Welcome to the North American Subaru Impreza Owners Club Thursday January 23, 2020
Old 12-03-2019, 06:56 PM   #1
anthony_suby713
Member#: 505885
Default Headlight 2011 wrx
Hey guys, so I noticed I had a headlight out on the drivers side about a 2 months ago and the same damn headlight is out again. Any ideas ? Is this some common issue with this series wrx?
anthony_suby713 is offline   Reply With Quote
Old 12-07-2019, 11:38 PM   #2
southmichigansubie
Member#: 499805
2012 wingless
dark blue
I have a 2012 and my passenger low beam goes out no matter what, it will work for a bit and then toast the bulb i quit replacing it, both my high beams work great idk lol
southmichigansubie is offline   Reply With Quote
Old 12-08-2019, 01:53 PM   #3
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/05 GTO
Using the high beams isn't really a solution, especially if there are other cars around-
Check the headlight connector for loose or burned contacts. A poor connection will cause voltage drop and heating which can result in early bulb failure.
Also check the voltage at the bulb terminals with the lights on. Excessive voltage (above 15V with the engine warmed up) will trash bulbs, although if this were the problem you'd likely have more than one bulb going out.
