose awic vs tmic or even fmic? just wondering because I went through the same issue: deciding awic vs tmic or fmic.
Old 08-20-2019, 10:31 PM   #17
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
I've used awic in supercharger setups in the past.. they're simple and work very well. Very low pressure drop and doesn't require 10ft+ of extra pipe.
TMIC would be easy but with the big NA intake, you can't really fit one in there...and I'd have to get a hood with a scoop.
I felt awic was the best value.
Old 08-26-2019, 09:06 PM   #18
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Its raining and I'm still waiting on some parts, so here's some crappy drawings of the intercooler setup and a dual catch can setup.
https://i.imgur.com/P5P3opa.jpg
https://i.imgur.com/aMeTvWb.jpg
Old 08-30-2019, 08:53 PM   #19
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Itís here! Itís also tiny...but beautiful
https://i.imgur.com/ILWfCyB.jpg
https://i.imgur.com/F7gmc7M.jpg
Old 09-03-2019, 01:13 AM   #20
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
First video is up!!
Old 09-04-2019, 02:14 PM   #21
pcampbell
Member#: 437670
2005 2.5 SC OB
I think they switched to returnless in 2006 for many cars, A return style has 3 lines. 1 is supply, 1 is return and 1 is Evap. You can tell by going to RockAuto and looking at the fuel pump module, or.... in engine bay 3 hoses would be return style. I have no idea how to tune a returnless system but I am sure many people have done it successfully.
pcampbell is offline   Reply With Quote
Old 09-04-2019, 03:53 PM   #22
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
I disconnected the hose I thought was return and it’s definitely evap, no fuel. I’ve had this car tuned multiple times, no one has ever mentioned returnless being an issue?
Old 09-04-2019, 08:17 PM   #23
pcampbell
Member#: 437670
2005 2.5 SC OB
Yeah I don't think it will be much of an issue.
Old 09-07-2019, 11:38 PM   #24
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Video 1.5 is up!
Lots of work done today.. and more tomorrow. I'll have a video up next week of us actually working!
Some progress pics:
Installing the AWIC radiator and pump
https://i.imgur.com/K2iSZ7S.jpg
https://i.imgur.com/NSqzBOX.jpg
Pump and relay/fuse box 100% complete
https://i.imgur.com/SjFeaWK.jpg
Inside the pump relay/fuse box
https://i.imgur.com/TEgOqEL.jpg
Radiator complete
https://i.imgur.com/2H0bV5I.jpg
Hella horn mounting
https://i.imgur.com/lh5wnLl.jpg
Subimods Hella horn harness
https://i.imgur.com/IuJj89R.jpg
Rear galley plug used for turbo oil feed and AVLS oil temp sensor relocation
https://i.imgur.com/qhW1eyD.jpg
OEM turbo manifold sandblasted, painted, and ready for wrap
https://i.imgur.com/ne9fVTa.jpg
https://i.imgur.com/1L4ceMo.jpg
Old 09-12-2019, 09:03 PM   #25
koopascoob
Member#: 505486
2008 Subaru
Legacy
Hi tipsymechanic, awesome build.
I'm assuming you did engine management yourself. How did you adjust your ROM for the larger fuel injectors? Any guides anuwhere about this?
I'm going to slap on a used raptor SC kit soon with wrx injectors onto an ej253 and need help since I don't have a base map.
koopascoob is offline   Reply With Quote
