Welcome to the North American Subaru Impreza Owners Club Sunday January 19, 2020
Old 01-04-2019, 04:01 PM   #26
phd12v
Member#: 432497
18 Sti
ISM
i have heard it might get pushed back a little...since the RR technically does work on the 18 models (just no TPMS) while it is a nice feature to have, it isnt imperitive at this point. I wouldnt rule anything out for CES though yet
phd12v is offline   Reply With Quote
Old 01-06-2019, 04:08 AM   #27
ems111
Member#: 496082
2018 Wrx premium
Will the factory TPMS still work?
ems111 is offline   Reply With Quote
Old 01-06-2019, 08:49 AM   #28
ems111
Member#: 496082
2018 Wrx premium
And also, using the Rr and su2 where do I connect the punk wire on a pioneer AVH-2440nex?
Old 01-06-2019, 10:27 AM   #29
phd12v
Member#: 432497
18 Sti
ISM
yes no change in the way tpms works, it just wont show up on screen
Old 01-06-2019, 10:31 AM   #30
phd12v
Member#: 432497
18 Sti
ISM
thats a VSS wire....its in the SU2 harness it is pink as well
Old 01-06-2019, 03:52 PM   #31
ems111
Member#: 496082
2018 Wrx premium
The pioneer side seems to be missing the pink wire unless Iím just missing it. All are connected except a yellow and black wire and a plain blue wire. On the diagram it says for radio wire but Iím just not getting it haha
Old 01-07-2019, 11:21 AM   #32
phd12v
Member#: 432497
18 Sti
ISM
yellow/black is for alpine radios
blue is for amp turn on
Old 01-07-2019, 06:52 PM   #33
ems111
Member#: 496082
2018 Wrx premium
Where do I connect the STARLINK (brown) wire? That might be the solution to what I posted in the other thread. It says pink or white/blue. Since I donít have the SOS what blue/white is it referring to?
Old 01-08-2019, 10:32 AM   #34
phd12v
Member#: 432497
18 Sti
ISM
if you dont have the SOS button, you dont need to hook up the starlink wire.
Old 01-08-2019, 11:53 AM   #35
ems111
Member#: 496082
2018 Wrx premium
Gotcha! For the 2018 premium what do I need to switch in order to be able to make the gauges work? Or will a flash be available in the near future that would fix it?
Old 01-08-2019, 03:20 PM   #36
phd12v
Member#: 432497
18 Sti
ISM
i posted in another thread about the BCM location for can if you dont have telematics. If you dont want to get to the bcm, you can get can going to the upper display as well. Also having the correct can also allows the camera to work. WINK WINK
Old 01-08-2019, 10:45 PM   #37
ems111
Member#: 496082
2018 Wrx premium
okay, and the 7" is the same as the 6.2" when talking about the harness?
Old 01-10-2019, 04:01 PM   #38
ems111
Member#: 496082
2018 Wrx premium
Default 2018 wrx premium
After doing a lot of looking at diagrams then looking in the car the 2018 wrx premium without the nav and hk is super difficult to get to the CAN wires and with no telematics there's no harness. If you tapped into the CAN High and CAN low at the ECM would it work?
Old 08-12-2019, 12:20 PM   #39
jarheadflip
Member#: 328771
2012 STI limited
dark grey metallic
Just wondering if theres any more news on this.
jarheadflip is offline   Reply With Quote
Old 09-01-2019, 12:26 PM   #40
SuperFly03
Member#: 500885
2018 STI Type RA
Was wondering the same the Jarhead. I have everything picked out for my Type RA but waiting on firmware compatibility.
SuperFly03 is offline   Reply With Quote
Old 09-01-2019, 10:13 PM   #41
jarheadflip
Member#: 328771
2012 STI limited
dark grey metallic
Yeah hopefully soon
Old 12-07-2019, 04:39 AM   #42
egodestruct
Member#: 508775
Those of you that have installed an RR into an 18+, are the instructions the same as the 17 and earlier models? Just asking because their site doesn't list it as being supported for 18+ and hence they don't supply any installation instructions.
Does the SU2 wiring harness still work? And are 2020 cars supported?
egodestruct is offline   Reply With Quote
Old 12-21-2019, 10:47 PM   #43
joostin420
Member#: 1046
2016 WRX Limited
crystal white pearl
Planning on trading an MY16 wrx limited for an MY20 limited in the spring so starting to plan now. I see no support for the past couple of years with the maestro rr or rr2. Is there going to be support soon for the rr2?
joostin420 is offline   Reply With Quote
Old 12-22-2019, 12:51 AM   #44
LouCioccio
Member#: 496163
2018 Forester
Pearl White
Yes and yes su2 plus to2 for 1 antenna cable. I started herehttps://www.reddit.com/r/SubaruFores...dunit_install/ and finished here at this site. I updated my 2018 Premium with a Kenwood 9904s. CarPlay works iPhone. Cavate no TPMS GAUGE although I can go to gauge for volts. Hence the new Rr2 has an extra uart to access those. The instructions I used t-taps at can hi and can lo.
Lou Cioccio
LouCioccio is offline   Reply With Quote
Old 12-23-2019, 03:42 PM   #45
jamesgil
Member#: 510058
Default resp
good post
jamesgil is offline   Reply With Quote
Old 12-29-2019, 12:45 PM   #46
Bumbledom
Member#: 510209
This is what I have been waiting for, can't wait.
Bumbledom is offline   Reply With Quote
Old 01-17-2020, 11:36 PM   #47
joostin420
Member#: 1046
2016 WRX Limited
crystal white pearl
Starting to procure items in anticipation of an MY20 with a Kenwood dnx996xr. Does anyone have any more inside info of support for the maestro rr2? From what it looks like an su3 harness is in the works. There are obviously a lot of people ����*♂️
http://www.12voltdata.com/forum/view...18400&start=15
Old Today, 01:37 PM   #48
gunz4me
Member#: 305130
2019 WRX
Dark Gray
Looks like we just have to wait.
I remember the beta program for my 2013 VW GTI, and well, it was worth the wait then. I just have to suffer with the buggy USB port in my car until then since my dealership can't replicate the problem... Naturally, they blamed my cable, but that wasn't the case since I also lose my memory stick with MP3s when the USB wigs out.
gunz4me is offline   Reply With Quote
